Rhino 8.35 M1 Mac - Python runtime initialization - stuck at 5-15%
Hi everyone,
I’m using Rhino 8.35 on an Apple Silicon Mac, and the Python 3 component in Grasshopper gets stuck at approximately 5-15% on “Installing Python runtime.” The Rhino ScriptEditor also hangs at the same point.
Here’s what I’ve tried:
  • Disabled Rosetta so Rhino runs natively on Apple Silicon.
  • Renamed the original ~/.rhinocode/py39-rh8 folder so Rhino would create a fresh runtime.
  • Confirmed that the Python executable runs in Terminal and reports Python 3.9.10.
  • Confirmed that pip 21.2.4 is installed and working.
  • Confirmed that importing Python’s ssl module works.
  • Checked ~/.rhinocode/logs, but no log files appear.
The fresh runtime still gets stuck at the same percentage. Searching the runtime folder also didn’t find pyminilsp_server.py.
Does anyone know how to diagnose this issue or get RhinoCode to complete Python initialization?
Thanks!
Hi Ognyan,
This looks like the same hang we’re tracking in RH-98424, also 8.35 on Apple Silicon, i’ve added your thread to it. Can you open Rhino (without starting the script editor), run RhinoCodeLogs and post the last lines from the runtime install, plus the SystemInfo output? The other report stops right after it marks python3.9 as executable, so seeing where yours stops will help. Thanks!
I was just following up on this thread. I am having similar issues with python runtime on grasshopper
Hi -
From what I can tell, an attempt to fix this went into 8.37, which is available as a release candidate.
Please test on that version and report back.
Hi @wim, thanks for the 8.37 RC. I tested it and the issue is not fixed for me yet.
  • Script Editor still stalls on “Installing Python Runtime”. With 8.36 it stopped around 18 %; with 8.37 it gets past 60 %, but it never finishes.
  • Any first Python 3 execution then blocks Rhino’s main thread and I have to force-quit. A minimal print(1+1) sent through the official Rhino MCP Platform (run_python) is enough to reproduce it, even in a nearly empty document. It happened again today.
  • C# scripts sent the same way (run_csharp) run fine, so it looks specific to the CPython 3.9 runtime.
My Setup
  • Rhino 8.37 RC (8.37.26294)
  • macOS 27.0, Apple Silicon (Mac mini)
  • Rhino running natively (not under Rosetta)
Hi Feñus -
Could you please do the following?
Hi, @wim I’m experiencing exactly same issues as Feñus. I updated to the RC and it still gets stuck just a bit later on.
Also, when trying to initialise python 3 by placing a python 3 script component in Grasshopper it causes the spinning wait cursor, until I force quit Rhino. I’ve tried renaming and deleting ~/.rhinocode/py39-rh8 but that hasn’t helped.
Here are the logs, hope this helps.
RhinoCodeLogs
Info 11/02/2026 12:00:15 [RhinoCode] Storage Site Registered: Local Drive (mcneel.eto.file)
Info 11/02/2026 12:00:15 [RhinoCode] Storage Site Registered: Rhino Files (mcneel.rhinoFiles.file)
Info 11/02/2026 12:00:15 [RhinoCode] Storage Site Registered: Web (mcneel.console.http)
Info 11/02/2026 12:00:15 [RhinoCode] Rhino3D Initialized on macOS - NETCoreApp
Info 11/02/2026 12:00:15 [RhinoCode] Platform Registered: Rhinoceros 3D @ 8.37.26294.11002 (mcneel.rhino3d.rhino)
Info 11/02/2026 12:00:15 [RhinoCode] Storage Site Registered: Rhino3D Project (mcneel.rhino3d.project)
Info 11/02/2026 12:00:15 [RhinoCode] Operating System: Unix 27.2.0
Info 11/02/2026 12:00:15 [RhinoCode] RhinoCode server starting on /var/folders/5h/g9gyszn948s2krnjgt7pj9nm0000gn/T/CoreFxPipe_rhinocode_remotepipe_27101
Info 11/02/2026 12:00:15 [RhinoCode] Language Registered: Plain Text 1.0 (rhinocode.builtin.text)
