brian
(Brian Gillespie)
21
Rhino WIP for Windows 7.0.19024 is now available
Enhancements:
- Bevel: Remember the loop selection option (RH-49799)
- Revert: Add Confirmation Dialog to Revert (RH-50120)
- SubD: Double-click SubD edge loop selection does not work with post-selection (RH-50413)
brian
(Brian Gillespie)
22
Rhino WIP for Windows 7.0.19031 is now available
Bugs Fixed:
- OSnap: Vertex and Mid support SubD edges (RH-50105)
- SplitEdge: Edge picking unreliable (RH-50141)
- Toolbar: Icons don’t stick (RH-50393)
brian
(Brian Gillespie)
23
Rhino WIP for Windows 7.0.19036 is now available
Bugs Fixed:
- GetObject: SelFaceLoop and SelEdgeLoop incorrectly select occluded items… and shouldn’t (RH-49934)
- Nudge: Along Control Polygons may not work correctly (RH-50621)
Enhancements:
- Annotation: Text: Long Text Field string can be wrapped (RH-43510)
- Nudge: New option - Use Control Polygon (RH-46147)
Features Added:
- Grasshopper: Grasshopper load diagnostics. (RH-48581)
brian
(Brian Gillespie)
24
Rhino WIP for Windows 7.0.19043 is now available
Bugs Fixed:
- File IO:
- Layers. Groups and OBJ (RH-46452)
- Remove mesh parameter ambiguity from STL export (RH-47205)
- Grasshopper:
- Ctrl+Tab index out of range exception. (RH-45530)
- Install missing GH components dialog is incessant (RH-50418)
- UI blanked out after plugin load fail. (RH-47753)
- Project: Should reject selecting SubD edges (RH-50613)
- Pull: Should reject selecting SubD edges (RH-50612)
- SelEdgeLoop: Does not support Selection Menu (RH-50003)
- Slide: Stuck after selection menu appears (RH-50345)
- Stitch: Fails on closed edge chains (RH-50064)
- SubD: ToSubD - add support for converting NURBS surfaces to SubD objects (RH-50287)
- ToNURBS: New command in Rhino 7 (RH-31262)
Enhancements:
- Curve: Added the new SubDFriendly option (RH-50524)
- DupBorder: Should work in SubDs (RH-49607)
- DupEdge:
- Double-click does not deselect an edge loop (RH-50646)
- Make double-click selecting a SubD edge loop (RH-50585)
- Grasshopper: Invert scroll zoom if Rhino is inverted. (RH-50189)
- OSnap: SubD and Near osnap support (RH-50556)
- SubD: ToSubD - When the input is not a SubD friendly NURBS surface, add extra rows of SubD faces to get a closer match (RH-50531)
- What: What - have it report when a NURBS curve or NURBS surface is SubD friendly (RH-50591)
brian
(Brian Gillespie)
25
Rhino WIP for Windows 7.0.19050 is now available
Bugs Fixed:
- Selection: Wires and control points behind shaded objects not pickable in X-Ray (RH-50602)
Cosmetics:
Enhancements:
- Bend: UDT Bend - make it work on SubD objects (RH-50544)
- UDT:
- UDT Stretch- make it work on SubD objects (RH-50547)
- UDT Twist- make it work on SubD objects (RH-50545)
Performance Problem:
- SelEdgeLoop: Slow on big meshes (RH-49984)
Regression:
- Selection: Very hard to select through a locked object (RH-50727)
SDK Enhancement:
- RDK: :MainEditorController() doesn’t make sense on the Mac (RH-50579)
brian
(Brian Gillespie)
26
Rhino WIP for Windows 7.0.19064 is now available
Bugs Fixed:
- Append: Snapping to retopology object points should be controlled by osnap settings (RH-46798)
- BlendSrf: BlendSrf - Made SubD edges not selectable (RH-50853)
- ExtractWireframe: ExtractWireframe - SubD wireframe bugs fixed. (RH-51021)
- Grasshopper:
- Grasshopper - Custom Preview does not disappear when editor is closed (RH-51116)
- Number parsing failure (RH-51115)
- Path mapper doesn’t accept as index brackets. (RH-51121)
- Referenced geometry in generic parameter isn’t loaded. (RH-51124)
- Relay DisplayName not visible from Disconnect menu. (RH-50863)
- Help: F1 does not open Mesh Utility topics (RH-51088)
