Rhino 7 WIP Available Now!
Rhino WIP for Windows and Mac 7.0.19330 is now available!
Bugs Fixed:
  • RDK attempts to download textures that don't exist, over and over again (RH-55705)
  • Annotation: DimLinear: Made "Mask margins" value box always enabled (RH-55704)
  • Commands: 'FieldDictionary.AddTextured(string, Color4f, string)' is obsolete (RH-55847)
  • Eto:
    • Eto Gridview dragging issues In Layout Panel (RH-55754)
    • Eto GridView - cannot double click on editable items (RH-55755)
  • File IO: Hookup Z to Y transform for SubD objects in OBJ export. (RH-55831)
  • NamedView: Viewport title update on Pan (RH-52929)
  • OffsetMesh: Changing to UseVectorLength=No gets different results (RH-55946)
  • RDK: CRhRdkSmartFrameBuffer::DrawGPU is provided with wrong rectClip when using render window scrollbars (RH-55779)
  • RelocateGumball: Gumball lost with OnSrf (RH-55873)
  • ShowEnds: Can't zoom to last end when ZoomEnds is canceled (RH-55924)
  • Snapshot: Issues of saving v7 as v6 (RH-55745)
Cosmetics:
  • MacroEditor: Use consistent toolbar button class in Macro Editor (RH-55894)
Enhancements:
  • Layout: Change order of Layouts by dragging (RH-41070)
  • ShowEnds: Clicking the Zoom button brings view back to the current end (RH-55568)
Regressions Fixed:
  • Display: Turning on Shadows for Shaded causes an issue with wires (RH-55840)
Usability Problems Fixed:
  • ShowEnds: Remember current end in the command session (RH-55943)
Mac-Only Changes
Cosmetics:
  • Name should be Rhino followed by a major version (RH-55765)
UI Change:
  • Preferences: Themes: Layout section outdated (RH-55480)
Windows-Only Changes
Bugs Fixed:
  • Grasshopper: Crashes when running headless in Rhino.Inside (RH-55913)
  • NamedView: UndoView does not remove * (RH-55872)
  • PropertiesPage: Icons not display full colors (RH-55666)
  • RDK: XML validation failed (RH-55753)
  • Rhino Inside: Docker no longer works (RH-55798)
  • NamedView: Re-order views in the list (RH-6961)
Rhino WIP for Windows and Mac 7.0.19337 is now available!
Bugs Fixed:
  • Annotation: Text size changes in edit control when changing format (RH-55976)
  • Bridge: Shaded subd preview when Join=No (RH-54567)
  • Connect: Wrong end with Smooth (RH-55830)
  • Display:
    • Shaded restores to modified (RH-55784)
    • Block Display Optimizations (RH-55886)
    • ViewCaptureTo* has been broken for Raytraced (RH-56002)
  • File IO: Console application using Rhino.Inside cannot export STL (RH-55938)
  • InsertEdge: Flat and smooth edges are both displayed (RH-55404)
  • RDK: Ground Plane panel has wrong background color (RH-55858)
  • Rendering: Materials:
    • SDK for physically based material incomplete (RH-55648)
    • Emission in PBR material shouldn’t require a texture (RH-55688)
    • Eto UI for double sided material (RH-55786)
    • PBR material with Sheen effect applied doesn’t show Sheen UI in the Material panel (RH-55921)
  • Split: Splitting a srf or polysurf by a curve partially on surface (RH-4996)
  • Stitch:
  • Trim: Trim fails on polysurface (RH-55874)
  • UDT: Reuse a cage deforms, moves, the captives (RH-55960)
  • UI Cleanup: Texture not enabled when adding procedural texture to material slot (RH-56003)
Crashes Fixed:
  • This case in GenerateRingEdges is not implemented (2) (RH-53806)
Enhancements:
  • Connect: New ExtendOtherCurvesBy=Line/Smooth options (RH-55133)
  • ReduceMesh: Added separators in large numbers (RH-55750)
  • Reflect: Saves SubD reflection information in 3dm files (RH-55905)
  • SubD Editing: : EdgeLoop selection feature for EditPts on SubDs (RH-55903)
Features Added:
  • PackageManager: Add command line args to -PackageManager that will pre-fill the search filter on the "Online" tab (RH-55389)
Tasks Completed:
  • Help: "Rhino .3dm Import/Export" help doesn't yet have a V7 section (RH-55711)
Bugs Fixed:
  • Reflect: Reflect creates holes and a bad SubD (RH-55889)
Enhancements:
  • Reflect: Reflect could use an X or Y axis option (RH-55890)
Features Added:
Mac-Only Changes
Bugs Fixed:
  • File IO: Update 3dm file version to 7.0 (RH-55625)
  • Reflect: An unknown command on Rhino 7 for Mac (RH-55967)
  • UI Cleanup: Rendering panel render size defaults to showing units in inches instead of pixels (RH-56004)
Crashes Fixed:
  • Stitch: com.mcneel.rhinoceros.RhCore:-[MRToolPaletteButtonCell doMacro] (RH-55811)
Enhancements:
  • Reflect: Reflect could use an X or Y axis option (RH-55968)
  • Rendering: Texture Mapping: Texture property to control the texture mapping method used in assigned materials is needed (RH-55802)
UI Change:
Rhino WIP for Windows and Mac 7.0.19344 is now available!
Bugs Fixed:
  • Lights property panel doesn't show up in certain cases (RH-54888)
  • Connect: Wrong end (RH-56096)
  • Cycles:
    • Rendering uses incorrect aspect ratios. (RH-53404)
    • Glass material doesn’t match / Raytraced vs. Rhino Render (RH-55297)
  • Display:
    • Material is transparent on Open until edited (RH-55050)
    • Memory leaks in display code (RH-55443)
    • PBR Displacement texture isn’t being baked (RH-56078)
  • Eto: Eto TreeGridView - unselect all when clicking into empty space (RH-55836)
  • OffsetMesh: Common normal option (RH-44646)
  • OpenNURBS: Bug in ON_SimpleArray<T>::QuickSortAndRemoveDuplicates (RH-55944)
  • Rendering:
    • Rhino Render Preview for No Environment is wrong (RH-55008)
    • Gamma controls on Windows are too bunched up (RH-55587)
    • Pick button on Depth of field is not implemented (RH-55588)
    • Bad Cycles bump result on PBR material (RH-55710)
    • PEP switches are confusing (RH-55916)
    • More multiples (RH-55740)
    • Cycles does not work correctly with new Double Sided material (RH-55787)
    • Specularity in PBR doesn’t work (RH-55823)
    • PBR Clearcoat bump has no effect in rendered mode. (RH-55835)
    • Subnode “Change…” menu item should result in a completely new content (RH-55855)
    • Double sided PBR doesn’t work with emission effect (RH-55955)
    • Some material names are loaded wrong (RH-56042)
  • Silhouette: Draft Curves for Get Silhouette (RH-55954)
  • SlideEdge: SlideEdge preview should use the geometry shown for SubD objects (RH-54494)
  • Snapshot:
    • Double-clicking a snapshot to restore it doesn’t always work (RH-56008)
    • Suppress the warning (RH-56095)
  • SubD: Can't delete non-manifold parts of SubDs (RH-56093)
  • SubD Editing:
    • Userdata lost on SubD when a face is moved (RH-55852)
    • EditSubDPtOn and EditSubDPtOnRepeat - edit selected subd surface points (RH-55878)
  • Trim: Trim - Split V7 Issue (RH-56005)
Cosmetics:
  • Menu: Provide link to EdgeContinuity panel from Analyze > Surface menu (RH-53166)
Crashes Fixed:
  • SubD: opennurbs!ON_SubDFace::EvaluateCatmullClarkSubdivisionPoint – Access Denied (RH-55607)
Enhancements:
  • DraftAngleAnalysis: Porting dialog from C++/MFC to C#/Eto (RH-53794)
  • OffsetMesh: New offset direction modes and so on (RH-55213)
  • Rendering: Tone mapping GPU support (Clamp, Black/White point, Logarithmic, Filmic, False color) (RH-55780)
  • Snapshot: Snapshot UI is confusing (RH-56037)
  • SubD Editing: Make EditPtOn command work with SubD objects. (RH-49249)
Tasks Completed:
UI Change:
  • Menu:
    • Add Stitch to SubD menu > Edit Tools (RH-55956)
    • InsertEdge needs to be added to the SubD menu (RH-55957)
    • InsertPoint needs to be added to the SubD menu (RH-55958)
    • Add Reflect command to the SubD menu (RH-55979)
  • Snapshot: Snapshot - Excludes unselected data to avoid tremendously increasing model size (RH-56079)
Mac-Only Changes
Bugs Fixed:
  • Display: Rendered mode doesn't show SubD custom mapping (RH-56049)
  • NamedView: Re-order views in the list (RH-55912)
  • Preferences: Rhino 7 for Mac is stuck in Rhino for Windows theme (RH-55966)
  • Rendering: Materials: Sub object materials are not handled correctly when converting from old school (RH-56139)
  • ToolPalettes: Rhinoceros/Commands/Customize Item macros background color is white in dark mode (RH-56044)
  • Toolbar: Icon "fails" on the Mac -dark mode (RH-54440)
Enhancements:
  • Toolbar: RMB macro for SoftTransform (RH-55661)
UI Change:
  • Preferences: Snaps panel truncated on first run (RH-55929)
Bugs Fixed:
  • Annotation: Styles: AnnotationStyles crashes when using the Scale all sizes button (RH-54250)
  • Display: Rendered mode doesn't show SubD custom mapping (RH-55108)
  • PropertiesPage: Object Properties page goes blank when closing the floating panel and reopening the object properties page. (RH-56083)
  • Rendering: Materials: Sub object materials are not handled correctly when converting from old school (RH-56100)
  • RhinoStart: Rhino window doesn't return to last position on the screen when restarted (RH-52855)
  • Snapshot: Not animating material blend amount (RH-56009)
Crashes Fixed:
  • :`scalar deleting destructor' – (NTSTATUS) 0xc00000fd - A new guard page for the stack cannot be created. (RH-55528)
  • PackageManager: Commands.UI.OnlinePackagesSidePanel.<>c__DisplayClass3_0.<<-ctor>b__27>d.MoveNext () (RH-55806)
Rhino WIP for Windows and Mac 7.0.19351 is now available!
