just a generic question: Did anything change from 7 to 8 on Mac with regards to the snap behaviour?
In general I can’t seem to work as smooth as I did in 7; too often it snaps to something I hadn’t intended.
All the best,
Timo
All the best,
Timo
The “Object snap radius” may be set differently in your V8 installation compared to your V7 installation.
In V8 Windows it is set in Options
> Rhino Options > Modeling Aids
Thank you, but both versions have the same settings.
Hi Timo- can you be more specific? What exactly are you seeing go wrong? Is there a particular repeatable case you can post as a Rhino file so we can test?
Hi Pascal,
no. Sorry. Only an unsubstantial “feeling”. I seem to have to select and deselect the OSnap targets more often than before to get it right. And therefore I thought I’d asked.
It is probably just user error.
Thank you!
Hi Timo- thanks, I’d say it is not impossible there is a difference in some cases - if you can confirm this somehow as you work and can provide some details, it would be helpful.
