Rhino 7 slow startup
Occasionally occurs; sometimes opens immediately, but most of the time, it takes a while for the splash screen to appear, rather than getting stuck during the splash screen loading phase.
Even in Safe Mode, the same situation persists.
Once the splash screen does show up, Rhino loads promptly.
I’ve tried running the -stopwatch command.
(0.0000) - Since Last Record = 0.0000 (%0.00) - Create Stopwatch
(0.0120) - Since Last Record = 0.0120 (%0.04) - Pre-initialize .net
(0.8710) - Since Last Record = 0.8590 (%3.08) - Post-initialize .net
(23.3790) - Since Last Record = 22.5080 (%80.80) - after create and load AppSettings
(23.3880) - Since Last Record = 0.0090 (%0.03) - before CRhWGLExtensions::InitWGLExtensions()
There were only 5 lines in the stopwatch output?
Apologies, the complete output is here. I noticed a delay occurring at 23 seconds (after creating and loading AppSettings) , so I only posted up to this point.
(23.5340) - Since Last Record = 0.1460 (%0.52) - after CRhWGLExtensions::InitWGLExtensions()
(23.5410) - Since Last Record = 0.0070 (%0.03) - before Create splash window
(23.5410) - Since Last Record = 0.0000 (%0.00) - after Create splash window
(23.5420) - Since Last Record = 0.0010 (%0.00) - construct CMainFrame
(23.6940) - Since Last Record = 0.1520 (%0.55) - after load CMainFrame
(24.4710) - Since Last Record = 0.7770 (%2.79) - after initialize license manager
(24.5060) - Since Last Record = 0.0350 (%0.13) - after loading of cursor resources
(24.5490) - Since Last Record = 0.0430 (%0.15) - after RegisterBuiltInCommands()
(24.5740) - Since Last Record = 0.0250 (%0.09) - Pre auto load plugins
(24.6240) - Since Last Record = 0.0500 (%0.18) - Toolbars
(24.6610) - Since Last Record = 0.0370 (%0.13) - RDK:CRhRdkRhinoPlugIn CTOR
(24.6690) - Since Last Record = 0.0080 (%0.03) - RDK:OnLoadPlugIn
(24.6740) - Since Last Record = 0.0050 (%0.02) - RDK:Initialize: start
(24.6750) - Since Last Record = 0.0010 (%0.00) - RDK:Initialize: after default registered properties
(24.6890) - Since Last Record = 0.0140 (%0.05) - RDK:Initialize: after default post effect plug-in factories
(24.6890) - Since Last Record = 0.0000 (%0.00) - RDK:Initialize: after adding internal extensions
(24.6890) - Since Last Record = 0.0000 (%0.00) - RDK:Initialize: after conduits
(24.7050) - Since Last Record = 0.0160 (%0.06) - RDK:Initialize: end
(24.7050) - Since Last Record = 0.0000 (%0.00) - RDK:OnLoadPlugIn: after RDK Initialize
(24.7050) - Since Last Record = 0.0000 (%0.00) - RDK:OnLoadPlugIn: after RDK OnLoadRhinoPlugIn
(24.7050) - Since Last Record = 0.0000 (%0.00) - RDK:OnLoadPlugIn - end
(24.7310) - Since Last Record = 0.0260 (%0.09) - Renderer Development Kit
(24.9340) - Since Last Record = 0.2030 (%0.73) - Commands
(24.9420) - Since Last Record = 0.0080 (%0.03) - Snapshots
(24.9500) - Since Last Record = 0.0080 (%0.03) - Rhino 渲染
(25.0090) - Since Last Record = 0.0590 (%0.21) - RDK_EtoUI
(25.0240) - Since Last Record = 0.0150 (%0.05) - Renderer Development Kit UI
(25.2320) - Since Last Record = 0.2080 (%0.75) - RhinoCycles
(25.2460) - Since Last Record = 0.0140 (%0.05) - 3Dconnexion 3D Mouse
(25.2550) - Since Last Record = 0.0090 (%0.03) - Displacement
(26.4050) - Since Last Record = 1.1500 (%4.13) - JFR
(26.8830) - Since Last Record = 0.4780 (%1.72) - JewellyForRhino
(27.2640) - Since Last Record = 0.3810 (%1.37) - JFRGemCoolHelpe
(27.3010) - Since Last Record = 0.0370 (%0.13) - after create TabbedDockBarCollection
(27.3010) - Since Last Record = 0.0000 (%0.00) - after load default render engine
(27.3020) - Since Last Record = 0.0010 (%0.00) - after CloseAllDocuments
(27.3140) - Since Last Record = 0.0120 (%0.04) - before LoadToolBarsAndRestoreDockBarPositionAndStates
(27.3160) - Since Last Record = 0.0020 (%0.01) - Start of C# LoadToolBarFiles
(27.3480) - Since Last Record = 0.0320 (%0.11) - - LoadToolBarFiles step 1
(27.3480) - Since Last Record = 0.0000 (%0.00) - - Start TryLoadRuiFile: C:\Users\Administrator\AppData\Roaming\McNeel\Rhinoceros\7.0\UI\default.rui
(27.5110) - Since Last Record = 0.1630 (%0.59) - - END TryLoadRuiFile
(27.5110) - Since Last Record = 0.0000 (%0.00) - - Start TryLoadRuiFile: D:\JFR7.0\Toolbar\零犀文化珠宝工具列.rui
(27.5550) - Since Last Record = 0.0440 (%0.16) - - END TryLoadRuiFile
(27.5550) - Since Last Record = 0.0000 (%0.00) - - LoadToolBarFiles step 2
(27.5670) - Since Last Record = 0.0120 (%0.04) - End of C# LoadToolBarFiles
(27.5670) - Since Last Record = 0.0000 (%0.00) - after m_pCallbacks->LoadToolBarFiles
(27.5670) - Since Last Record = 0.0000 (%0.00) - after RunLoadToolbars
(27.7240) - Since Last Record = 0.1570 (%0.56) - after RunPostLoadToolBarsAndRestoreDockBarPositionAndStates
(27.7240) - Since Last Record = 0.0000 (%0.00) - after LoadToolBarsAndRestoreDockBarPositionAndStates
(27.7950) - Since Last Record = 0.0710 (%0.25) - before Process Shell Commands
(27.8570) - Since Last Record = 0.0620 (%0.22) - after Process Shell Commands
(27.8570) - Since Last Record = 0.0000 (%0.00) - CRhStopWatch::ShowReport()
指令: CommandHistory
It is interesting that it takes so long to load the settings. Maybe @stevebaer can look into this more.
