Rhino wip --After inputting Testfancycurves, adjusting the data and setting enable to on, the drawing curve does not change because of what
Hi -
That command no longer exists. In the current WIP you change the curve’s appearance by using a custom linetype.
What can I do to change the appearance of the curve? What command should I enter?
The command no longer exists, 3d sketch mode is still there?
example:
example:
Thank you very much
