Rhino 7 Technical Views (pen, artistic, etc)
Rhino 7 seemingly cannot generate technical drawing data for 80mb model. I tried simplifying the model, but that did not seem to help. Single small box will generate, but more complex will not.
It should be using the GPU to compute, but the CPU jumps to 75-100% for Rhino. Any thoughts would be appreciated!
SystemInfo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX A2000 12GB (NVidia) Memory: 12GB, Driver date: 3-22-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 528.86
- Secondary monitor attached to adapter port 0
- Windows Main Display attached to adapter port 1
- Secondary monitor attached to adapter port #2
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-22-2023
Driver Version: 31.0.15.2886
Z-Buffer depth: 24 bits
Total Video Memory: 12282 MB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.32.23221.10241
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.32.23221.10241
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.32.23221.10241
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.32.23221.10241
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.32.23221.10241
can you share the model so we can review it? (held in confidence then deleted after testing)
you can upload it here-
https://www.rhino3d.com/upload
Hi Kyle - model has been uploaded!
FYI NVIDIA Driver updated - same issue.
Rhino 7 SR32 2023-8-9 (Rhino 7, 7.32.23221.10241, Git hash:master @ 3d9c816c4cd57561d12d8f53246bce304f314ba2)
License type: Commercial, build 2023-08-09
License details: Cloud Zoo
Primary display and OpenGL: NVIDIA RTX A2000 12GB (NVidia) Memory: 12GB, Driver date: 8-14-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.13
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 8-14-2023
Driver Version: 31.0.15.3713
Hi Timothy, I opened your file and was able to switch Technical views seamlessly. This points towards troubleshooting your video driver/ display configuration.
Same here- Pops right open in all modes.
Did you update your driver with a clean install?
If not please update again, use the custom/advanced mode and use the “clean install” checkbox.
