Rhino 7sr11 will not save aliases
it will not save changing ‘C’ from ‘circle’ to ‘copy’, among others. but i have tried several times only changing that one and it will not take. Also tried changing another single command at a time, no luck with that either. settings-Scheme__Default.xml (79.3 KB)
our Design applications support group is working on this, I’m sure you’ll be in contact with them. Thanks.
Hi, was this ever figured out? I am having the same issue.
Thanks-
Hi Ridvan -
Please run the Rhino SystemInfo command and copy-paste the result here.
Having similar issues
Rhino 7 SR34 2023-9-24 (Rhino 7, 7.34.23267.11001, Git hash:master @ a37d83041828484840f2448d5b3e3770e46694f9)
License type: Commercial, build 2023-09-24
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3080 Ti (NVidia) Memory: 12GB, Driver date: 6-8-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.23
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-8-2023
Driver Version: 31.0.15.3623
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.34.23267.11001
Hi Steve -
Can you please describe the issues in detail?
Hi Wim
The ‘bugs’ I’ve noticed are the display panel being reset; I have the properties panel locked against the layers/rendering/materials panel. Below this is locked the layout panel. This panel layout is reset to default each time I open Rhino.
The selection filter locked at the bottom of the screen is reset (gone). Aliases set are gone. Ortho gets switched off. Viewport tabs are moved back to the bottom instead of being on the left. Line type in Print Setup switches back to Match Pattern Definition. I think chamfer distances are reset. It feels as though the command line user function prediction does not remember. There may be other things I’ve not noticed
I did notice windows defender blocking Rhino, I’ve tried to allow Rhino access but not sure if I did this correctly. To be clear this is a new PC and the issues weren’t there on my old laptop. Also the computer came with windows 10 and I inadvertently upgraded to 11. Issues happened on both 10 and 11
Hey Wim
Any ideas on a fix?
@user1963 it sounds to me that Rhino has insufficient rights to write the settings back to disk
Does the problem persist if you (temporarily) disable it?
Hello @Gijs , @wim @Japhy . My aliases and keyboard shortcuts don’t get loaded while in Rhino Inside Revit.
Rhino 7 SR36 2023-12-12 (Rhino 7, 7.36.23346.16351, Git hash:master @ 11a364321297eb8cdb34405a3308d8911f58706d)
License type: Educational, build 2023-12-12
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Unplugged [53% battery remaining] ~170 minutes left
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 9-8-2022 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 4070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 8-27-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.28
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 8-27-2023
Driver Version: 31.0.15.3728
Total Video Memory: 8188 MB
C:\Users\Jobriel\AppData\Roaming\McNeel\Rhinoceros\BlockEditNew\BlockEditNew.rhp “BlockEdit” 1.0.0.0
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.36.23346.16351
In Rhino.Inside.Revit you can run isolated settings from standalone Rhino. This allows you to specific different template (units, tolerances) that are specific to your Revit setup.
Hi japhy, care to elaborate? this setting is checked when i opened it.
