Hello Rhino developers,
I am working on deploying a Rhino 7 plugin that I created using the Rhino C++ SDK.
So far, I’ve followed what was described here:
to generate the .yak file, and I have configured the Package Manager to go find that on a shared disk.
However, the plugin being installed under the AppData\Roaming\McNeel\Rhinoceros\packages\7.0
generated an error when being loaded in Rhino, saying that there’s a missing DLL, although the DLLs that my plugin use are already under the same folder under the path mentioned earlier.
Is there a specific rule for where Rhino looks for the required DLLs?
A simple test of copying the contents of my packaged plugin (.rhp and dlls) into the /System directory directly next to the Rhino executable, works like a charm, and the plugin is able to find all its DLLs in that directory. So my guess is the DLL lookup isn’t appropriate?
Any help would be appreciate it.
Thanks