Bugs Fixed:
  • CRhinoSettings is unreliable (RH-55242)
  • Analysis:EdgeContinuity: Mistakenly opens the ShowEdges dialog (RH-56094)
  • Bake: SubD object with spherical mapping bakes completely black (RH-56149)
  • Bridge:
    • Rename Smoothness option (RH-54570)
    • Help button does not open the topic (RH-56298)
  • Copy: Issue with SubD face (RH-54438)
  • Cycles: Rhino Render does not delete the CRhRdkRenderWindow object (RH-56176)
  • DraftAngleAnalysis: Make create parting curves button more obviously connected to the check boxes (RH-56117)
  • Gumball: Extrude handle is getting blocked by translation arrow shaft (RH-56165)
  • NamedCPlane: Cannot deselect items by clicking at an empty area (RH-55777)
  • OSnap:
    • Projected osnap tooltip lags on view change (RH-56072)
    • Fails on selected meshes (RH-56160)
  • Osnap:Vertex:
  • Properties: Dash properties macros error (RH-55658)
  • RDK:
    • Read in old materials as new-style always (RH-50100)
    • Assert fired in CRhRdkFrameBufferChannel::GetAllValues (RH-55964)
    • Dragging a TextureProxy on the Mac seems to be broken. (RH-56252)
  • Reflect: Reflect creates holes in this case (RH-55947)
    • Keep textures more stable (RH-55363)
    • Displacement texture in PBR does nothing (RH-55685)
    • Switching from a Custom material to a PBR material doesn’t work well (RH-55700)
    • PBR bump direction is wrong (opposite) than what is expected. (RH-55735)
    • Texture crossover (RH-55774)
    • Optimize ON_Material::PhysicallyBased for Steve (RH-55907)
    • Made Brass and Gold colors slightly different (RH-56068)
  • Rendering: Realtime SDK: RhRdkBakeTexture does not support PBR channels (RH-56020)
  • SelEdgeRing: preview does not highlight the whole ring (RH-56056)
  • Select: Can't select the SubD (RH-53910)
  • Selection: Sub-object select doesn't work on grouped objects (RH-56102)
  • Snapshot: Physical based material property animation support for Snapshots (RH-56142)
  • SubD: Valence 2 evaluation bug (RH-54312)
  • Textures: Don't combine textures just because they have the same settings (RH-55362)
  • ToSubD: ToSubD Selection tune-up - prohibit selection of SubD objects as input (RH-54513)
  • Units: Slow redraw (RH-54652)
Cosmetics:
  • SDK: RhinoCommon: Use consistent toolbar (or button row) in all panel (RH-55888)
Enhancements:
  • Bridge: Edge picking is harder in shaded mode (RH-56122)
  • File IO: Imports block descriptions (RH-56137)
  • LayerBook: New Stop option (RH-56113)
  • SubD: "Align to Object" supports SubD sub-objects (RH-41915)
  • What: Added SubD information about damaged components, wire edges, and nonmanifold edges (RH-56120)
Features Added:
  • Grasshopper: Placeholder component for keeping files intact during a Read/Write operation. (RH-55420)
  • Rebuild: Supports History when Delete Input is unchecked (RH-56271)
Performance Improvements:
  • RDK:
    • Function needed for quickly getting a contiguous, interleaved array of pixel data from a CPU/GPU channel (RH-55866)
    • Function needed for quickly setting a contiguous, interleaved array of pixel data to a CPU/GPU channel (RH-55985)
SDK Enhancement:
  • SDK: Need DraftAngle from ON_SilhouetteParameters wrapped (RH-55909)
Tasks Completed:
  • ToolPalettes: Add to toolbars (RH-56011)
UI Change:
  • Icons: Icon needed for Reflect command (RH-55978)
Mac-Only Changes
Bugs Fixed:
  • CRhinoDib fills with the wrong color (RH-55180)
  • Print: Rhino incorrectly prints Layer panel (RH-55381)
  • Reflect: Reflect creates holes and a bad SubD (RH-55969)
  • Toolbar: Toolbar buttons like Quad report Unknown command (RH-56115)
Crashes Fixed:
  • Rendering: com.mcneel.rhinoceros.RhMaterialEditor:CRhRdkDocumentDataSource_Rendering::Print() (RH-55076)
Bugs Fixed:
  • Eto: ETO Win DragDrop Source is null (RH-56144)
  • InsertPoint: Unable to split ngon (RH-47797)
  • NamedView: Named View UI is broken (RH-52463)
  • Snapshot: Arrows need a refresh (RH-56211)
  • Textures: Information tune up (RH-56128)
  • UI Cleanup: Texture drag and drop between Physically Based material slots works differently from old-style Custom material (RH-56076)
Cosmetics:
  • UI Cleanup: Background color of Document Properties > Render (RH-55991)
Enhancements:
  • ProjectOsnap: New "Project object snaps to CPIane in plan parallel views" option (RH-54162)
UI Change:
  • Toolbar: Clean up Mesh Utilities (RH-56131)
Rhino WIP for Windows and Mac 7.0.20007 is now available!
