Looks like the location of visibility setting for Crosshairs is changed. Where can I find it?
I can not set scale for layout in property panel. I changed value, but nothing happened.
3.Undo does work sometimes. If I reopen a file, it works again. Sometimes, even after reopening a file, it does not work.
4.When View projection is set to parallel, holding right clicking for rotation is not working. Looks like rotation is changed to Shift+Ctrl+Right Click. Is there any way to get it back to just right click?
Hi -
Please start new threads for different topics!
That was moved to Rhino Options > Modeling Aids > SmartTrack and Guides.
That seems to work fine here.
That works fine here as well…
I don’t have Rhino 4 or earlier installed here, but that seems to be the default behavior at least since Rhino 5.
Again, please start new threads for different topic, provide sample 3dm files where appropriate and pretty much always run SystemInfo and copy that information in your topic.
