I’m new to Rhino and recently tried to create some jewellery on a trial version of Rhino 7. The thing is, it comes out like an 80s rendering, rather than a modern one. Can someone help me please? Do I need to change the settings? Change the graphics card? Download some sort of plug in? I’m so confused…
I’ve attached a jpeg of what I’m seeing for reference. It’s meant to be polished silver with a blue plastic piece.
Thanks for responding. Do you have any suggestions on what I should update my graphics software to? In order to get the rendering I need/want/it should be?
Even with the laptop you should be able to get decent renders. You need to use either the Raytraced viewport mode, or press Render with Rhino Render as the current render engine.
Assuming you have added a Rhino Metal material with its color set to silver and a Rhino Plastic with the blue color you should get pretty good results even with just CPU rendering.
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 3.8Gb)
Primary display and OpenGL: Intel(R) HD Graphics (Intel) Memory: 1GB, Driver date: 3-27-2018 (M-D-Y). OpenGL Ver: 4.5.0 - Build 23.20.16.5017
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.5 (primary GPU’s maximum)
Anti-alias mode: 8x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.5
Shading Language: 4.50 - Build 23.20.16.5017
Driver Date: 3-27-2018
Driver Version: 23.20.16.5017
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
It is a goods start. But metals look great because they have an interesting environment to reflect in the real world. In your case there is no environment, so nothing nice to reflect. The default studio environment doesn’t show well in your model because it has straight surfaces that happen to be position such to the camera that there is nothing good to see. Compare with a torus
You see it looks already much nicer just because you can see more of the studio environment in the reflections.
I am no jewler, but I like to get rid of the automatic ground plane, since that will show up on reflective surfaces in Raytraced and Rhino Render. I’d rather create an object to ‘ground’ the item. Further I like to have the bright spot of an environment texture coming in from behind
There is a number of environments bundled with Rhino that you may want to try out for custom reflection and skylight environments in the rendering panel.
