Rhino 8 Alpha Channel on all Clipping Plane Objects
I’m having trouble with clipping plane in Rhino 8 and an alpha channel being applied to the objects in the clipping plane.
In this first image, I have a figure that is a PNG placed in the scene. The figure is on a different layer than the rest of the objects. In using the clipping plane, the figures alpha channel is being applied to each object being cut by the clipping plane. These objects are on another layer and do not have that texture applied.
In this image- if I turn off the alpha channel for the texture, the appearance of the alpha channel is removed from the objects being cut.
Clipping Plane Alpha Channel.3dm (1.8 MB)
hmm, I’m not seeing that here:
can you run _SystemInfo in Rhino and post back the results?
edit: also there was no clippingplane in that file, could you send the file in the exact state that you see the issue?
Hi Gijs, thanks for the help.
Sorry about that. I thought that clipping plane was included. Should be in the attached it in the file below. I’ve checked my render display mode as you show above and that presents the issue as well.
Thanks for any help.
Clipping Plane Alpha Channel.3dm (1.7 MB)
Here’s my system info:
Rhino 8 SR6 2024-4-10 (Rhino 8, 8.6.24101.05001, Git hash:master @ 32c244aa711e0034e75bec2e87d093c764820b96)
License type: Educational, build 2024-04-10
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.17
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 11-7-2023 (M-D-Y).
Primary OpenGL: NVIDIA RTX A2000 8GB Laptop GPU (NVidia) Memory: 8GB, Driver date: 4-11-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.22
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-11-2024
Driver Version: 31.0.15.5222
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\mpolites\AppData\Roaming\McNeel\Rhinoceros\BlockEditNew\BlockEditNew.rhp “BlockEdit” 1.0.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.6.24101.5001
