Rhino 7 WIP Available Now!
wip
wip-win-splash
(Brian Gillespie) #1
New feature development for Rhino 7 happens in the Rhino WIP. You need a license of Rhino 6 to download and run Rhino WIP. Download now!
New in Rhino WIP:
  • All the fixes in Rhino 6, plus:
  • CopyToClipboard: Doesn’t work in V7 (RH-42805)
  • File IO: Files written with ON_DebugWriteObject can’t be read in V7 (RH-43175)
Continuing from the Rhino WIP based on Rhino 6 code:
  • Cycles Render Plug-in
  • Mesh2 command
  • QuadMesh command
Sure, there’s not a lot new yet, but we need to get in the habit of releasing :slight_smile:
Download Rhino WIP now, and report any problems in this forum.
Has SubD been removed from the final Rhino 6 build?
Any rhino 7 news
(Bob McNeel) #2
(Brian Gillespie) #3
A post was split to a new topic: SubD APIs missing from WIP
(Brian Gillespie) #4
WIP 2018-Feb-13 Includes
Bug Fixes:
  • BooleanUnion:
  • Rhino Installer Engine: Localization folder not installed in V7 WIP (RH-43641)
Usability Problem Fixes:
  • BooleanDifference: Boolean failures (RH-30705)
(Brian Gillespie) #5
(Bob McNeel) #6
(Brian Gillespie) #7
Rhino WIP for Windows 7.0.18246 is now available
New Feature:
Bugs fixed:
  • Menu: Panels menu changes (RH-47985)
  • Mesh utilities for SubD:
  • Options: New linetype pattern not saved (RH-47686)
  • Update System: Installing Rhino WIP breaks automatic updates (RH-47590)
(Brian Gillespie) #8
Rhino WIP for Windows 7.0.18254 is now available
Bugs Fixed:
  • Selection: Extrusion picking doesn’t work right (RH-48181)
  • SelectionFilter: “Curves” and surface edges in commands (RH-48254)
  • TextField: DimCurveLength returning “####” (RH-45589)
Usability Problems Fixed:
  • Gumball: Synchronize Gumball menus? (RH-47486)
(Brian Gillespie) #9
Rhino WIP for Windows 7.0.18262 is now available.
Download now.
  • Mesh utilities for SubD: Direction arrows too small or big (RH-46839)
Features Added:
    • Automatic mesh orientation when using retopology snap to create new mesh (RH-46157)
    • ngon support (RH-47935)
  • TextField: The basic arithmetic operations (RH-20160)
Bugs Fixed:
    • Bevel leaves holes (RH-46657)
    • Create quad, undo, create quad throws exception (RH-48253)
    • Ngon support (RH-46697)
    • Remember command option values (RH-44968)
    • Undo doesn’t work with the “orient mesh according to retopo normal” (RH-48446)
    • stitching failure (RH-44407)
  • SelectFilter: Sub-object selection inconsistent (RH-48173)
Enhancements:
  • DevLoft: Add History support (RH-44309)
  • TextField: DimArea doesn’t work on sub-object selections (RH-42653)
(Brian Gillespie) #10
Rhino WIP for Windows 7.0.18268 is now available.
Download now.
Bugs Fixed:
    • Fails without error message (RH-45712)
    • Mesh object that faces are appended to moves to current layer (RH-46595)
    • Retopology snap object selection broken (RH-48383)
    • chain mode broken (RH-48334)
  • TextField: Volume (RH-20147)
  • Mesh utilities for SubD: Amount input without reference point picking (RH-46802)
New Features:
  • Mesh utilities for SubD: Snap to previously added points (RH-46845)
  • TextField: Allow multiple objects for area and length in TextField (RH-27872)
(Brian Gillespie) #11
Rhino WIP for Windows 7.0.18273 is now available.
Download now.
Bugs Fixed:
    • Ngon boundaries are not welded (RH-48570)
    • Problem with this mesh (RH-48592)
    • Triangle added when ending quad chain by right mouse click (RH-48593)
    • Twisted face when appending ngon FromEdge (RH-48614)
    • retopo object selection (RH-46917)
Usability Problem:
  • Mesh utilities for SubD: undo while creating polygon removes previous polygon (RH-48587)
(Brian Gillespie) #12
Rhino WIP for Windows 7.0.18280 is now available.
New Feature:
  • Project command: Add support for control points and mesh vertices… (RH-47265)
Bugs Fixed:
  • ExtendSrf: ExtendSrf - Always Expand with Positive Number (RH-48590)
(Brian Gillespie) #13
Rhino WIP for Windows 7.0.18303 is now available.
