How to transfer an object from rhino 7 to archicad 26?
Hi -
You’ll need to compare the lists of supported file formats and find one that works for you.
right. I was thinking there should be a plug-in (as there is one for Grasshopper to Archicad) or some other dedicated way for a particular problem…
Hi -
If you are running both Rhino and Archicad on your machine, then, yes, I suppose the Grasshopper – Archicad Live Connection tool would probably make most sense. You can reference Rhino geometry in Grasshopper. Apart from that, for questions related to that tool, you’ll need to contact its developer Graphisoft.