- Properties: Enable ETO Hatch Object Properties page 7.x branch (RH-51178)
- RDK: Content UI stores content pointers and is at risk of crashing (RH-50856)
- Selection: Named Selection Sets need Gumball support (RH-50278)
- Snapshot: Plug-in works by mistake (RH-44658)
- SubD:
- Command line feedback on SubD edge double-click (RH-50276)
- TestSubDSplitEdge fails (RH-50783)
- SubD Editing: Undo after ToNurbs deletes subd (RH-51077)
- SubDFromMesh:
- Add the ability for the ToSubD command convert extrusions, revoultions, surfaces into SubD objects in the most obvious way (RH-49979)
- Unexpected subd from ngon mesh (RH-49795)
- Toolbar: Tooltip on Untrim Holes (RH-50834)
- Undo: Does not work with SubD objects (RH-51089)
Cosmetics:
- Grasshopper: Eval length warning message is wrong (RH-50864)
Crashes Fixed:
- ToNURBS: On mesh sub-object edges causes crash (RH-51167)
Enhancements:
- DupBorder: DupBorder - SubD border bugs fixed so command works when entire SubD is selected. (RH-51059)
- DupEdge: Should work on SubD edges (RH-49506)
- Grasshopper:
- Attribute message labels are unclickable. (RH-51125)
- GH point preview size must be adjustable. (RH-51120)
- Grasshopper: Components: Data Output missing nickname. (RH-51122)
- History: Updated BlendSrf Edge does not match the original edge (RH-50643)
- SelFaceLoop: SubD support (RH-49864)
- SubD: Double click SubD edge to select chain of edges (RH-50137)
- Subobject Selection:
- Ctrl+Shift+Double-Click does not deselect an entire edge loop (RH-51075)
- Double-click to select an edge or a face loop for Meshes (RH-50614)
- Select SubD Face Loops by double click (RH-50561)
- ToNURBS:
- ToNURBS - support SubD edges to nurbs curves (RH-51068)
- ToNURBS and DupEdge - bad fits at extraordinary vertices (RH-50522)
- ToNURBS and DupEdge - bad fits when open curve begins/ends at interior vertex (RH-50523)
- UDT: UDT Taper - make it work on SubD objects (RH-50546)
Features Added:
- Append:
- Bevel:
- InsertEdge:
- Loft: Added SubD to the Style list (RH-50530)
- SelEdgeLoop: New command (RH-51109)
- SelEdgeRing: New command (RH-45615)
- SelFaceLoop: New command (RH-46404)
- ToNURBS: ToNURBS - add support for converting sets of SubD edges into NURBS curves (RH-50491)
- Select: Dense SubD selection is delayed (RH-50631)
Usability Problems Fixed:
- Append: Weld angle should be 180 degrees by default (RH-47664)
brian
(Brian Gillespie)
27
Rhino WIP for Windows 7.0.19071 is now available
Bugs Fixed:
- ExtrudeCrv: Non-planar curves cannot extrude to SubDs (RH-51273)
- Properties: Hatch properties page does not update pattern rotation and scale per selection (RH-51209)
- Subobject Selection: Edge and face loop counting issues (RH-51247)
Cosmetics:
- Menu: SubD menu before Solids (RH-51234)
Features Added:
- Grasshopper: Add Plural to Term (RH-51276)
- Grasshopper: Help editor field “Author” (RH-51253)
brian
(Brian Gillespie)
28
Rhino WIP for Windows 7.0.19078 is now available
Bugs Fixed:
- ExtrudeCrv: Output=SubDs/Surfaces inconsistent (RH-51354)
- Grasshopper: Text to boolean conversion needs to be better. (RH-51126)
- Grasshopper: Components: MeshBox has naked edges which cannot be welded. (RH-51118)
- Gumball: No preview on subobject mesh GB transform (move) (RH-51219)
- RDK: Drag and drop target needs more information about the source (RH-50776)
- Ribbon: Sweep 2 add slash fails to create correct surface if between first 2 slashes. (RH-51283)
Enhancements:
- Grasshopper: Components: Text Format error messages are obscure. (RH-51123)
Features Added:
- Grasshopper: Add formatting controls (RH-51162)
brian
(Brian Gillespie)
29
Rhino WIP for Windows 7.0.19085 is now available.