Bugs Fixed:
  • CLK_TCK and CLOCKS_PER_SEC need review (RH-56291)
  • Display:
    • Far from Origin - Moving to far off location should update display meshes automatically (RH-54464)
    • Rendered mode takes a while to get started when loading baked textures (RH-56280)
  • DraftAngleAnalysis: Create parting curve needs SubD support (RH-56116)
  • File IO: Unexpected "Save changes to Untitiled?" dialog (RH-56244)
  • FilletEdge: FilletEdge rejects tangent edges using 1 degree rather than the document's angle tolerance (RH-56332)
  • Grasshopper: Callback system for GH exceptions (RH-55315)
  • Gumball:
    • Face selection and History (RH-56403)
    • The far extrusion dot is highlighted (RH-56430)
  • InsertPoint: InsertPoint doesn't use Osnaps well (RH-55980)
  • NamedSelections:
    • Named Selections CTRL+LMB to select sub selections is not working (RH-53643)
    • Items doubled on every file save (RH-55088)
    • The Save button does not work (RH-56333)
  • OSnap: Does not ignore occluded snaps on SubD (RH-56130)
  • Offset: Remove the lock in RhinoOffsetCurve in V7 (RH-51839)
  • Rendering:
    • RenderWindow command is broken (RH-56227)
    • Render, Cycles and Material do not use windows system colors (RH-56238)
    • Raytraced mode constantly restarts (RH-56331)
    • PBR displacement doesn’t use applied texture mapping method (RH-56090)
    • Mapping doesn’t work for SubD (RH-56133)
    • Metal does not work on the back of double-sided (RH-56221)
  • SetDocumentUserText: UserText update (RH-56407)
  • SubD Editing: SlideEdge breaks SubD display toggle (RH-55557)
  • SubD Grips: Mistakenly locks SubD grips (RH-56299)
  • Sweep1: History update fails with pline and untrimmed miters (RH-56126)
  • TextField:
    • TextFields events need to recalculate on Layer rename (RH-55662)
    • Area does not work on sub-faces (RH-56439)
  • Toolbar: Extra ShowDir button (RH-56312)
  • UserText: TextField function refreshing was broken by addition of LayoutUserText (RH-56438)
Crashes Fixed:
  • Named Item drag and drop crash (Eto UI) (RH-54487)
  • Material Editor crashes (RH-56412)
Enhancements:
  • Display: Technical, Artistic and Pen modes support double precision display (RH-37333)
  • ExtractSrf: Added SubD support (RH-55789)
  • File IO: DGN import is updated to use OpenDesgin 20.8 (RH-56377)
  • Layout: Added Layout User Text to Layout viewport (RH-54346)
  • Make2D: Added SubD support (RH-56154)
  • NamedSelections: Save selection sets in 3dm (RH-50279)
  • OffsetMesh: Does FlipAll still make sense? (RH-56138)
  • Options: The Save command is added to the never repeat list (RH-56261)
  • Rendering: Histogram colors need tweaking (RH-55915)
  • TextField: New PointCoordinate function (RH-56140)
Features Added:
  • SubD: New command (RH-56132)
  • TextField: Remove "Page Contents" from Layout Properties and TextField (RH-55063)
Tasks Completed:
  • Mesh utilities for SubD: Port code from C# plug-in into RhinoCore as C++ (RH-51786)
UI Change:
  • Icons: Add to toolbar (RH-56153)
  • Panels: Add the panel icon (RH-55020)
  • TextField: Add "World" to PointCoordinate description (RH-56440)
  • Toolbar: LayerBook stop button icon (RH-56134)
Mac-Only Changes
Bugs Fixed:
  • Grasshopper: Components: Curve Explode fails on Nurbs curves (RH-55318)
  • ProjectOsnap: New "Project object snaps to CPIane in plan parallel views" option (RH-56275)
  • Rendering: Materials: Select material by typing first letter (RH-45084)
  • Textures: Rename does not work for Texture Proxies (RH-52793)
  • ToolPalettes: Change image background color in button editor (RH-56297)
  • Toolbar: Clean up Mesh Utilities (RH-56196)
Crashes Fixed:
  • Layout: Remove "Match" from Layout User Text on Mac (RH-56329)
  • Properties: Picking Render Properties Crashes Rhino (RH-55896)
Enhancements:
  • Insert: New "Prompt to scale on import" checkbox (RH-56352)
Features Added:
  • Eto: Custom tooltips or cursors for Eto Drag and Drop (RH-49821)
Bugs Fixed:
  • Context Menu: Lights do not count (RH-55513)
  • Delete: Delete key must be pressed twice (RH-55496)
  • History: May not turn off for one-shot (RH-56402)
  • Make2D: AggregateException: One or more errors occurred. (RH-53599)
  • Print: Print Units Not Sticking between sessions (RH-56373)
  • Rendering: Time discrepancy (RH-55703)
Enhancements:
  • History: Pane menu is not accessible while a command is running (RH-56396)
  • Insert: New "Prompt to scale on import" checkbox (RH-55936)
  • Layout: New "Combine Layout Tabs" item in the view tab context menu (RH-56338)
Features Added:
  • Layer: Disable delete key handler in layer manager list control (RH-56405)
UI Change:
  • Rendering: Materials: Make IOR list easy to discover on Windows (RH-55489)
Rhino WIP 7.0.20014 is now available for Windows and Mac!
Bugs Fixed:
  • BlendCrv: Jumps to another location when editing (RH-56417)
  • BlockEdit: BlockEdit linked-embedded block default (RH-52538)
  • Cylinder: Bounding Box option added to several commands by mistake? (RH-56449)
  • DevLoft: Ruling changes with density (RH-56473)
  • Display:
    • Drop Material on view - broken in rendered mode (RH-55965)
    • Shiny material becomes yellow in Rendered mode (RH-56465)
    • GetObjectAt causes display problems in layouts (RH-56478)
  • Eto: Eto Color Button Inaccuracy (RH-54529)
  • FitSrf: Cannot cancel (RH-56434)
  • MeshSplit: Despite edge×edge, this must split (RH-56101)
  • Properties: New Layouts object properties page has border (RH-54736)
  • Rendering:
    • Cycles render threads should be THREAD_PRIORITY_BELOW_NORMAL (RH-56019)
    • PEPs slow for Kyle, are they not executing on the GPU? (RH-56363)
  • Rendering: Materials: No way to invert the bump direction in the PBR UI (RH-55636)
  • Rendering: Texture Mapping: Surface mapping for SubD objects is not useful (RH-56335)
  • SDK: RhinoCommon: Intersect.MeshMesh function (RH-54662)
  • Sweep2: Refit rails at the command line (RH-56374)
  • TextField: Remove Page Content (RH-55860)
Crashes Fixed:
  • SDK: RhinoCommon: Object reference not set… ETO. (MERGE) (RH-48366)
Enhancements:
  • DupEdge:
    • Added History support (RH-56404)
    • No History recorded for SubD edges (RH-56441)
  • Layout: Detail caching boosts detail view drawing performance (RH-56503)
  • RhinoStart: Tune up RhinoScript material methods to be RDK compliant (RH-56284)
Features Added:
  • Display: Function needed to enable Rhino's OpenGL context (offscreen window) (RH-54815)
  • Viewports: Lock viewports (RH-1335)
Regressions Fixed:
  • Subobject Selection: Subobject Selection Filter issue in V7 (RH-55927)
UI Change:
Mac-Only Changes
Bugs Fixed:
  • Cycles: RhinoCycles does not appear to work in latest RhinoWIP for Mac (RH-56486)
  • Extend: Cursor tune up (RH-54684)
  • Interface: Match behavior with Windows (RH-54683)
  • NamedSelections: Crash when dragging an item (RH-55516)
  • RDK: PEP code asserts on Mac when creating a new material (RH-56418)
  • Rendering: Time discrepancy (RH-56339)
  • Textures: Texture thumbnails incorrect (RH-56155)
Enhancements:
  • Block: The dialog box for browsing missing linked block files displays the path and filename of the missing file (RH-55612)
Bugs Fixed:
Rhino WIP 7.0.20021 is now available for Windows and Mac
Bugs Fixed:
  • SubD to Brep - investigate and improve G1 continuity at extraordinary vertices. (RH-53274)
  • DupEdge: Curves with History from surface/mesh edges won't update (RH-56520)
  • QuadReMesh: QuadRemesh by edge length jumps from .1 to .001 crippling Rhino (RH-56456)
  • Rendering: Asynchronous baking for Cycles textures should be turned off for production rendering (RH-56507)
    • Bounding Box mapping for Sphere and Cylinder is broken (RH-56521)
    • WCS mapping fix is broken (RH-56522)
  • SplitMeshWithCurve: Needs double precision mesh before split (RH-56568)
Enhancements:
  • ExtrudeCrv: Ignore Planar for extruding (RH-56459)
