When I was using RHINO 7 I encountered a very serious problem!
When I choose the dimension, the software will crash directly
You’re using a cracked version of Rhino 7 that could be the problem.
Please download the 90-day evaluation version from https://www.rhino3d.com/download/
We can continue if the evaluation version also crashes.
Can you type the SystemInfo command in Rhino and post the information?
Rhino 7 SR3 2021-2-22 (Rhino 7, 7.3.21053.23031, Git hash:master @ f8a40388712d9cf7edc68910e0415427bdefc64a)
License type: Evaluation, 版本2021-02-22
License details: Stand-Alone
Expires on: 2021-05-31
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1050 Ti (NVidia) Memory: 4GB, Driver date: 9-30-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 456.71
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-30-2020
Driver Version: 27.21.14.5671
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\13203\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\KeyShot10RhinoPlugin (ccedd9da-83b9-429a-aec5-8ec90b85fe67)\1.0.0.0\KeyShot10RhinoPlugin\Rhino 5.0\KeyShot10RhinoPlugin.rhp “KeyShot10RhinoPlugin” 1.0.0.0
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V6\VRayForRhino.rhp “V-Ray for Rhino”
C:\Users\13203\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\KeyShot9RhinoPlugin (ecfe8d1f-876a-460f-aa5e-3dd816936811)\1.0.0.0\KeyShot9RhinoPlugin\Rhino 5.0\KeyShot9RhinoPlugin.rhp “KeyShot9RhinoPlugin” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.3.21053.23031
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.3.21053.23031
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.3.21053.23031
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.3.21053.23031
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.3.21053.23031
When I use other functions, there is no problem, but as long as I select the dimension, the software will crash
Please do these:
Update the display card driver and then test.
Tools > Options > Plug-ins, select “Plugins that do not ship with Rhino”. Disable all the plug-ins listed. Restart Rhino and then test.
Do you happen to have the “速成” input method active when Rhino is running? Can you change the input method to ENG when Rhino is running?
I am using Microsoft’s own input method. I still have problems when I change to ENG
OK, please go to Windows Settings > APPs >, modify Rhino 7 installation.
Click “Select Languages”.
Add English to download the English language pack.
When it’s done, start Rhino in English. (You may need to go to Options > Appearance to select English.)
See if the crash still happens.
Hmm… Can you send the crash report, and enter your email? I’ll check with the developer.
OK,Thank you!
Nothing found in debugging your crash report.
Can you try to install all Windows updates?
And please take a screen capture of Windows Settings > System > About of your computer.
Now I am trying to reinstall my computer system. If there is any problem, I will come to you to respond!
Thanks for you help!