Bugs Fixed:
- Annotation: Hatch: Add gradient data to ON_Hatch (RH-50188)
- File IO: PDF import wrong text orientation (RH-50745)
- Multiplication integer overflow error (RH-51444)
- Straight loft broke in R7. (RH-51119)
- Licensing: Cloud Zoo: The variable ‘e’ is declared but never used warning building Rhino.sln (RH-51482)
- SDK: RhinoCommon: Remove Rhino.Geometry.SubDLimitMesh (RH-51528)
Enhancements:
SDK Enhancements:
- File IO: Extract PLY writing code from the plugin and add to RhinoCommon FileIO. (RH-45733)
brian
(Brian Gillespie)
30
Rhino WIP for Windows 7.0.19092 is now available
Bugs Fixed:
- Can’t edit location and color of a Stop (RH-51565)
- RemoveGradient doesn’t work (RH-51566)
- Build Process: Rhino3dmIO: ‘LimitSurfaceCenterPoint’: is not a member of ‘ON_SubDFace’ (RH-51546)
- LayerStateManager: Update the selected layer state to the current layer status functionality missing (RH-51654)
Enhancements:
- SDK: RhinoCommon: RhinoApp.ParseTextField should return the same results as HostUtils.ParseFieldExpression (RH-51520)
Features Added:
- Annotation: Hatch: Gradient hatch (RH-15560)
brian
(Brian Gillespie)
31
Rhino WIP for Windows 7.0.19099 is now available
Bugs Fixed:
- Annotation: DimLinear: DimLinear - No history update on ‘object’ mode. (RH-51290)
- Curve: SubDFriendly option regardless of degree (RH-51708)
- History: Dims on Layout do not follow object (RH-51582)
- Loft: No preview for SubD output (RH-51664)
- Mesh:
- OSnap:AlongLine: AlongLine - Suspend the current command more completely (RH-51644)
- Rendering: Materials: ON_PhysicallyBasedMaterial::Supported() returns false in display code (RH-51790)
- SDK: RhinoOffsetCurve should not use the active doc (RH-51687)
- Select: Prepick and Postpick return different results when Mesh Ngon is selected (RH-51635)
- Selection:
- Can’t select more than one named selection (RH-51734)
- Create Named Selections ETO dialog for Windows and Mac (RH-51458)
- SubD: Bug in making SUbD friendly (SDF) curves with a specific point count (RH-51686)
- Subobject Selection: Copy-Paste of Sub-Object selected group elements does not work (RH-51675)
- ToSubD: Supports non-manifold mesh edges (RH-49843)
Crashes Fixed:
- DupEdge: SubD lock up (RH-51702)
- MeshIntersect: MeshMeshAccurate crashes Rhino (RH-51609)
Enhancements:
- FilletEdge: Tune up handle size to match DistanceFromEdge (RH-51637)
- Mesh: Inset- draw the new edges in the preview (RH-51640)
- Mesh utilities for SubD: Keep inset faces selected after Inset (RH-51460)
- Selection: Named Selections should auto-name in prompt (RH-51725)
- IncrementalSave: Incremental save to older Rhino version wants to overwrite existing file (RH-51717)
brian
(Brian Gillespie)
32
Rhino WIP for Windows 7.0.19106 is now available
Bugs Fixed:
- ExportOptions: Rhino 7 should use new OptionsExport and OptionsImport commands (RH-51802)
- History: Dims on Layout do not follow object (RH-51720)
- Join:
- Join doesn’t work on subd surfaces (RH-51555)
- Joining subd surfaces is unpredictable and can cause ‘dimples’ (RH-51817)
- Enable new RhinoCommon/Eto based LayerStateManager panel (RH-51552)
- Layer State Manager doesn’t have check boxes like the Windows Rhino version (RH-51649)
- Mesh: Inset is busted (RH-51989)
- Offset: Memory leak (RH-51736)
- Select:
- Chain option in GetObject doesn’t work in Length command with SubD edges. (RH-51855)
- Make SelChain and the Chain hidden option in GetObject both run the same code (RH-51828)
Cosmetics:
- Layer: Layer panel header sort arrows nether theme drawn or dpi aware (RH-52024)
Crashes Fixed:
- Select:
- Crash selecting mesh edges with Chain option or nested SelChain (RH-51852)
- Selecting curves and picking SubD edges in Length causes crash (RH-51856)