  • Help: Dithering in Post effects (RH-56384)
  • OffsetMesh: OffsetMesh - New Preview option (RH-56581)
  • QuadReMesh: QuadRemesh - Transfer Material/ Mapping from input object to remeshed object (RH-56548)
  • SubD: DimArea, Area and Volume text fields support SubD (RH-56442)
  • UDT: New TargetSurface option that uses surface normal for object orientation (RH-56357)
Features Added:
  • NamedView: Remove "Lock named view" checkbox to reduce confusion (RH-56512)
  • Viewports: New command (RH-56223)
SDK Enhancement:
  • SDK: RhinoCommon: Add ToARGBArray for Mesh vertex colors (RH-56582)
UI Change:
Mac-Only Changes
Bugs Fixed:
  • Annotation: Hatch: Color Dialog fix for mac OS in gradient control creates endless color stops (RH-55481)
  • Interface: Cursor unstable (RH-56537)
Bugs Fixed:
Enhancements:
  • Grasshopper: Grasshopper About/Splash screen has a woefully old Copyright date… 2009 (RH-56489)
Rhino WIP 7.0.20028 is now available for Windows and Mac
Bugs Fixed:
  • SDK: Support VS2019 in Rhino 7 SDK (RH-56476)
  • SDK: RhinoCommon: LayerTable.Purge not working for parent layers (RH-55695)
  • SrfSeam: Remember the direction setting (RH-56625)
  • ToSubD: ToSubD selects polysurfaces (RH-54368)
  • UDT:
    • Made TargetSurface option pay attention to surface normal direction (RH-56566)
    • Flow, Gumball and pre-select (RH-56646)
Crashes Fixed:
  • File IO: Stack overflow in tl.TL_NGonFinder.FindFacesInNgons() during Export (RH-53697)
Enhancements:
  • SDK: RhinoCommon: Expose RhGetDrawListSerialNumbers (RH-56649)
  • TextObject: UI improvements for engraving fonts (RH-48090)
  • UserText: New "Paste key and value to all layouts" option (RH-55885)
Features Added:
  • MeshSplit: Ngon can be retained (will not be triangulated) (RH-53553)
  • RibbonOffset: create command line version of ribbon offset tool (RH-52990)
Tasks Completed:
  • Toolbar: SubD output for 3dFace (RH-55933)
Mac-Only Changes
Features Added:
Bugs Fixed:
  • MergeCrv: MergeCrv & high degree (RH-56591)
  • NamedView: Cancel renaming duplicates "(Locked)" (RH-56586)
  • Viewports: Listed as "Locked" in context menu (RH-56585)
Rhino WIP 7.0.20035 is now available for Windows and Mac
Bugs Fixed:
  • 3DFace: Cannot append from mesh edges (RH-56602)
  • Annotation: Linetype: Copies are always continuous (RH-56574)
  • CollapseMeshFace: CollapseMeshFace hangs when selecting an Ngon (RH-56609)
  • Curvature: Not working properly when the curvature maxima are at curve ends (RH-56657)
  • ExtendSrf: ExtendSrf fails (RH-55037)
  • RDK: Rhino Render Preview Request takes a long time. (RH-54960)
    • Shader driven WCS display needs to respect OCS mapping origin (RH-56517)
    • Baking of WCS textures needs to respect OCS origin (RH-56519)
Crashes Fixed:
  • RDKCrash: :FastMakeCopy – Access Denied (RH-56530)
Enhancements:
  • BlendSrf: The Edit option temporarily turns off History locking (RH-56232)
  • Block: Attributes Should Pre-Populate Key Values (RH-56653)
  • MatchMeshEdge: Skips prompts and options when meshes are preselected (RH-56699)
  • Mirror: New ZAxis option, and now uses CPlane axes instead of World axes (RH-55646)
Features Added:
  • File IO: Supports exporting group names and indexes (RH-56564)
  • TextField: New LayoutUserText function (RH-56337)
Regressions Fixed:
  • NamedPosition: Remember Named Positions (RH-56648)
UI Change:
  • SubD: SubD - Update descriptive notes for commands (RH-56540)
  • TextField: Update Note in "Layout User Text" Field dialog (RH-56627)
  • Toolbar: Add to toolbar (RH-56511)
Mac-Only Changes
Bugs Fixed:
  • Annotation: Hatch: Apply color change when Select Color dialog is closed (RH-55142)
  • NamedView: Cancel renaming duplicates "(Locked)" (RH-56733)
Crashes Fixed:
  • RDKCrash: RhinoWIP crashes on New Model on macOS High Sierra 10.13.6 (RH-56688)
Bugs Fixed:
  • Display: Decal makes object white in Rendered Mode (RH-56330)
  • SDK: Rhino 7 SDK creates plug-ins that reference the Rhino 6 SDK (RH-56663)
Rhino WIP 7.0.20042 is now available for Windows and Mac
Bugs Fixed:
  • Need a way to open a content in an editor (RH-56652)
  • Rendered mode ignores different OCS frames between objects (RH-56843)
  • Analysis:EdgeContinuity: Edge pairs are partly forgotten (RH-56864)
  • Block: Redefining Block With Attributes Gives Odd Result (RH-56659)
  • BlockEdit:
    • BlockEdit and hidden objects (RH-46745)
    • SubD objects vanish from edited blocks (RH-56744)
  • Bridge: Fails on SubD (RH-55084)
  • Cap: Splits surface with kink (RH-56463)
  • Cycles:
    • Shaders with emission don’t update properly (RH-45394)
    • ViewCaptureTo* commands may crash with Raytraced (RH-55421)
    • Support for >100 texture amounts in PBR material (RH-56562)
    • No repeat texture leaves a gap (RH-56694)
  • Display:
    • Dragging materials on objects that have PBR emission already assigned (RH-56561)
    • Fixed Rendered mode showing 360 degree environment stitch seam (RH-56605)
  • ExtendSrf: ExtendSrf not extending when entering a numeric value (RH-56188)
  • File IO:
  • Grasshopper: Components: Grasshopper Component QuadRemesh - Black mesh in Rendered display mode (RH-56824)
  • Lasso: Lasso selects clipped objects (RH-56668)
  • MeshIntersect:
    • Gappy mesh intersect (RH-49268)
    • MeshIntersect ‘ESC’ cancellation shows Bug dialog (RH-54842)
  • MeshSplit:
    • Double segments (RH-8803)
    • MeshSplit ‘ESC’ cancellation shows Bug dialog (RH-54651)
  • OffsetMesh: Added FlipAll back and changed Preview to DynamicPreview (RH-56743)
  • QuadReMesh: QuadRemesh cancel out when Preview is being calculated (RH-56107)
    • Double click behavior in Eto based numeric control (RH-55879)
    • PBR displacement doesn’t work in Raytraced mode (RH-56089)
    • Remove “Share materials” from Advanced options (RH-56240)
    • Drag arrow in TextStepper control feature (RH-56303)
    • Diner model takes a long time to load (RH-56410)
    • PBR control tune-up (RH-56428)
  • SDK: GHPython: Document RH-53391 (RH-53718)
  • SoftTransform: SoftTransform command line message should be more specific (RH-55506)
  • SubD: ON_SubDFace ON_BrepFace - Add MaterialChannelIndex property. Correct obsolete comments. (RH-56811)
  • Subobject Selection: Subobject picking doesn't work with Transparent Grid in Shaded mode (RH-56818)
  • TextField: Notes lose hard returns (RH-56706)
  • UDT: History may not update properly when target surface is used (RH-56784)
  • UnWeldEdge:
    • Creased edges in subd can’t be separated but can be on meshes (RH-53257)
    • Now separates control vertices on SubD (RH-54034)
Crashes Fixed:
  • Geometry Core: ntdll!RtlpFindAndCommitPages – (NTSTATUS) 0xc00000fd - A new guard page for the stack cannot be created. (RH-56891)
  • InsertPoint:
    • InsertPoint - Crashes Rhino on this model (RH-56436)
    • InsertPoint on SubD crash (RH-56551)
    • InsertPoint crashes on this SubD (RH-56730)
Enhancements:
  • BlockEdit: Allows to cancel if objects are hidden/locked in the editing (RH-46746)
  • Bridge: Greater bulge is required when straightness is set to 0 (RH-56274)
  • GumballAlignment: New Align to View option (RH-56414)
  • MatchSrf: History locking allows editing control points of matched surfaces (RH-56285)
  • NamedView: Made overwrite not possible when "Lock named view" is enabled (RH-32726)
  • OSnap: Allows Near on edge of plane when Cen is enabled (RH-56862)
  • OffsetSubD: OffsetSubD needs a Flip option (RH-56702)
  • Revolve: Ends of the revolving axis can be attached to objects using object snaps when History is recorded (RH-2868)
  • SubD Editing: Supports moving SubD control points (RH-56771)
  • Sweep1: Remember the refit setting between sessions (RH-55398)
  • TextField: New command (RH-56654)
Features Added:
  • ExtrudeMesh:
  • File IO: Attribute User Text and ACAD xData can be exchanged (RH-55484)
  • QuadReMesh: New QuadRemesher component (RH-54904)
