i recentely stummbled upon a script from “Jesterking” to open 3dm files in Blender. It works great but the camera dimensions arent being converted properly. I only found a short thread from 2018 about this but the problem still doesn
t seem to be resolved.
Is there any fix or workaround to achieve the exact same camera settings in both programs ?
Thanks in advance for any information!
I don’t think there is a work-around other than fixing the code
/jesterKing
Well?
Definitely at some point
I wrote these two scripts to export named views from Rhino and import them into blender:
Rhino
import scriptcontext as sc
import json
import Rhino
import System.Environment
def ViewData():
view_port = sc.doc.Views.ActiveView.ActiveViewport
if not view_port.IsPerspectiveProjection: return None
width = view_port.Size.Width
height = view_port.Size.Height
fov = view_port.GetCameraAngle()[3]*2
lens_length = view_port.Camera35mmLensLength
camera_location = view_port.CameraLocation
clipping_near = view_port.GetFrustumNearPlane()[1].Origin
clipping_near = clipping_near.DistanceTo(camera_location)
clipping_far = view_port.GetFrustumFarPlane()[1].Origin
clipping_far = clipping_far.DistanceTo(camera_location)
camera_rot_plane = Rhino.Geometry.Plane(
Rhino.Geometry.Point3d.Origin,
view_port.CameraX,
view_port.CameraY)
transformed_plane = Rhino.Geometry.Plane.WorldXY
rot_transform = Rhino.Geometry.Transform.ChangeBasis(camera_rot_plane, transformed_plane)
camera_rotation = (Rhino.Geometry.Transform.GetYawPitchRoll(rot_transform)[1:])
camera_rotation = (camera_rotation[2], camera_rotation[1], camera_rotation[0])
camera_rotation = str(camera_rotation)
camera_rotation = camera_rotation[1:-1]
camera_data = [width, height, "Perspective", fov, lens_length, camera_location.ToString(), camera_rotation, clipping_near, clipping_far]
return camera_data
sc.doc.Views.RedrawEnabled = False
cameraData = {}
for nv in sc.doc.NamedViews:
sc.doc.Views.ActiveView.MainViewport.PushViewInfo(nv, False)
data = ViewData()
if data:
entry = {
"camera_width": data[0],
"camera_height": data[1],
"camera_lensType": data[2],
"camera_fov": data[3],
"camera_lensLength": data[4],
"camera_location": data[5],
"camera_rotation": data[6],
"camera_clippingNear" : data[7],
"camera_clippingFar" : data[8]
cameraData[str(nv.Name)] = entry
desktop = System.Environment.GetFolderPath(System.Environment.SpecialFolder.Desktop)
doc_name = rs.DocumentName()[:-4]
folder = rs.BrowseForFolder(folder=desktop, message=None, title="Save Location")
if folder:
json_filename = folder + '\\' + doc_name + '_BlenderCamera.json'
print json_filename
with open(json_filename, 'w') as f: json.dump({}, f)
with open(json_filename, 'w') as f: json.dump(cameraData, f, indent = 4, sort_keys=True)
sc.doc.Views.RedrawEnabled = True
sc.doc.Views.Redraw()
Blender
import bpy
import os
import math
import json
pi = math.pi
scene = bpy.context.scene
scale = 1/1000
use_fov = False
def ReadData(filename):
try:
with open(filename, 'r') as f:
datastore = json.load(f)
return datastore
except IOError:
print ("Reading Failed")
def AddCamera(view):
camera_loc = [float(l)*scale for l in d_camera[view]["camera_location"].split(",")]
camera_rot = [float(l) for l in d_camera[view]["camera_rotation"].split(",")]
bpy.ops.object.camera_add(enter_editmode=False, align='VIEW', location=camera_loc, rotation=camera_rot )
currentCameraObj = bpy.data.objects[bpy.context.active_object.name]
scene.camera = currentCameraObj
currentCameraObj.name = view
if use_fov:
currentCameraObj.data.lens_unit = 'FOV'
currentCameraObj.data.angle = float(d_camera[view]["camera_fov"])
else:
currentCameraObj.data.lens_unit = 'MILLIMETERS'
currentCameraObj.data.sensor_width = 57.519
currentCameraObj.data.lens = float(d_camera[view]["camera_lensLength"])
#Align View to Main Camera
area = next(area for area in bpy.context.screen.areas if area.type == 'VIEW_3D')
area.spaces[0].region_3d.view_perspective = 'CAMERA'
#Clipping
clippingNear = float(d_camera[view]["camera_clippingNear"]) * scale
clippingFar = float(d_camera[view]["camera_clippingFar"]) * scale
currentCameraObj.data.clip_start = clippingNear
currentCameraObj.data.clip_end = clippingFar
bpy.context.scene.render.resolution_y = float(d_camera[view]["camera_height"])
bpy.context.scene.render.resolution_x = float(d_camera[view]["camera_width"])
path = r'C:\\Users\\Alasdair\\Desktop\\'
json_filename = path + "Blender-Camera.json"
d_camera = ReadData(json_filename)
for view in d_camera:
AddCamera(view)
Just replace the path with where you saved the named views.
Does this code still work with the latest Rhino 7? The json file is empty when I export from Rhino.