Enhancements:
- Dir: Dir command - make it work on SubD objects (RH-51556)
- LayerStateManager: Remember states across sessions (RH-51652)
Features Added:
UI Change:
- Join: Add Join to SubD menu (RH-51820)
- SubD:
- Add to menu for Crease - New command (RH-51862)
- Add to menu for RemoveCrease - New command (RH-51859)
brian
(Brian Gillespie)
33
Rhino WIP for Windows 7.0.19114 is now available
Bugs Fixed:
- Annotation: Hatch: Pattern rotation input box doesn’t accept negative values in Properties panel (RH-51697)
- Crease:
- Confusion between creasing a SubD edge and a control net edge (RH-52170)
- Control polygon edge selection issue (RH-52125)
- DupBorder: Does not work with with a proper subset of faces of a SubD (like it does with ordinary mesh objects). (RH-50600)
- ExtrudeCrv: ExtrudeCrv to SubD does not fit a subd friendly curve (RH-51665)
- File IO:
- Import_LWO should create RDK materials (RH-51770)
- Import_SKP should create RDK materials (RH-51767)
- Import_VRML should create RDK materials (RH-51771)
- GetObject: Verify that Chain hidden option works (RH-51774)
- Join: Does not keep the direction of the first BREP (RH-52066)
- Loft: Won’t Loft to SubD (RH-51994)
- No Subsystem:
- Import_3MF should create RDK materials (RH-51768)
- Import_FBX should create RDK materials (RH-51769)
- PointDeviation: Print info on demand (RH-52056)
- SDK: RhinoOffsetCurve should not use gslib (RH-51688)
- SDK: RhinoScript: RhinoScript commands do not create proper RDK materials (RH-51740)
- Select: Change Sweep1, Sweep2, Pipe and BlendSrf to all use a modified version of CRhinoSweepUtil::SelectRails() (RH-51842)
- Selection: SubD control polygon edge selection not working correctly (RH-52156)
- SubD Editing: Joining SubD surfaces doesn’t unify normals (RH-51816)
- WeldEdge: WeldEdge locks up Rhino on this joined subd (RH-51818)
Enhancements:
- Crease: Crease command - add support for vertex picking (RH-51871)
- DupBorder: Make it work on SubD subobjects (like it does on meshes) (RH-51193)
- File IO:
- Support SubD objects in IGES export (RH-50426)
- Support SubD objects in STEP export (RH-50427)
- Flip: Flip command - make it work on SubD objects (RH-51557)
- RemoveCrease: RemoveCrease command - add support for picking vertices as input. (RH-51872)
- SDK: RhinoCommon: Rhino.Geometry.Mesh.CreateFromCylinder needs Solid option (RH-52099)
Features Added:
- RemoveCrease:
- Cannot select edges and vertices (RH-52195)
- RemoveCrease - New command (RH-51232)
- Selection: Ring select SubD/mesh edges (RH-51340)
- Slide:
SDK Enhancement:
- SDK: RhinoCommon:
- Export SLC format support in RhinoCommon (RH-52073)
- Export STP format support in RhinoCommon (RH-52074)
Tasks Completed:
- Menu: Remove “Crease” and “Remove Crease” from the Mesh menu (RH-52087)
UI Changes:
- Menu:
- Add to menu for Slide command (RH-51594)
- Add to menu for SubDBox command (RH-52032)
- Add to menu for SubDPlane command (RH-52026)
- Add to menu for SubDSphere command (RH-52061)
- Add to menu for SubDTorus command (RH-52069)
- Toolbar: Add DeleteAll to RMB of the CurveBoolean button (RH-49071)
brian
(Brian Gillespie)
34
Rhino WIP for Windows 7.0.19120 is now available
Bugs Fixed:
- Annotation: Hatch: Can’t create Hatches in the latest Rhino 7 WIP (RH-52274)
- Audit: Report formatting (RH-51897)
- Crease: Click close to a vertex should always select the vertex (RH-52173)
- ExportWithOrigin: One-shot OnSrf snap causes export to fail (RH-52115)
- RDK: ContentDisplayCollection datasource should filter out contents that are hidden by auto delete (RH-52113)
- Rotate3D: Unable to transform 1 object in block (RH-52124)
- SDK: RhinoCommon:
- Dialogs.ShowMultiListBox title and message swapped (RH-52181)