  • SDK: RhinoCommon: New Mesh NGon C++ SDKs need to be wrapped in RhinoCommon (RH-40903)
Regressions Fixed:
  • ClippingPlane: CheckBox in Properties (RH-56696)
SDK Enhancement:
  • SDK: Supports converting Revit Hermite surface to NURBS (RH-55629)
  • SDK: RhinoCommon:
    • Wrap ON_HermiteSurface for RhinoCommon use (RH-56615)
    • Expose RhinoCleanUpPolyCurve to RhinoCommon (RH-56689)
Mac-Only Changes
Bugs Fixed:
  • Cycles: Raytrace initializes slowly (RH-56471)
  • DevLoft: DevLoft - SubCrv display persists (RH-49514)
  • Grasshopper: GradientHatch component, removed boundary in preview (RH-56901)
  • LoadPlugin: Removed plug-ins on Mac still appear in the plug-in manager (RH-56834)
  • Menu: Add SubD commands to the SubD menu (RH-56779)
  • MergeCrv: MergeCrv & high degree (RH-56656)
  • NamedView: "Restore Named View" missing in viewport title menu on Mac (RH-56468)
  • Orient3Pt: Orient3pt only translates one geometry (RH-56745)
  • Preferences: Add _ShowToolPalette to the Do Not Repeat list (RH-56726)
  • ToolPalettes: Floating Tool palettes Disappear (RH-56725)
Enhancements:
  • Grasshopper: Grasshopper About/Splash screen has a woefully old Copyright date… 2009 (RH-56595)
Features Added:
  • File IO: Added UseCompressionWhenSaving advanced settings (RH-34937)
  • Grasshopper: New Hatch component (RH-56623)
Bugs Fixed:
  • AutoSave: Pays attention to the "Save render mesh" option in Options > Files (RH-53781)
  • Eto:
    • ETO NumericStepper UI style (RH-56665)
    • Window.Closing and Window.Closed events not getting raised when calling Close() (RH-56750)
  • ExtrudeMesh: Using gumball extrude on mesh face creates a bad object (RH-56251)
  • Grasshopper: GradientHatch component, removed boundary in preview (RH-56747)
  • RDK: TextureProxy rename on thumb (RH-56734)
UI Change:
  • Menu: Add SubD commands to the SubD menu (RH-56700)
Rhino WIP 7.0.20049 for Windows and Mac is now available
Bugs Fixed:
  • Bevel: Bevel fails if creases are not kept (RH-56748)
  • BlendSrf: BlendSrf rail start points aren't maintained correctly (RH-56881)
  • CutPlane: CutPlane is short (RH-56956)
  • Display:
    • Raytraced display mode is slowed down by many lights (RH-56409)
    • Texture issues with blocks (RH-56514)
    • Slow text editing on layouts (RH-57041)
  • Eto: Eto numeric edit control behaves erratically (RH-56865)
  • Gumball: Extrusion removes face (RH-56671)
  • InsertPoint: InsertPoint makes holes (RH-56884)
  • Installer: Installer is missing source files for Cycles kernel compilation (RH-57069)
  • InterpCrvOnSrf: Loses smooth seam (RH-56938)
  • Mesh: Cannot set CapFaceStyle=Tri (RH-56969)
  • MeshSphere: Ugly quad caps (RH-56970)
    • “Plastic” with a bump setting produces bad results (RH-55972)
    • More usable SSS radius (RH-56460)
  • Rendering: Texture Mapping: Broken on SubD (RH-56523)
  • RotateView: Shift between parallel and perspective does not use default lens length (RH-56910)
  • SDK: RhinoBrepSplit with multiple curve cutters does nothing if a curve does not cut (RH-55570)
  • SplitEdge: Duplicates edges (RH-54577)
  • Trim: Trims too much (RH-4609)
  • UVEditor: Procedural textures preview black in Rendered view (RH-56736)
Enhancements:
  • Bevel: Bevel default segments seem too high (RH-56781)
  • Gumball: Remember zero (RH-56889)
  • InterpCrvOnSrf: Changed to not automatically record History (RH-56936)
  • OSnap: Snaps to polygon face center on polysurface (RH-56863)
  • NamedView: Thumbnail mode: Switching between views is slow (RH-56728)
Tasks Completed:
  • Thicken: Remove Thicken from Rhino 7 WIP (RH-44645)
UI Change:
  • Eto Named Items usability problem (RH-54488)
Mac-Only Changes
Bugs Fixed:
  • ExtrudeMesh: Using gumball extrude on mesh face creates a bad object (RH-56905)
  • Rendering: Materials: Tree view of materials isn't a tree (RH-55425)
  • SDK: RhinoCommon: New RhinoCommon class and command name does not match the filename (RH-56166)
  • Settings: Document User Text icon missing (RH-57014)
  • Sweep2: Remember the refit setting between sessions (RH-56961)
Bugs Fixed:
  • IOR control throws exception (RH-56425)
  • Properties: Icon display glitch in v7 (RH-56949)
  • Rendering: Materials: Fixed nothing found if there is a capital letter in the search string. (RH-56792)
Rhino WIP 7.0.20056 for Windows and Mac is now available
Bugs Fixed:
  • ClippingPlane: Views Clipped - Checkbox issue (RH-57036)
  • Cycles: PBR emission crashes when used as double-sided material entry in Raytraced viewport (RH-56967)
  • Display: transparent layer - objects blocks wires (RH-57164)
  • Eto: Splitter position reset when used on a TabPage in a TabControl (RH-54722)
  • Gumball:
  • NamedSelections: NamedSelections hang around after file new (RH-56983)
  • NamedView:
    • Saving named view sometimes copies the named view (RH-56911)
    • Buggy support for clipping planes (RH-57043)
  • Rendering:
    • Defaults for ‘logarithmic’ (RH-43122)
    • Eto PEP sections can’t be closed (RH-56324)
    • Eto PEP UI splitter position weirdness (RH-57080)
    • Post Effects - Selection Load/Save with the document (RH-57111)
  • Rendering: Materials: Metals look different in the WIP (RH-56992)
  • Rhino Inside: Rhino Render (ccycles.dll) fails to load in Rhino Inside Revit (RH-56927)
  • SlideEdge: SlideEdge should not allow verts to stack as it makes the command fail (RH-56260)
  • Splash and About: Splash screen no longer shows the "Recent" tab when Debug Rhino starts… (RH-45786)
  • Split: Option needed in Split to NOT use apparent intersections or projections… (RH-55574)
  • SubD:
    • Error of extruding SubD with Gumball (RH-53616)
    • Reflect: Made Undo not break automatic update (RH-57005)
  • SubD Editing:
Cosmetics:
  • BlockManager: Deleting a block deletes layer by layer (RH-57121)
Crashes Fixed:
  • Rendering: Realtime SDK: Rendering Realtime SDK: Crash in new OCS texture mapping when trying to use Grasshopper through ChangeQueue (RH-57042)
Enhancements:
  • Bevel: Bevel - Now works on SubDs in flat appearance (RH-55359)
  • Bridge: Works with pre-selected edge chains (RH-49850)
  • Help: ToSubD topic improvement (RH-56775)
  • TextField: AddMissingBlockAttributeKeys: Key is restored to both key and value fields (RH-57108)
Features Added:
  • TextField: AddMissingBlockAttributeKeys: New command (RH-56715)
SDK Enhancement:
  • SDK: RhinoCommon: SDK RhinoCommon: Added Draco compression support (RH-57044)
Tasks Completed:
  • Toolbar: ExtractControlPolygon: Added to SubD Sidebar (RH-56608)
UI Change:
  • Block: AddMissingBlockAttributeKeys: Add to menu (RH-56854)
  • ExtrudeMesh: Add to toolbar (RH-56909)
  • Toolbar: Bevel: Add to SubD Tools toolbar (RH-56672)
Mac-Only Changes
Bugs Fixed:
  • Panels: Added the "Layout and detail layer information" panel back to Rhino 7 WIP for Mac (RH-57134)
  • Snapshot: Snapshots command does not open the panel in Rhino 7 WIP for Mac (RH-57148)
Crashes Fixed:
  • RDKCrash: RDK: Crash when viewing Materials panel in macOS 10.13.6 (RH-57094)
  • Splash and About: Splash: Crash during initialization (RH-57074)
Bugs Fixed:
  • Installer: Windows Smartscreen warning message appears with every install. (RH-55729)
  • Panels: Properties is clipped and not drawing fully (RH-57000)
Enhancements:
  • Headless: Rhino Compute: Supports exporting SVG in headless mode (RH-57097)
13 posts were merged into an existing topic: What’s New for Rhino WIP is strange
Rhino WIP 7.0.20064 for Windows and Mac is now available
Bugs Fixed:
  • Bake: QuadRemeshing: Crashes Rhino in Rendered mode (RH-57001)
  • Bridge:
    • Make it work with face selections (RH-49917)
    • Doesn’t update the Reflect child side (RH-57003)
  • Display:
    • Supports layer and object transparency on meshes in Shaded mode (RH-57143)
    • Depth Sorting incorrect for Transparent Layers (RH-57217)
  • DupEdge: DupEdge from Extrusion doesn't support history (RH-57205)
