Is there something that I should enable for rhino to remember frequent commands? Ever since I switched from 6 to 7 this has been an issue and its driving me crazy. As you know some commands arent the shortest, almost a whole sentence… This is giving me a very unpleasant workflow and slowing me down.
PLEASE HELP. Thank you
Hello - make sure these settings are turned on:
And, the PopUpPopular
command can help - you can put this on the context menu
then it will always show at the top of the command area context menu:
Thank you pascal, Ill give it a try.
Additionally right clicking in the command line gives you a list of last used commands and then of course you can shorten your commands by using aliases.
