R9: GPU Lock / Freeze
“Revert back to R8” type issue.
Suspect: object transparency + locked objects.
GPU (RTX 3080) spikes to 99%. On large files (~250MB), system freezes.
Not a problem in earlier R9 WIP.
Side note:
Would be nice if R9 WIP by default limited GPU usage to max 90% to avoid freeze.
@Joshua_Kennedy the curve given here in Rhino 8 will offset on both sides ok only with distance 0.497. I tried with Offset Through Point on Both sides.
Hi Wim
-Will do!
I mostly use custom viewports and 80% transparency on locked objects in R8. (and R9 until recently) I check later if I can reproduce something with factory defaults, when the transparency option is back in R9. I assume that this situation is only temporary.
