Rhino 8: Antialiasing color looks black
Hi @stevebaer,
the antialiasing of magenta lines on my green surface looks black, and not good.
I had to take a photo from the monitor. Snapshots made with SnagIt don’t show this problem.
black_antialiasing_with_magenta_lines_on_green_surface.3dm (970.4 KB)
SystemInfo.txt (2.4 KB)
Thanks
Michael
hi @Michael_Meyer this is what I see in 8.6.24086.23001
Which matches what I see in Rhino 7
I think this is an inevitable result of two exact opposite colors, where the mix of the semitransparent pixels of magenta + green turns back a dark gray
You can improve the visibility of the magenta curves by increasing the curve thickness in shaded mode, but probably a more eye friendly fix is to use a different color for either the curves or the surface.
Hi @Gijs,
thank you for your time. Yes, perhaps a bad color combinaten.
Take care
Michael
