**Title:** Rhino 8.35 – SpaceMouse buttons work but no cap motion (Rhino 7 works on same machine, RDP USB redirection)
**Problem**
On Rhino 8 the SpaceMouse buttons work (the Menu button shows the Rhinoceros profile, and button commands run), but moving the cap does nothing in the viewport: no pan, zoom or rotate. On the same machine, in the same session, with the same 3DxWare, **Rhino 7.38 navigates normally**, as does Houdini. 3DxHome also shows cap motion.
**Setup**
- Rhino 8 Commercial **8.35.26251.13001** on Windows 11 Pro 25H2 (build 26200)
- 3DxWare **10.9.15** (3DxWinCore 17.9.15.121, siappdll.dll 4.3.26267.121, 3dxhid 1.6.8.773)
- Device: SpaceMouse Pro Wireless, connected by cable (VID_256F / PID_C631)
- The workstation is used over Microsoft Remote Desktop (mstsc). The SpaceMouse reaches it through RemoteFX USB redirection (`usbdevicestoredirect`), so it shows up on the remote machine as a normal USB device, bound to 3Dconnexion’s `3dxhid` driver.
- Plug-in: the bundled `3dxrhino.rhp` (8.35.26251.13001) is loaded and not disabled. Rhino connects to 3DxWare through the siapp SDK and exports its command set, and 3DxWare switches to the Rhinoceros profile.
**What I’ve tried**
- Restarted Rhino after the device was connected (the device was present before Rhino started)
- Stopped and started 3DxWare, and deleted the user override of the Rhino profile (`%APPDATA%\3Dconnexion\3DxWare\Cfg\RhinoFS.xml`) so the default profile is used. Pan/Zoom and Rotation are both enabled in the 3DxWare advanced settings.
- Recalibrated the device
- Checked the Rhino 8 `Rhino.Options.SpaceBall.*` advanced settings. They’re at defaults (AllowTilt=True, scales 2048), and this build has no `UseLegacy` option.
- Ruled out elevation: Rhino, 3DxService and the 3Dconnexion processes all run at Medium integrity in the same session.
- Tested in the Perspective viewport:
- Tested the 3d mouse connected to the workstation via usb - works
**Results in the same session**
| App | Cap motion |
| 3DxHome / 3DxWare settings | works |
| Rhino 7.38 | **works** |
| Houdini | works |
| Rhino 8.35 | **buttons only, no motion** |
Since Rhino 7 works with the same 3DxWare, device and session, this looks specific to the Rhino 8 3Dconnexion plug-in. Is there a known issue with motion events in 8.35, or a setting to switch the 3D mouse integration mode?
`_SystemInfo` attached below.
Rhino 8 SR35 2026-9-8 (Rhino 8, 8.35.26251.13001, Git hash:master @ 3645d710f50175d8ebcf404aded5b042a481c23e)
License type: Commercial, build 2026-09-08
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 64GB)
.NET 8.0.23
Computer platform: DESKTOP (Hosting Remote Desktop session)
Primary display: Microsoft Remote Display Adapter (Microsoft) Memory: 0MB, Driver date: 6-21-2006 (M-D-Y).
> Remote Desktop display device with 16 connection(s)
- Windows Main Display using connection #0
Primary OpenGL: NVIDIA GeForce RTX 3090 (NVidia) Memory: 24GB, Driver date: 7-22-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 610.88
> Accelerated graphics device with 0 adapter port(s)
- There are no monitors attached to this device!
Secondary graphics devices.
Intel(R) UHD Graphics 770 (Intel) Memory: 2GB, Driver date: 10-18-2024 (M-D-Y).
> Integrated graphics device with 0 adapter port(s)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-22-2026
Driver Version: 32.0.16.1088
Z-Buffer depth: 24 bits
Total Video Memory: 24 GB
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.4.2.0
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll “Enscape.Rhino8.Plugin” 4.19.0.2748
C:\Users\Ruzek\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Rhino-MCP-Platform\0.3.0\net8.0\RhinoAI.rhp “RhinoAI” 0.3.0.0
C:\Program Files\Chaos\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.35.26251.13001
