I tried searching for similar posts but I couldn’t find one exactly the same.
After installing Rhino 7, both SR0, SR1. My Rhino Shaded Views always have a yellow bar on the bottom of the viewport with “Shaded ( ) Not Available” The views then become very sluggish. I barely can rotate or pan them. I do have V-Ray 5 plugin installed.
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 32Gb)
Primary display: Intel® UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 9-25-2019 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 9-14-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 456.38
> Integrated acclerated graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-14-2020
Driver Version: 27.21.14.5638
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\ADA 3D\Mesh2Surface for Rhino 6\m2s_for_Rhino.rhp “MESH2SURFACE”
C:\ProgramData\McNeel\Rhinoceros\6.0\Plug-ins\Twinmotion Direct Link 2020.2 (e24ee14a-9514-47da-8fe6-f6e61b20160e)\Twinmotion Direct Link 2020.rhp “Twinmotion Direct Link 2020” 1.0.6.0
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
This looks like the “Raytracing” HUD for things like “Raytraced” mode…So something has clearly messed up the display mode ID’s for your modes… I have no idea how or what could have done this.
I would try going into Options->View->Display Modes and delete your Shaded mode (and any other modes that exhibit this problem) and then close the Options dialog. Rhino will then recreate the mode(s) with the defaults.
That’s the file that I found the issue all the time. After disabling the V-Ray Plugin. I’m not able to open this file anymore. My Rhino 7 crashes all the time when I open this file.
@jvic - your file probably has a V-Ray viewport visible. To get around that import your 3dm into a new file. That will probably get around your problem.
After removing SHADED display mode from the display setting. Then reloading the V-Ray plugin back and select it as the render engine, the problem was gone. Now the shaded mode displays without any yetllow bar at the bottom of the viewport. It runs perfect now. Thank you for the solution.