  • ExtrudeMesh:
    • Bad default base point for SubD (RH-56965)
    • Restricts selection to mesh and SubD boundary edges (RH-56997)
  • ExtrudeSrf: ExtrudeSrf allows SubD selection but doesn't do anything (RH-57071)
  • FBX: FBX import - SubD creases are not added properly (RH-57242)
  • Gumball: Made SubD creases stay creased when extruded (RH-57006)
  • Helix: Radius control does not update (RH-39041)
  • Lasso: Region selection - Selecting pointcloud points pays attention to clipping planes (RH-57262)
  • MatchProperties: Right-clicking a checkbox may not clear all the others (RH-57141)
  • RDK: PBR Section sometimes changes scroll position if a texture is turned on or off. (RH-57019)
  • Reflect:
    • SubDivide doesn’t immediately update the child side (RH-57208)
    • Fill doesn’t update immediately when used with Reflect (RH-57214)
    • Rendering Materials: PBR Metallic undo doesn’t work properly (RH-56986)
    • Rendering Materials: Crash on creating from texture files (RH-57135)
  • SDK: RhinoMergeBreps is different from the NonmanifoldMerge command (RH-56919)
  • SlideEdge: Numeric input is delayed in command-line (RH-49890)
  • SmartTrack: SmartTrack and distance constraint (RH-57171)
  • Splash and About: Move profile image loading out of startup sequence (RH-51548)
  • Split: May not work on some objects (RH-30701)
  • SplitEdge: SplitMeshEdge: Freeze on SubD (RH-51710)
  • Stitch:
    • Display SubD in Flat mode to help picking SubD vertices (RH-54961)
    • Result is not valid (RH-56343)
  • SubD: Document a process for converting T-splines models to SubDs (RH-56897)
  • Surface-surface intersection: Surface intersecting: Memory leak (RH-53732)
  • Toolbar: EnterEnd: Fails to finish the command (RH-57107)
Crashes Fixed:
  • File IO: Export Command: rdk!CRhRdkContent::CImpl::RenderCRCRecursive – Access Denied(MERGE) (RH-57162)
  • Stitch:
    • Crashes on a model (RH-56952)
    • Stitch Command: RhinoCore!Mu7::StitchCommand::RunCommand – Access Denied (RH-57066)
Enhancements:
  • ArraySrf: New Mode=UV/Isocurve and Preview options (RH-57287)
  • FBX:
    • File IO 3DS/FBX: Added UI to FBX import dialog to choose between mesh and SubD objects (RH-56896)
    • 3DS/FBX Import: New :Open/Import meshes as SubD surfaces" option (RH-56978)
  • File IO: SVG Export - Supports exporting transparent objects (RH-57147)
  • MatchSrf: Remembers Perpendicular to target edge setting (RH-57153)
  • Reflect: Supports History (RH-55845)
Features Added:
  • DupBorder: Added History support (RH-56569)
  • Grasshopper: Help menu: Add link to Community Component Reference (RH-57040)
UI Change:
  • SubDivide: DeleteInput=Yes/No is removed (RH-57238)
Mac-Only Changes
Bugs Fixed:
  • Licensing: Single Computer: Licensing Single Computer: Circle and SubD primitives can't be created. (RH-57113)
  • Preferences: Display: Clipping plane objects color usage goes weird when you switch from Plane color to solid color (RH-57186)
  • RDKCrash: RDK: Crash while assigning picture material (RH-56457)
  • SelectionFilter:
    • Made “Others” works properly with decal widgets (RH-53517)
    • Needs to use ETO panel on Mac (RH-57160)
    • Selection Filter: Refresh the check boxes (RH-57211)
  • Snapshot: Import behavior incorrect (RH-57181)
Bugs Fixed:
  • Append: Select meshes to append to as the first step (RH-46310)
  • Color Picker:
  • Properties: Properties Panel - Flickers while mouse moves over icons (RH-57077)
  • PropertiesPage: Material Properties: Does not display ETO sections on Windows (RH-57224)
  • Toolbar: Inset icon tooltip needs 'SubD' added (RH-57178)
Rhino WIP 7.0.20071 for Windows and Mac is now available
Bugs Fixed:
  • 3DFace: Appending with Interpolated=Yes moves existing SubD edit points (RH-57275)
  • BlockManager: Changing Block def name should raise doc change events (RH-57114)
  • Cycles:
    • Unstable update with physically based materials (RH-55660)
    • Black renderings in DEBUG Rhino with GPU (RH-56785)
  • Display:
    • White centers of points should be transparent (RH-57290)
    • Transparent points occlude GH Preview (RH-57303)
  • Eto: Slider thinks everything is 0 to 100 (RH-57139)
  • GetPoint: SnapToMeshObject forbids picking points off selected meshes (RH-57370)
  • History: Editing grips turns off history locking (RH-57289)
  • InsertPoint:
    • Insert extra points on SubD (RH-56415)
    • Undo should not switch to Flat SubD (RH-57368)
  • Installer: Preparing Plug-ins for First Use (RH-56720)
  • Layout: Size may not update in Layouts panel (RH-54357)
  • OpenNURBS: ON_SumSurface copy constructor and operator= need work (RH-43931)
  • Options: Reset to defaults error with construction plane options (RH-57267)
  • Print: Can not preview the print (RH-57220)
  • QuadRemesh:
    • A particular mesh produces a blocky result (RH-56387)
    • Fails if mapping method is Box (RH-56589)
    • Should not allow sub-object selections (RH-57177)
    • QuadReMesh: Open source acknowledgements (RH-57299)
  • Rendering: Feather-setting for Fog in PEP needs more precision (RH-55641)
    • Rendering: Materials: PBR undo very slow (RH-57197)
    • Rendering: Materials: PBR material changes are too slow (RH-57198)
    • Rendering: Materials: Crash while adding texture to PBR material through GP settings floating panel (RH-57358)
  • SDK: RhinoCommon: SDK: RhinoCommon: Needs some kind of view modified event (RH-56556)
  • SelVisible: SubD objects are not selected (RH-57250)
  • Selection: Ghosted picks of mesh edges not working (RH-57293)
  • SlideEdge:
    • Slide: Does not clear the selected mesh (RH-50092)
    • Can’t Slide SubD edges when control points stack (RH-51819)
  • Split: works with this curve in perspective view… should it? (RH-46534)
  • Toolbar: Mouse-over hint rewording (RH-57257)
  • Trim: Failure (RH-56923)
Cosmetics:
  • Properties: Panel flickers when scrolling the Plug-ins list in Rhino Options (RH-56991)
Crashes Fixed:
  • SubD: Crash after double-clicking edge on big SubD (RH-57319)
Enhancements:
  • Annotation: Text: Annotation: Text: Single Stroke Fonts display better in Text/TextObject edit box (RH-50123)
  • QuadRemesh: Allow group selection when picking guide curves (RH-57173)
  • Selection: SelConnected works with SubD control points and edit points (RH-57316)
  • UDT: CageEdit - SubD can be captive object (RH-57176)
Features Added:
  • GetPoint: New SnapToMeshObject command (RH-52710)
  • SubDAppearance: New SubDDisplayToggle command (RH-55232)
Regressions Fixed:
  • Display: Front wires are transparent in Ghosted mode (RH-57295)
  • Explode: Missing layer material names when referenced blocks are exploded (RH-57046)
SDK Enhancement:
  • SubD: Add C++ SDK SubD tool to remove zero length edges (RH-57274)
Tasks Completed:
  • OpenNURBS: Document RDK functions in ONX_Model (RH-57280)
UI Change:
  • Toolbar:
    • Add ConvertTextToBlockAttribute command (RH-56822)
    • Add AddMissingBlockAttributeKeys command (RH-56855)
    • Add SubDDisplayToggle command (RH-57004)
Mac-Only Changes
Bugs Fixed:
  • Enable RH_WRITE_DEBUG_REG in -DebugLog (RH-57302)
  • Display: Color reduction in display modes doesn't stick (RH-56993)
  • Layout: Current indication (bold) does not stick (RH-54973)
  • Snapshot: Deleting Materials in Snapshot doesn't always update Snapshot (RH-56147)
UI Change:
  • Menu: Add missing items in viewport title menu on Mac (RH-57199)
Bugs Fixed:
  • Installer:
    • Rhino 6 loads some plug-ins from V7 WIP (RH-43707)
    • Rhino 7 SDK installs property sheets which still reference Rhino 6 registry keys (RH-50329)
  • Rendering: Missing render content (RH-50331)
Enhancements:
  • UI Cleanup: Resize ImportLayout dialog box (RH-57252)
UI Change:
  • Menu: Add SubDDisplayToggle command (RH-57354)
Rhino WIP 7.0.20077 for Windows and Mac is now available
Bugs Fixed:
  • Rdk_Globals_ShowColorPickerEx needs to allow custom color lists from .NET (RH-54674)