Info 11/02/2026 12:00:15 [RhinoCode] Language Registered: JSON 1.0 (rhinocode.builtin.json)
Info 11/02/2026 12:00:15 [RhinoCode] Language Registered: Yaml 1.0 (rhinocode.builtin.yaml)
Info 11/02/2026 12:00:15 [RhinoCode] Language Registered: Git DotFile 1.0 (rhinocode.builtin.gitDotFile)
Info 11/02/2026 12:00:15 [RhinoCode] Language Loader Registered: mcneel.pythonnet.python@3.*
Info 11/02/2026 12:00:15 [RhinoCode] Language Loader Registered: mcneel.ironpython.python@2.*
Info 11/02/2026 12:00:15 [RhinoCode] Language Loader Registered: mcneel.roslyn.csharp@9.*
Info 11/02/2026 12:00:15 [RhinoCode] Language Loader Registered: mcneel.gh1.grasshopper@1.*
Info 11/02/2026 12:00:15 [RhinoCode] Language Loader Registered: mcneel.markdig.markdown@0.*
Info 11/02/2026 12:06:06 [RhinoCode] Language Registered: Python 3.9.10 (mcneel.pythonnet.python)
Info 11/02/2026 12:06:06 [RhinoCode] Language Registered: IronPython 2.7.12 (mcneel.ironpython.python)
Info 11/02/2026 12:06:06 [RhinoCode] Language Registered: C# 9.0 (mcneel.roslyn.csharp)
Info 11/02/2026 12:06:06 [RhinoCode] Language Registered: Grasshopper 1.0 (mcneel.gh1.grasshopper)
Info 11/02/2026 12:06:06 [RhinoCode] Language Registered: Markdown 0.30.4 (mcneel.markdig.markdown)
Info 11/02/2026 12:06:07 [RhinoCode] Initializing CPython 3.9.10/43 runtime
Info 11/02/2026 12:06:09 [RhinoCode] Configuring runtime@py39-rh8 for the first time on Arm64
Info 11/02/2026 12:06:09 [RhinoCode] Deploying CPython 3.9.10/43 runtime
Info 11/02/2026 12:06:09 [RhinoCode] Clearing exiting runtime
Info 11/02/2026 12:06:09 [RhinoCode] Successfully uninstalled existing runtime at /Users/sasha/.rhinocode/py39-rh8
Info 11/02/2026 12:06:10 [RhinoCode] Marking python binary as executable: /Users/sasha/.rhinocode/py39-rh8/python3.9
Info 11/02/2026 12:06:10 [RhinoCode] Running process: /bin/bash -c "/bin/chmod +x /Users/sasha/.rhinocode/py39-rh8/python3.9"
System Info
Rhino 8 SR37 2026-10-21 (Rhino 8, 8.37.26294.11002, Git hash:master @ a6592128d921cf5111f81ead500d1035845fda34)
License type: Educational Lab License, build 2026-10-21
License details: Cloud Zoo
Apple macOS Version 27.2 (Build 26B123) (Physical RAM: 18GB)
Mac Model Identifier: Mac15,6
Language: en-GB (MacOS default)
.NET 10.0.8
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
  Apple M3 Pro
    Color LCD (1800 x 1169 @ 120.00Hz)
GPU Vendor: Apple
USB devices
  None
Bluetooth devices
  None
Third party kernel extensions
  None
Third party plugins
  /usr/lib/objc/libobjcMsgSend.dylib
  /usr/lib/swift/libswiftObservation.dylib
  /usr/lib/swift/libswiftSpatial.dylib
  /usr/lib/swift/libswiftSynchronization.dylib
  /usr/lib/swift/libswift_Builtin_float.dylib
  /usr/lib/swift/libswift_DarwinFoundation1.dylib
  /usr/lib/swift/libswiftDistributed.dylib
  /usr/lib/swift/libswift_DarwinFoundation2.dylib
  /usr/lib/swift/libswift_DarwinFoundation3.dylib
  /usr/lib/swift/libswiftAppleArchive.dylib
  /usr/lib/swift/libswiftMLCompute.dylib
  /usr/lib/swift/libswiftNaturalLanguage.dylib
  /usr/lib/swift/libswiftFoundation.dylib
  /usr/lib/swift/libswiftSwiftOnoneSupport.dylib
  /usr/lib/swift/libswiftsys_time.dylib
  /usr/lib/swift/libswiftCoreMediaIO.dylib
  /usr/lib/swift/libswiftCallKit.dylib
  /usr/lib/objc/libobjcMsgSend1.dylib
  /usr/lib/objc/libobjcMsgSend2.dylib
  /usr/lib/objc/libobjcMsgSend3.dylib
  /usr/lib/objc/libobjcMsgSend4.dylib
  /usr/lib/objc/libobjcMsgSend5.dylib
  /usr/lib/objc/libobjcMsgSend6.dylib
  /usr/lib/objc/libobjcMsgSend7.dylib
  /usr/lib/objc/libobjcMsgSend8.dylib
  /usr/lib/objc/libobjcMsgSend9.dylib
  /usr/lib/objc/libobjcMsgSend10.dylib
  /usr/lib/objc/libobjcMsgSend11.dylib
  /usr/lib/objc/libobjcMsgSend12.dylib
  /usr/lib/objc/libobjcMsgSend13.dylib
