Pascal - thanks for responding. The crashing has been happening on saved and non-saved files. Unfortunately, when Rhino8 goes down, it can crash to desktop so fast that I don’t notice, and search through the Alt-Tab process selection to make sure it’s not hidden under some other window. Crash report UI’s are a rare thing in my experience with Rhino8. Rhino7 would occasionally crash - maybe once a month or so - and a crash report dialog would pop up. Rhino8 is, in my experience much more unstable and crashing - usually to desktop - is a daily occurrence, sometimes multiple times.
Blockquote Do you get a crash report UI so that you can send us the crash information (very helpful) when it crashes?
not very often, but when I do, I send it because you guys are awesome and I know it’s useful.
Blockquote Does the Autosave command generate a file?
yes
Blockquote If so, does this file disappear when Rhino closes cleanly?
yes
Blockquote Can you please run SystemInfo
in Rhino and post the results?
You bet ::
Rhino 8 SR3 2023-12-12 (Rhino 8, 8.3.23346.14001, Git hash:master @ 3b8659a0557b596b2d172939093022d2b67fd2e1)
License type: Commercial, build 2023-12-12
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64Gb)
.NET Framework 4.8.9181.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2080 Ti (NVidia) Memory: 11GB, Driver date: 10-26-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.01
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
- Secondary monitor attached to adapter port #2
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-26-2023
Driver Version: 31.0.15.4601
Z-Buffer depth: 24 bits
Total Video Memory: 11 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\ConnecterPlugIn (caac53be-e271-4b97-93e7-f3dd18d48ccc)\0.5.0.0\ConnecterPlugIn.rhp “ConnecterPlugIn” 0.5.0.0
C:\Users\XXXXX\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.3.23346.14001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.3.23346.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.3.23346.14001
C:\Users\XXXXX\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.3.23346.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.3.23346.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.3.23346.14001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.3.23346.14001