  • Cycles:
    • RenderWindow command has no effect (RH-54820)
    • RenderWindow is slower than Raytraced mode (RH-56791)
  • Export: File IO: Rhino Block Attributes Do Not Import into AutoCAD (RH-56673)
  • File IO: File saved with Arial shows Missing Font warning in Mac Rhino (RH-57343)
  • InsertEdge:
    • Can not select edge position (RH-56972)
    • Preview doesn’t work if an edge ring is selected (RH-57382)
  • InsertPoint:
  • NamedSelections:
    • Duplicate on panel resize (RH-57352)
    • Redo does not always bring back a previously deleted subobject (RH-57353)
  • Rendering: Fog Post Effect - Area flipped in Y (RH-57351)
  • Rendering: Materials: Rendering Materials: Metallic checkbox in PBR material doesn't work properly (RH-56987)
  • ShowCamera: F6 Camera widget is broken (RH-57369)
  • ToSubD: Mesh ngon with a hole is ignored (RH-41709)
Crashes Fixed:
  • Split: RhinoCore!CCommandSplit::RunCommand – Access Denied (RH-57155)
Enhancements:
  • BooleanDifference: BooleanDifference/BooleanSplit: Allows objects in block instances as cutters (RH-57350)
  • File IO: Supports reading Solidworks files up to version 2020 (RH-57386)
  • Inset: Preselect a mesh or SubD to inset every face of it (RH-57179)
  • Pull: Supports pulling points and curves onto SubD objects (RH-53322)
  • RDK: Find way to remove need for const_cast in realtime display mode code (RH-57371)
  • Reflect: New RemoveExistingSymmetry option (RH-57204)
  • Rendering: Post-Effects: Brightness/Contrast/HSL/Multiply on GPU (RH-57312)
  • Selection: Allows selecting a range of control points on a curve, surface, or SubD (RH-55928)
Features Added:
  • Intersect: New IntersectSelf command (RH-55474)
  • Cycles:
    • Render tile optimization: Don’t copy all buffer passes if they’re not needed (RH-57193)
    • Render tile optimization: Optimize get_pass_rect (RH-57194)
    • Render tile optimization: The Cycles pixel buffer is upside-down compared to the RenderWindow channels (RH-57195)
SDK Enhancement:
  • SDK: Add functions to remove fins from nonmanifold Breps (RH-57123)
UI Change:
  • Menu:
  • Toolbar: Add IntersectSelf command (RH-57023)
  • 3DFace: Made Append options sticky in current or between session(s) (RH-56619)
Mac-Only Changes
Bugs Fixed:
  • File IO: Revert on macOS shows Missing Font warning (RH-57342)
  • Layout:
    • Crash on Print After Layout Rearrange in Inspector (RH-55056)
    • Trouble Dragging (RH-56650)
  • No subsystem: Use latest PanelingTools source for MacRhino (RH-54746)
  • SelectionFilter:
    • Should not reset when a second panel is opened on Mac (RH-57334)
    • Status bar button does not reflect current enabled state (RH-57393)
  • Snapshot: Imported snapshot has all options enabled (RH-57180)
Tasks Completed:
  • Toolbar: Add icons for new selection filter commands (RH-57306)
UI Change:
  • Toolbar: Inset icon tooltip needs 'SubD' added (RH-57305)
Bugs Fixed:
  • MoveFace: Selection highlight issue (RH-49503)
  • PluginManager: Remove Rhino 6 Plug-in Update dialog from Rhino 7 (RH-54690)
  • Snapshot: Imported snapshot has all options enabled (RH-56036)
  • Toolbar: SoftTransform RMB macro is not in SubD side bar (RH-57237)
Enhancements:
  • Layer: Sorting by column header can be undone (RH-31839)
  • Panels: Added Move up and Move down buttons to Named Views, CPlanes, and Positions panels (RH-56213)
Rhino WIP 7.0.20084 for Windows and Mac is now available
Bugs Fixed:
  • Annotation: Message is confusing when fonts are not found (RH-57296)
  • Annotation: Hatch: Annotation Hatch: Deleting gradient color stops does not work correctly on hatch creation (RH-56724)
  • Cycles: Raytraced mode doesn't render edges (RH-57448)
  • Display:
    • Support for >100 texture amounts in PBR material (RH-56563)
    • Glitchy output when advanced GPU lighting and shadows are disabled (RH-57449)
  • Rendering: Dithering PEP is visible and enabled by default. The actual dithering method is None. This is confusing. (RH-57419)
  • Rendering: Texture Mapping: Rendering: Texture Mapping: OCS mapping is broken (RH-57297)
Enhancements:
  • AlignMeshVertices: Supports SubD (RH-57183)
  • Annotation: Prompts a warning when opening a model using a font that is missing on the current system (RH-57485)
  • Copy: InPlace is transforming (RH-57446)
SDK Enhancement:
  • OpenNURBS: New functions for accessing RDK embedded images (RH-57318)
Tasks Completed:
  • Help: Describe what happens when a font is missing (RH-57292)
  • Keyboard Shortcuts: Investigate ability to make TAB a configurable Rhino "hot-key" (RH-55227)
Mac-Only Changes
Bugs Fixed:
  • RDK: Floating Preview: odd dummy document (RH-52994)
Enhancements:
  • Rendering: Materials: Rendering: Materials: Paste & import options for materials (RH-56424)
Bugs Fixed:
  • TextField: Combination of 2 Area() fails (RH-57356)
Tasks Completed:
  • Keyboard Shortcuts: SubDDisplayToggle is removed from F4 (RH-57526)
Rhino WIP 7.0.20091 for Windows and Mac is now available
Bugs Fixed:
  • Align: Fails on groups (RH-57564)
  • Annotation: Text: Text command: Dialog opens with edit box collapsed in new installs (RH-57602)
  • Choose One Object: Selection menu popping up with redundant items by reverting (RH-57504)
  • Display: PBR scattering in Rendered view (RH-56723)
  • Eto: Made Delete key works properly in Material Editor (RH-56246)
  • ExtractRenderMesh: Render mesh has naked edges while Polysrf does not (RH-57473)
  • File IO: Disable group radios in OBJ export if a user has selected objects as groups (RH-57611)
  • PackageManager:
    • If installed package is not found on the server, it should not say “update available” (RH-57182)
    • Pre-release checkbox has no effect (RH-57201)
  • Project: Add SubD to the command prompt (RH-57632)
  • RDK: The render window buffer draws RGB/A in grayscale after viewing distance channel (RH-57556)
  • Rendering: Disable Post Effect UI when required channel is not available (RH-57478)
  • Rendering: Materials: Rendering Materials: PEP ASSERTs fire when using RDP (RH-57017)
  • SDK: RhinoCommon: Wish: Set display mode background fill mode, colors, etc. from RhinoCommon. (RH-55138)
  • SplitRefit: Re-enable some disabled Mummy test commands (RH-57435)
  • SubDLoft:
    • Changed PointCount to SegmentCount (RH-57542)
    • Shape point count doesn’t update correctly (RH-57544)
  • Subobject Selection: Subobject selection: Made mesh subobject selection pay attention to clipping planes (RH-57506)
  • ToSubD: Fails on untrimmed NURBS surfaces with singularities (RH-53261)
  • Viewports: Black Viewports depending on docked dialogs (RH-57493)
Crashes Fixed:
  • PT_SDK!DupBorder – Access Denied (RH-56946)
  • Eto: PackageManager: Crashes Rhino WIP (RH-57617)
  • NamedView: File IO: Crash by canceling file import when Named Views panel visible (RH-57561)
Enhancements:
  • Align: New ToCurve, ToLine, and ToPlane options (RH-57300)
  • OrientOnCrv: New Flip option (RH-57534)
  • Project: Added SubD support (RH-57570)
  • Select: The Select command respects the state of subobjects in Selection Filter (RH-57481)
  • SelectionFilter: Surfaces/Faces sub-object filter works with mesh ngons (RH-57527)
  • UDT: FlowAlongSrf: Flowing object grips supports History (RH-57432)
UI Change:
  • Menu: Rename ExtrudeMesh menu item according to RH-56997 (RH-57496)
  • Toolbar: "Copy In Place" added to the Transform toolbar (RH-57536)
Mac-Only Changes
Bugs Fixed:
  • Localization: Portuguese xml is not being updated (RH-57615)
  • TextField: Suppress smart quotation marks on Mac (RH-55677)
  • Viewports: CloseViewport on Mac appears to fail for layout (RH-57488)
Enhancements:
  • SelectionFilter: Mac needs to uncheck all object types on right click (RH-57422)
UI Change:
  • Toolbar: Added SubD Tools and SubD Sidebar (RH-57307)
Bugs Fixed:
  • ApplyDisplacement: Displacement mesh modifier does not obey OCS frame (RH-56971)