  /usr/lib/objc/libobjcMsgSend14.dylib
  /usr/lib/objc/libobjcMsgSend15.dylib
  /usr/lib/objc/libobjcMsgSend16.dylib
  /usr/lib/objc/libobjcMsgSend17.dylib
  /usr/lib/objc/libobjcMsgSend18.dylib
  /usr/lib/objc/libobjcMsgSend19.dylib
  /usr/lib/objc/libobjcMsgSend20.dylib
  /usr/lib/objc/libobjcMsgSend21.dylib
  /usr/lib/objc/libobjcMsgSend22.dylib
  /usr/lib/objc/libobjcMsgSend23.dylib
  /usr/lib/objc/libobjcMsgSend24.dylib
  /usr/lib/objc/libobjcMsgSend25.dylib
  /usr/lib/objc/libobjcMsgSend26.dylib
  /usr/lib/objc/libobjcMsgSend27.dylib
  /usr/lib/objc/libobjcMsgSend28.dylib
  /usr/lib/objc/libobjcMsgSend29.dylib
  /usr/lib/objc/libobjcMsgSend30.dylib
  /usr/lib/objc/libobjcMsgSend31.dylib
  /usr/lib/objc/libobjcMsgSend32.dylib
  /usr/lib/objc/libobjcMsgSend33.dylib
  /usr/lib/objc/libobjcMsgSend34.dylib
  /usr/lib/objc/libobjcMsgSend35.dylib
  /usr/lib/swift/libswiftPassKit.dylib
  /usr/lib/swift/libswiftGLKit.dylib
  /usr/lib/swift/libswiftMetalKit.dylib
  /usr/lib/swift/libswiftModelIO.dylib
  /usr/lib/swift/libswiftSceneKit.dylib
  /usr/lib/usd/libusd_ms.dylib
  /usr/lib/swift/libswiftExtensionFoundation.dylib
  /usr/lib/swift/libswiftGameplayKit.dylib
  /usr/lib/swift/libswiftSpriteKit.dylib
  /Users/sasha/Library/Application Support/McNeel/Rhinoceros/8.0/MacPlugIns/DatasmithRhino8.rhp/DatasmithFacadeCSharp.dylib
  /Users/sasha/Library/Application Support/McNeel/Rhinoceros/8.0/MacPlugIns/DatasmithRhino8.rhp/libtbbmalloc.2.dylib
  /System/Volumes/Preboot/Cryptexes/OS/usr/lib/libMetalMetricsInterpose.dylib
  /Users/sasha/Library/Application Support/McNeel/Rhinoceros/8.0/MacPlugIns/DatasmithRhino8.rhp	"Datasmith Exporter"	5.7.4.0
  /Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework	"Renderer Development Kit"	8.37.26294.1002
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp	"Commands"	8.37.26294.11002
  /Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp	"Snapshots"	8.37.26294.1002
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp	"RDK_EtoUI"	8.37.26294.11002
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp	"MeshCommands"	8.37.26294.11002
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp	"Rhino Render"	8.37.26294.11002
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp	"RhinoCycles"	8.37.26294.11002
  /Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp	"SectionTools"	8.37.26294.1002
  /Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp	"Displacement"	8.37.26294.1002
  /Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp	"PanelingTools"	8.37.26294.1002
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp	"IronPython"	8.37.26294.11002
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp	"Grasshopper"	8.37.26294.11002
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp	"RhinoCodePlugin"	8.37.26294.11002
Seeing the exact same here with a single user in our enviro. Completely removed AV, using open internet, not behind firewall. No change. User is logged in with a Mobile Account (AD joined apple silicon MBP) with admin rights… If signed in as a local admin account, we do not have the issue.
Last line in the logs stop at: Running process: /bin/bash -c “/bin/chmod +x /Users/REDACTED/.rhinocode/py39-rh8/python3.9”
I’m having this problem as well. I cannot run Raven and cannot run python. I’ve worked with IT and it’s not any firewall issue. It really seems to be in something with the latest Rhino release.
Hi Michael,
Please run the SystemInfo command in Rhino and post the results.
When troubleshooting start by removing 3rd party plugins.
Yep! I just did a deep dive. When I removed “Datasmith Exporter plugin for Rhino.” it ran python and Raven. This has been a problem for days and it came down to this.
