Rhino 7's "Blend surface" locked sliders don't move smoothly while one of the edges is G0
In Rhino 6’s “Blend surface”, the locked sliders for both ends moved smoothly no matter what’s the continuity for each end. Even if one of the blend surface’s ends was G0, the sliders were still fully responsive. However, Rhino 7’s sliders don’t work smoothly if one of the blend surface’s ends is set to G0. Upon trying to move the slider for the G0 end the former will move just slightly, then will stop and will no longer follow the movement of the mouse pointer. Here is a video showing that behaviour. Rhino 6 did it much better in that regard:
https://mcneel.myjetbrains.com/youtrack/issue/RH-62868
This bug is still present and I will be glad if it gets fixed soon in Rhino 7. :slight_smile: It was reported more than two years ago and I wonder what’s the situation with it.
