Rhino 7 Viewport Problem
When I create an object, such as a sphere at the origin, only half of the sphere is shaded (Viewport is in shaded mode). The portion of the sphere in the -x axis region is not shaded. If I move the sphere to the right so that the sphere is only in the +x axis region it is fully shaded. I’m not quite sure what I did to create this problem. How can I correct this problem?
Thanks
Not familiar with that one. Try resetting the display mode you are using to default?
Please type systemInfo in the command line (plugins, video card config ect) and return the results here. Thanks
Just to be clear, this is a new problem, it was working as expected 2 days ago.
Here is the info you asked for:
Rhino 7 SR23 2022-10-9 (Rhino 7, 7.23.22282.13001, Git hash:master @ a931168ca9426920ae6aa97218710b662f17fc39)
License type: Commercial, build 2022-10-09
License details: Cloud Zoo
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 7.9Gb)
Computer platform: LAPTOP - Plugged in [99% battery remaining]
Primary display and OpenGL: Intel(R) Iris(R) Plus Graphics 640 (Intel) Memory: 1GB, Driver date: 7-19-2022 (M-D-Y). OpenGL Ver: 4.6.0 - Build 31.0.101.2111
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 31.0.101.2111
Driver Date: 7-19-2022
Driver Version: 31.0.101.2111
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 7\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\export_STL.rhp “STL Export”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 7\Plug-ins\QuadRemesh\QuadRemesh.rhp “QuadRemesh” 7.23.22282.13001
C:\Users\Roger\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
Hello- does this happen in a new session of Rhino, using file > New > No Template, then make your sphere? Or is it file-specific?
Pascal,
The new session of Rhino fixed the problem. Thank you for your insight.
Roger