  • Eto: Windows UI - Custom Material tune-up (RH-56426)
Enhancements:
  • Grasshopper: Better tolerance for Join component (RH-57512)
  • Keyboard Shortcuts: Tab key is made configurable (RH-57554)
UI Change:
  • Toolbar: Added SubD Tools and SubD Sidebar (RH-56039)
Rhino WIP 7.0.20098 for Windows and Mac is now available
Bugs Fixed:
  • Color Picker:
    • New Eto base color dialog observations (RH-57603)
    • Rhino loses focus after color picker (RH-57679)
  • Grasshopper: Components: Grasshopper: Components: Simple Mesh component previews black in Rendered mode and dark in Shaded (RH-56894)
  • RDK: Custom material texture on/off undo does not work. (RH-57372)
  • SubDLoft:
    • AdjustSegmentCounts stops working when repeatedly used (Add to mac project) (RH-57427)
    • SubDCorners should add corners only at start and end sections (RH-57676)
Crashes Fixed:
  • SDK: RhinoCommon: RhinoOffsetCurve: Repeatable crash (RH-57706)
Enhancements:
  • Analysis:EdgeContinuity: EdgeContinuity: Added relative curvature deviation display (RH-56873)
  • CPlane: Object option does not work with SubDs (RH-57637)
  • SubD: SubDLoft: Added SubDCorners and SubDCreases options (RH-53964)
  • SubDLoft: DivisionsAcross option allows overriding division count in curve direction (RH-57429)
  • ToSubD: New UseSurfaces=Location/ControlPoints option and so on (RH-53118)
Features Added:
  • Annotation: Report when font has been substituted (RH-22880)
  • Grasshopper: Components: Grasshopper: Components: Expression Grasshopper Slider (RH-55925)
  • SelectionFilter: New SelectionFilterEdges, SelectionFilterFaces, SelectionFilterVertices, SelectionFilterNone commands (RH-54247)
  • SubDLoft: Tuneups (RH-57366)
Tasks Completed:
  • Annotation: Hatch: Annotation: Hatch: Clean up and optimize hatch panel view model code (RH-57376)
Mac-Only Changes
Bugs Fixed:
  • Grasshopper:
    • Rhino for Mac Crash on Revert (RH-57630)
    • Crash Mac Rhino when changing monitors (RH-57636)
  • Layout: Remove Display Modes From Layout Menu on Mac (RH-57445)
  • SelectionFilter:
    • New SelectionFilterEdges, SelectionFilterFaces, SelectionFilterVertices, SelectionFilterNone commands (RH-56813)
    • Popup too wide (RH-57598)
  • Sweep1: Clang warnings in sweep (RH-57387)
Crashes Fixed:
  • Rendering: Materials: UI: PBR material "create from texture files" crash (RH-57672)
Enhancements:
  • Preferences: Made Rhino for Windows theme the default (RH-55460)
Features Added:
  • SelectionFilter: Supported on Mac (RH-36532)
Bugs Fixed:
  • Annotation: Text: Annotation: Text: Arial Narrow doesn't work correctly with the Eto text control (RH-57145)
  • Textures: Texture Mapping > Mapping text gets cut off (RH-57508)
Crashes Fixed:
  • Rendering: Materials: UI: PBR material "create from texture files" crash (RH-57669)
Enhancements:
  • Installer: GH file association (RH-57590)
Tasks Completed:
  • Toolbar: Add icons for new selection filter commands (RH-56808)
Rhino WIP 7.0.20105 for Windows and Mac is now available
Bugs Fixed:
  • RDK: We need a Normal XYZ wrapper channel (RH-57270)
  • Code Editor: C#: Code Editor C#: Writing a function crashes Rhino (RH-57741)
  • DraftAngleAnalysis: Draft curve results for this model are not desirable. (RH-56467)
  • Eto: Eto UI: Made Delete key work properly in Material Editor (RH-56246)
  • Grasshopper: Components: Grasshopper: Polygon Edge component has Error in mouseover tooltips (RH-57593)
  • Installer: Remove OptionsManager.rhp from installer (RH-57604)
  • Layout: Double-clicking in editable GridView begins editing (RH-57720)
  • Loft: Creases missing in Loft to SubD (RH-51391)
  • MeshIntersect: Should provide correct result for this case (RH-57464)
  • Offset:
  • Pull: Changed back to not supporting whole polysurfaces or SubDs (RH-53322)
  • QuadRemesh: Makes gaps if used on polysrf versus mesh (RH-57472)
  • RDK:
    • Attempt plug-in load when loading file with custom material (RH-42856)
    • Preview pipeline uses ActiveDoc (RH-45059)
    • RenderWindow channel SDK breakage (RH-57751)
  • Rendering: Materials: Rendering Materials: Asynchronous rendered previews do not appear after 8th April 2020 (RH-57821)
  • RibbonOffset:
    • Incorrect with some pick points (RH-57718)
    • Depends on pick point location (RH-57840)
  • SDK: RhinoCommon:
    • SDK RhinoCommon: RhinoGetTightBoundingBox() SDK function not wrapped for RhinoCommon (RH-30819)
    • SDK RhinoCommon: Intersection.RayShoot should return Brep face(s) that were hit (RH-57098)
  • SelectionFilter: Active selection gets cleared when toggling off selection filters (RH-57784)
  • SubD: Add ON_SubD::ComponentStatusSerialNumber() to detect when component status (hidden, locked, highlighted) has changed. (RH-57815)
  • SubDLoft: Increasing DivisionsAcross does not change the shape (RH-57675)
  • TextField:
    • Attribute Text Function Dialog > Document Text string not always applied (RH-57728)
    • Convert lcase functions so that they parse correctly (RH-57756)
  • Textures: Texture: Incomplete preview (RH-57817)
Crashes Fixed:
  • ExtrudeCrv: opennurbs!ON_ClassArray<ON_MaterialRef>::Count – Access Denied (RH-57758)
Enhancements:
  • Align: Supports sub-selected SubD vertices (RH-57530)
  • Display: Allow for more aggressive skylight shadow resolution degrading through advanced options (RH-57804)
  • ExportOptions: Does not export "Never repeat these commands" list (RH-51411)
  • SDK: GHPython: SDK GHPython: Add utility functions to show messages on Grasshopper python components (RH-57039)
  • SubDLoft: "Adjust Seam" step is renamed "Adjust edge loop position" (RH-57678)
  • SystemInfo: Plug-ins shipped and not shipped with Rhino are listed in two groups (RH-57608)
Features Added:
  • Offset: New Corner=None and Trim=Yes/No options (RH-42854)
  • SubDLoft: New command (RH-57232)
  • TextField: Add Layout User Text for Title Block Specific Information (RH-55876)
Meta Issue:
  • PackageManager: Platform-specific (w.r.t. OS and Rhino version) package versions (RH-52382)
SDK Enhancement:
  • SDK: RhinoCommon:
    • SDK RhinoCommon: Added Curve.Offset override that allows loose offset and end cap (RH-57413)
    • SDK RhinoCommon: Expose rail sweep frame calculators (RH-57699)
  • SubD: Add per face color properties to ON_BrepFace and ON_SubDFace (RH-57661)
Tasks Completed:
  • Menu: Change Slide command to Slide Edge in menus (reverted to Slide) (RH-52420)
  • Rendering:
    • In-viewport post effects are only implemented for the RhinoCommon case. (RH-57384)
    • Create a denoiser PEP using NVIDIA’s OptiX SDK (RH-57707)
UI Change:
  • Menu: Add SubDLoft command (RH-54920)
  • SubDLoft: SubDloft: Made the SnapToKnots option default to No (RH-57677)
  • Toolbar:
  • SystemInfo: Remove user data (RH-57607)
Mac-Only Changes
Bugs Fixed:
  • Annotation: DimAngular: Annotation DimAngular: DegreeMinutesSeconds ignored (RH-57765)
  • Grasshopper:
    • GrasshopperPlayer doesn’t support Undo (RH-57772)
    • GrasshopperPlayer single input doesn’t move on after one selection (RH-57773)
  • InsertEdge: fails when multiple documents are open (RH-57708)
  • Rendering: Materials: Rendering Materials: Navigation is too slow on Mac… compared to Windows (RH-56937)
  • TextField: Combination of 2 Area() fails (RH-57532)
  • UserText: Attribute User Text Functions: UI Issue (RH-57755)
Crashes Fixed:
  • RDKCrash: RhinoWIP fails to launch with segmentation fault caused by System.EntryPointNotFoundException: Rdk_CRdkCmnEarlyPostEffectPlugIn_SetCallbacks (RH-57808)
UI Change:
  • SelectionFilter: Added to top bar as a popup list (RH-57261)
Bugs Fixed:
  • Drag and Drop: ETO Dragdrop to viewport does not work on the Windows (RH-57559)
  • Grasshopper:
    • GrasshopperPlayer single input doesn’t move on after one selection (RH-57713)
    • GrasshopperPlayer doesn’t support Undo (RH-57715)
UI Change:
  • Grasshopper: Rename contextual inputs (RH-57828)