Bugs Fixed:
  • Analytics: Add clickers to Scale controls (RH-48822)
  • BlendEdge: Use setbacks wherever possible in BlendEdge (RH-44180)
  • Fullscreen: Fullscreen misses top toolbar & dragstrength (RH-43727)
  • Selection: Turn on clickable control polygon by default (RH-46066)
  • SelU: Click on the control polygon (RH-42015)
(Brian Gillespie) #14
Rhino WIP for Windows 7.0.18310 is now available.
Bugs Fixed:
  • Menu: Add Edge Continuity to the Panels menu (RH-49239)
T-splines and Rhino 6
(Brian Gillespie) #15
Rhino WIP for Windows 7.0.18324 is now available
Crashes Fixed:
Bugs Fixed:
  • Analysis:EdgeContinuity: Only works once in a Rhino session (RH-49251)
  • Analytics:
    • EdgeContinuity - Add and remove edge pairs (RH-48821)
    • Make an analysis mode to display Edge Continuity between pairs of surface edges (RH-48690)
  • BlendEdge: Fails to create 6-patch corner (RH-48753)
  • Context Menu: Control point context menu defaults (RH-49030)
  • Divide: Add EqualCordLength option to Divide command (RH-44521)
  • Drape: Change output surface from degree 2 to 3 (RH-4051)
  • FitCrv: New command (RH-44758)
  • Lasso: Select objects with points on (RH-48680)
  • No Subsystem: ShowDir event watcher should only run when analysis dialog is visible (RH-48798)
  • SDK:
    • Function for Ribbon Offset (RH-49355)
    • Wish - Joined polylines should have arc length parameterization (RH-49371)
  • Selection: Cannot Ctrl+Shift Select surfaces in grouped items. (RH-47505)
  • SplitRefit: Fails (RH-44011)
  • Sweep2: Fails in v7 (RH-49200)
  • Analysis:EdgeContinuity: Needs a “Remove All” button? (RH-49409)
Regressions Fixed:
  • PointCloud: Cannot SubObject Select Points in PointCloud - RH7 WIP (RH-49271)
(Brian Gillespie) #16
Rhino WIP for Windows 7.0.18331 is now available
Features Added:
  • Curve: Add MergeCrv command (RH-45817)
Bugs Fixed:
  • Analysis:EdgeContinuity: Make EdgeContinuity a real command (RH-48971)
  • SelCircular: Keep the center (RH-49383)
(Brian Gillespie) #17
Rhino WIP for Windows 7.0.18338 is now available
Bugs Fixed:
  • MeshSelfIntersect: New command (RH-48255)
  • SDK: Function for Ribbon Offset (RH-49355)
  • UDT: Flow Group Behavior Should Be Optional (RH-45727)
(Brian Gillespie) #18
Rhino WIP for Windows 7.0.18352 is now available
Bugs Fixed:
    • Curvature readout (RH-48993)
    • Should remember panel docking/floating status (RH-49408)
  • Analytics: EdgeContinuity - Curvature report (RH-48823)
(Brian Gillespie) #19
Rhino WIP for Windows 7.0.19009 is now available
Bugs Fixed:
  • Display: Single Stroke Font Display (RH-50121)
  • Installer:
    • Rhino 6 in safe mode is not found in a Windows Start Menu search (RH-49966)
    • WIP 7 changes my Rhino 6 installation again (RH-49755)
  • SDK: RhinoCommon: RhinoRibbonOffsetCurve needs to be wrapped for RhinoCommon (RH-50021)
  • SelEdgeRing: SubD support (RH-49863)
Features Added:
  • Extrude: Support pre-selection of top level mesh objects (RH-49802)
  • Slide: Remember loop selection option (RH-49803)
  • Append: Selecting meshes to append to needs to be optional (RH-46796)
(Brian Gillespie) #20
Rhino WIP for Windows 7.0.19017 is now available
Bugs Fixed:
  • BlockManager: Block Name Conflict Dialog Cleanup (RH-49936)
  • Select: SubD control point selection incorrectly highlights nearby points (RH-49847)
  • Selection:
    • A control point has doubled items in selection menu (RH-50365)
    • Select two control points without noticing (RH-50002)
Enhancements:
  • SDK: RhinoCommon: Gradient Mesh and Hatch drawing routines in RhinoCommon (RH-50310)
  • Splash and About: Use ‘wip-win-splash’ tag to feed Rhino WIP news feed (RH-50307)
Features Added:
  • Mesh utilities for SubD: Improvements (RH-49794)
Performance Problem:
  • Grasshopper: Shallow geometry copies should use parent display cache (RH-50309)
Regression:
  • FilletEdge: FilletEdge - values are displayed incorrectly during preview - RH7 (RH-50195)
