Hi McNeel Team,
I am currently using Rhino 8.36 with the newly released NVIDIA GeForce RTX 5060 Ti (Blackwell architecture). I am completely unable to use my GPU for Raytraced mode or Rhino Render. Both CUDA and OptiX options show a persistent orange dot (“Device is not ready”) and the system keeps falling back to CPU rendering.
I have already installed the latest Microsoft .NET Desktop Runtime and configured Windows Graphics Settings to “High Performance” for Rhino, but it did not resolve the issue.
Here are the specific behaviors from my GPU Kernel Compile Log:
1. Under OptiX Mode:
The compiler crashes immediately with a process stream conflict error:
Start compiling 1: NVIDIA GeForce RTX 5060 Ti (OptiX)
1: NVIDIA GeForce RTX 5060 Ti (OptiX) (0) | Initializing
1: NVIDIA GeForce RTX 5060 Ti (OptiX) (0) | Loading render kernels (may take a few minutes the first time):
Error Log:
System.InvalidOperationException: Cannot mix synchronous and asynchronous operation on process stream.
at System.Diagnostics.Process.get_StandardError()
at RhinoCyclesCore.Core.RcCore.StartCompileGpuKernels()
[OpenColorIO Info]: Color management disabled. (Specify the $OCIO environment variable to enable)
2. Under CUDA Mode:
The log states “No error” and allows the viewport to sample up to 1000/1000, but the UI dot remains stubbornly orange, indicating the device state is still not properly recognized or fully driven by Cycles for production rendering.
It looks like the RhinoCyclesKernelCompiler in Rhino 8.36 is having an asynchronous stream conflict with the new Blackwell architecture drivers.
Is there a specific hotfix driver version you recommend, or an updated RhinoCyclesKernelCompiler.exe patch that I can copy into my Rhino installation folder to get the RTX 5060 Ti fully functional?
Thank you for your assistance!
