Rhino 7 Lights Panel
Anyone having issues opening ‘lights panel’ in Rhino 7? I feel like when I first upgraded it worked but now whenever I try to open it nothing happens. Does it not work because I have VRay and that overrides native controls?
I don’t have or use V-Ray, but that could be it.
Change your Current Renderer to Rhino Render and see if it works.
If it does, then switch back to V-Ray and see if it goes away again.
Than you’ll know.
Unfortunately that doesn’t seem to work…
In Rhino Options > Plug-ins, are these plug-ins enabled and loaded?
the RDK_EtoUI was off. that solved it! thank you.
That would explain it.
That’s the plugin that provides the User Interface for RDK based tools.