- Layer.IsVisible error shown as message box instead of exception (RH-48321)
- RhinoMath.ZeroTolerance != ON_ZERO_TOLERANCE (RH-52215)
- Typo in in Rhino.Display.DisplayModeDescription.DeleteDiplayMode (RH-48390)
- TextField: %<PageWidth()>% returns page height (RH-52269)
Features Added:
- TextField: Paper Size “Name” as Text Field (RH-51538)
SDK Enhancement:
- SDK: RhinoCommon: ShrinkTrimmedSrfToEdge in RC (RH-50712)
Tasks Completed:
- Rhino Inside: Set up AppVeyor CI build for RhinoInside.Revit (RH-52164)
brian
(Brian Gillespie)
35
Rhino WIP for Windows 7.0.19127 is now available
Bugs Fixed:
- DeleteMeshFaces: Selection menu does not ignore selected faces (RH-52400)
- Loft: Loft to SubD doesn’t work on these curves (RH-51230)
- Rendering: Materials: ON_PhysicallyBasedTexture needs PBR specific texture API (RH-52107)
- SubD: Creates bad objects (RH-52325)
- ToSubD: Extrusions do not make SubD (RH-51977)
Enhancements:
- TextField: Area and Volume and Length units (RH-48295)
brian
(Brian Gillespie)
36
Rhino WIP for Windows 7.0.19134 is now available
Bugs Fixed:
- OpenNURBS:
- Assert fired when reading PBR material (RH-52483)
- ON_PhysicallyBasedMaterial doesn’t get textures added/removed (RH-52482)
- Rendering: Materials: CRhRdkMaterial::ChildSlotUsage - GetTextureForUsage can’t handle PBR (RH-52108)
Enhancements:
- Rendering: Textures should have filtering enabled by default (RH-52484)
Tasks Completed:
- Menu: Change Slide command to Slide Edge in menus (RH-52420)
UI Change:
- OpenNURBS: Rhino outputs the name of all textures being saved (RH-52512)
brian
(Brian Gillespie)
37
Rhino WIP for Windows 7.0.19141 is now available
Bugs Fixed:
- SDK: RhinoScript: ReadFileVersion error (RH-52471)
brian
(Brian Gillespie)
38
Rhino WIP for Windows 7.0.19148 is now available
Bugs Fixed:
- MacroLibrary: Remove Print3D macros (RH-52719)
- OpenNURBS: ON_Texture’s m_bOn flag stays “true” even though texture has been un-checked. (RH-52843)
- RDK:
- Assert fires when opening Rendering panel (RH-52813)
- Assert fires when removing texture from slot (RH-52814)
- Revolve: Revolve/RailRevolve does not split at tangents correctly (RH-52736)
- SynchronizeRenderColors: Color not synced if there is a texture (RH-52023)
- Toolbar: Icon missing from Texture Tools toolbar (RH-52712)
Crashes Fixed:
- Annotation: Hatch: Crash trying to import hatch pattern (RH-52838)
- No Subsystem: Rhino.DocObjects.HatchPattern._InternalGetConstPointer () (RH-52749)
Enhancements:
- Csec: Allow lines as input (New LineObjects option) (RH-52791)
- DeleteFaces: New command (RH-52889)
Features Added:
- Picture: Paste image from clipboard as Picture (RH-40450)
SDK Enhancement:
- SDK: RhinoCommon: Rename a named view (RH-52278)
UI Change:
- DeleteFaces: Add to menus (RH-52890)
- Toolbar:
brian
(Brian Gillespie)
39
Rhino WIP for Windows 7.0.19163 is now available
Bugs Fixed:
DeleteFaces: Does not repeat (RH-52906)
Display:
- Copy (and other transform command) SubD display broken during drag (RH-52179)
- SubD loft preview isn’t shaded (RH-50749)
File IO: User would like changes to PLY exporter (RH-52385)
FilletEdge: Update edge radii - tune up (RH-52885)
Inset:
- Inset - Crash insetting quad mesh face with 3 colinear points (RH-52882)
- Inset doesn’t work on subd ngons (RH-52760)
Loft:
- Loft - Remember the SplitAtTangents setting (RH-52866)
- Loft - Match tangent checkboxes not working correctly (RH-52954)
- Loft - No SubD preview in wireframe and only wires in shaded mode (RH-50992)
Mesh: Create function on ON_Mesh, CullDegenerates, that removes collapsed edges (RH-52825)
OpenNURBS:
- ON_PhysicallyBasedMaterial should fix some default values (RH-52847)
- OpenNurbs main.py preparation script doesn’t work with Python 3 (RH-52370)
