Ive just installed rhino 7 , and my pop up and (middle mouse) zoom is not working
also cant see my lines when i draw ?
Run SystemInfo and post the results here, to start… The mouse wheel zoom isn’t working? Have you got some custom settings for something else that might be interfering?
OS Name | Microsoft Windows 10 Pro |
Version | 10.0.19042 Build 19042 |
Other OS Description | Not Available |
OS Manufacturer | Microsoft Corporation |
System Name | RYAN-PC |
System Manufacturer | GIGABYTE |
System Model | Q2532N |
System Type | x64-based PC |
System SKU | 0 |
Processor | Intel(R) Core™ i5-2410M CPU @ 2.30GHz, 2301 Mhz, 2 Core(s), 4 Logical Processor(s) |
BIOS Version/Date | American Megatrends Inc. 204, 18/02/2011 |
SMBIOS Version | 2.6 |
Embedded Controller Version | 255.255 |
BIOS Mode | Legacy |
BaseBoard Manufacturer | GIGABYTE |
BaseBoard Product | Q2532N |
BaseBoard Version | 1.0 |
Platform Role | Mobile |
Secure Boot State | Unsupported |
PCR7 Configuration | Binding Not Possible |
Windows Directory | C:\WINDOWS |
System Directory | C:\WINDOWS\system32 |
Boot Device | \Device\HarddiskVolume1 |
Locale | Zimbabwe |
Hardware Abstraction Layer | Version = 10.0.19041.488 |
Username | RYAN-PC\RYAN |
Time Zone | South Africa Standard Time |
Installed Physical Memory (RAM) | 10.0 GB |
Total Physical Memory | 9.91 GB |
Available Physical Memory | 5.07 GB |
Total Virtual Memory | 19.9 GB |
Available Virtual Memory | 14.9 GB |
Page File Space | 10.0 GB |
Page File | C:\pagefile.sys |
Kernel DMA Protection | Off |
Virtualisation-based security | Not enabled |
Device Encryption Support | Reasons for failed automatic device encryption: TPM is not usable, PCR7 binding is not supported, Hardware Security Test Interface failed and the device is not Modern Standby, Un-allowed DMA-capable bus/device(s) detected, TPM is not usable |
Hyper-V - VM Monitor Mode Extensions | Yes |
Hyper-V - Second Level Address Translation Extensions | Yes |
Hyper-V - Virtualisation Enabled in Firmware | Yes |
Hyper-V - Data Execution Protection | Yes |
i upgraded from version 4 ? and had to upgrade my windows to win 10 maybe need to go back to windows 7 and use version 4 ?
I meant to run the “SystemInfo” command in Rhino. Umm your bios is from 2011 so it’s possible your hardware does not meet the minimum specs for V7.
Rhino 7 SR7 2021-5-31 (Rhino 7, 7.7.21151.13001, Git hash:master @ 24d76fc798fa6ffd33733e5f18b034d547b87840)
License type: Educational, build 2021-05-31
License details: Stand-Alone
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 9.9Gb)
Computer platform: LAPTOP - Plugged in [83% battery remaining]
Primary display: Intel(R) HD Graphics 3000 (Intel) Memory: 2GB, Driver date: 5-19-2016 (M-D-Y).
> Integrated graphics device with 2 adapter port(s)
Primary OpenGL: NVIDIA GeForce GT 540M (NVidia) Memory: 1GB, Driver date: 5-1-2017 (M-D-Y). OpenGL Ver: 4.5.0 NVIDIA 382.05
> Integrated accelerated graphics device with 1 adapter port(s)
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.5 (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.5
Shading Language: 4.50 NVIDIA
Driver Date: 5-1-2017
Driver Version: 22.21.13.8205
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.7.21151.13001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.7.21151.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.7.21151.13001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.7.21151.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.7.21151.13001
u are welcome to team view it to see for yourself ?
Well your video drivers are 4 years old, so update those if it’s possible. Rhino 7 needs up-to-date drivers and Windows.
