Rhino 8.9 SRC2 installer reports corrupt .cabs. Rhino borked
I just ran the 8.9 SRC2 update installer. It reported that PLU_x64.cab, Core_x64.cab and LANG_EN are corrupt. Even though I acknowledged each error dialog with Cancel, the installer eventually reported “Installation completed successfully”, which seemed unreasonably optimistic.
I uninstalled Rhino 8, rebooted and ran an 8.8 installer. This gave the same corrupt .cab messages, although it had worked cleanly back in the day. I tried running Rhino and it crashed. The error report has been submitted.
How do I replace the corrupt .cab files with working copies so I can run a successful install?
TIA
Jeremy
Perhaps:
Automating Uninstall of Rhino 8
  1. Download BurnOut.exe utility.
  2. Run BurnOut.exe /uninstall {851D74A0-D029-4AC7-9CBE-E50455C24237}
This will find and uninstall any version of Rhino 8 on the computer. Note that uninstall doesn’t remove per-user files that were created during or after installation.
https://wiki.mcneel.com/rhino/uninstall/8
Or perhaps: https://wiki.mcneel.com/rhino/uninstalling
Manually Uninstalling Rhino
The following process applies to Rhino 4 and later (that includes Rhino 5, 6, 7.
Problem
During the startup, install or uninstall of Rhino, you get an error message like this:
The feature you are trying to use is on a network resource that is unavailable. Click OK to try again, or enter an alternate path to a folder containing the installation package ‘.MSI’ in the box below.
Cause
The Windows Installer cache cannot find a file or registry key required for uninstall. This is a common problem caused by the Windows Installer Service. The best solution is to use Windows Install Clean Up to thoroughly remove the previous installation. After you clean up the previous install, you will be able to reinstall Rhino and get a valid install.
Manually remove Rhino and the Windows Installer registration for the product. You will need to have Administrator privileges on your computer to complete this.
1. Run the Program Uninstall
  1. Close the Rhino application.
  2. Go to Windows Search.
  3. Type App and Features (or Add and Remove programs)
  4. Find the Rhinoceros x.0 program on the list, pick and select Uninstall button.
2. Delete the Rhino install folder
  1. Browse to *C:\Program Files*.
  2. Delete folder Rhinoceros x or Rhinoceros x Evaluation.
3. Delete the Rhino folders
  1. Browse to %AppData%\Roaming\McNeel\Rhinoceros.
  2. Delete folder x.0 where x is the Rhino version.
  3. Browse to %ProgramData%\McNeel\Rhinoceros
  4. Delete folder x.0 where x is the Rhino version.
4. Delete Registry Keys:
  1. Go to Windows Search and type Registry Editor.
  2. Open the Registry Editor.
  3. Browse to HKEY_LOCAL_MACHINE\Software\McNeel\Rhinoceros.
  4. Delete the x.0 Key. For example, Rhino 4.0, 5.0 or whatever version of Rhino you are removing.
  5. Browse to HKEY_CURRENT_USER\Software\McNeel\Rhinoceros.
  6. Delete the x.0 Key. For example, Rhino 4.0, 5.0 or whatever version of Rhino you are removing.
5. Reboot
  1. Apply all Windows updates.
  2. If you plan to reinstall, download the latest Rhino installer https://www.rhino3d.com/download/here.
_
Optional
You should only do the following procedures if uninstall fails from the Apps and Features.
Run Microsoft’s Uninstall Fix
  1. Visit Fix problems that block programs from being installed or removed - Microsoft Support
  2. Click Run Now.
Cleaning up the Windows Installer Cache
Warning: The following procedure may result in registry corruption and a 1402 error next time you install software. Only follow these steps if the above procedure did not allow you to install Rhino.
  1. Download the Windows Installer Cleanup Utility.
  2. Unzip the contents of WindowsInstallerCleanupUtility.zip to a “Windows Installer Clean Up” folder on your desktop.
  3. Run msicuu.exe.
  4. Scroll down to (All Users) Rhinoceros 5.0 WIP (or All Users Rhino 5.0 WIP x64) on 64-bit systems.
  5. Click Remove.
If you followed these steps and then got a 1402 error, these instructions may resolve the 1402 error.
David,
Thank you for taking the time to reply. I think I will wait until someone from McNeel can provide a little more info on those .cab files before doing anything drastic.
Regards
Jeremy
Three recent installer show the same error, notwithstanding two installed ok previously. Example of installer log sent to tech@mcneel.com.
@dan - any idea here?
I think this is more @brian’s area of expertise.
David’s suggestions are good ones. I’d also like to see the full install log that contains the failures: they’re named rhino* and are in your %temp% folder.
Hi Brian,
Logs went to tech@mcneel.com and I have been communicating with Cécile Lamborot on this. The short version is that the root cause was disk corruption, this then affected other installers and worsened quite rapidly to the point where Windows would not boot. New disks and a clean install of Windows and all apps, culminating just moments ago with Rhino 8.9, have installed fine.
Regards
Jeremy