QuadMesh: This object returns no Quad mesh (RH-52933)
Rhino Inside: Create a download page for Rhino.Inside (RH-53127)
RDK:
- Assert fires in Plastic Material (RH-52958)
- SimulateMaterial assert when opening display regression test model (RH-52898)
SDK: RhinoCommon: Brep.CreateEdgeSurface should pass ON_Curve objects to RhinoCreateEdgeSrf (RH-52303)
SubD:
- Enable “proxy brep” support in getobject when a SubD is selected. (RH-52593)
- Inset does something odd in this case (RH-52009)
- SubD gumball extrude lifts neighbor faces (RH-52351)
SubD Editing: Extruding SubD edge creates flipped normal (RH-53047)
Sweep1: Sweep1 - miter fails (RH-4131)
TextField: PageWidth, PageHeight and PaperName won’t update (RH-52270)
Crashes Fixed:
- NamedSelections: ArgumentNullException: Value cannot be null. Parameter name: source (RH-52755)
- QuadMesh: QuadMash crash (RH-42409)
Enhancements:
- Bridge: Rename JoinOutput to WeldOutput? (RH-49868)
- Bridge: Add an option to adjust the direction about Bridge Command (RH-49922)
- Grasshopper: Automatically show errors and results (ghpython) (RH-52526)
- Loft: Loft - Support SubD Edges as input curves and tangent matching (RH-51084)
- Print: Print pdf folder path to the command line. (RH-47901)
- Display all materials when “Search Name” is selected (RH-53075)
- Search box should do partial matches (RH-53076)
- Smooth: Add SubD support (RH-51511)
Features Added:
- Bridge: SubD support (RH-49857)
- QuadMesh: Get QuadRemesher plugin using C++ method to create rhino licensed mesh (RH-52831)
- ToSubD: Add InterpolateMeshPoints=yes/no toggle option (RH-52856)
SDK Enhancement:
- SDK: RhinoCommon: FileObj.Write should support a list of Mesh (RH-49344)
Tasks Completed:
- Toolbar: Bridge icon needed in SubD toolbar (RH-53081)
UI Change:
- ExtractRenderMesh: Delete Ngons (RH-52886)
dan
(Dan)
40
Rhino WIP for Windows 7.0.19169 is now available
Bugs Fixed:
- Display:
- Mirrored SubD Xray (RH-50095)
- Mirrored SubDs shade incorrectly until file is reopened (RH-50605)
- ExtractAnalysisMesh: Not working correctly with SubD (RH-52435)
- ExtractMeshFaces: Please add back the ExtractMeshFaces command (RH-53219)
- Lasso: Lasso, region selection commands and selection filter support SubD objects/sub-objects (RH-49474)
- Mesh: Meshes created from closed SubD (ie. no edges) have naked edges (RH-52651)
- Mesh utilities for SubD: Add Mesh Utilities toolbar (RH-48796)
- Mirror:
- QuadMesh:
- RDK: Some hdri files don’t load into Rhino (RH-41747)
- Rendering: Materials: PBR smudge map is not necessary (RH-53146)
- SDK: RhinoCommon:
- SubDBox, SubDCone, SubDCylinder, SubDSphere need to use RhinoCommon classes instead of pInvoke (RH-53252)
- Sweep2 functionality need updating (RH-31673)
- Stitch: Preserve ngons (RH-46502)
- SubD:
- Copy-paste generates wiggly result (RH-53210)
- Selected SubD vertices and edges are not highlighted (RH-49241)
- SubD - becomes invisible after running Mesh command at maximum density. (RH-53153)
- SubD subobject drawing not working (RH-52384)
- ToSubD: Add ON_SubD::CreateFromBoundary (RH-52937)
- WeldEdge:
- Should not highlight unsupported edge types (RH-53243)
- WeldEdge hangs Rhino on this subd loft (RH-50743)
Enhancements:
- 3DFace: Add SubD support (RH-50876)
- Intersect: Add SubD support (RH-49975)
- SubD: Do a better jobs of creating SubD friendly fits to arcs. (RH-52517)
Features Added:
- Annotation: Text: New command (RH-50821)
- Stitch:
Regression:
- RDK: Can’t change thumbnail size (RH-53167)
SDK Enhancement:
- SDK:
- CRhinoDoc::ReplaceObject with SubD (RH-53279)
- CRhinoSubDObject::AddToDocument support for history and reference (RH-53280)
UI Change:
- Curve: SubDFriendly option messes with snapping (RH-53266)
