Rhino 7 keeps locking out as I try to work with mesh on mac
The thing keeps stopping responding and needs forced quit. I have a large mesh (6529930 vertices, 12720052 faces) that needs reducing in size as it constantly crashes the program. It’s 636mb file size. At a loss as how to deal with this! I then need to chop the object into smaller parts to print it. Can anyone help please?! Thanks!
It’s a 636mb size btw
Hi Gordan,
Please run systeminof in your command line and post the results. Thanks!
Rhino 7 SR38 2024-12-3 (Rhino 7, 7.38.24338.17002, Git hash:master @ 97e36efa02d7f71638988290bb2d190fcf1b18c5)
License type: Commercial, build 2024-12-03
License details: Cloud Zoo
Apple macOS Version 15.7.7 (Build 24G720) (Physical RAM: 24Gb)
Rhino is running in Rosetta2 on Apple Silicon
Mac Model Identifier: Mac16,7
Language: en-GB (MacOS default)
Apple M4 Pro (OpenGL ver:4.1 Metal - 89.4)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 16 GB
Graphics: Apple M4 Pro
Displays: Unknown (255dpi 2x)
Graphics processors
Apple M4 Pro
Color LCD (1728 x 1117 @ 120.00Hz)
USB devices
DYMO: DYMO LabelWriter 400
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftDataDetection.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswift_Builtin_float.dylib
/usr/lib/swift/libswift_errno.dylib
/usr/lib/swift/libswift_math.dylib
/usr/lib/swift/libswift_signal.dylib
/usr/lib/swift/libswift_stdio.dylib
/usr/lib/swift/libswift_time.dylib
/usr/lib/swift/libswiftsys_time.dylib
/usr/lib/swift/libswiftunistd.dylib
/usr/lib/swift/libswiftDistributed.dylib
/usr/lib/swift/libswiftSynchronization.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMLCompute.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftSwiftOnoneSupport.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftSpatial.dylib
/usr/lib/swift/libswiftPassKit.dylib
/usr/lib/swift/libswiftAppleArchive.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.38.24338.17002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.38.24338.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.38.24338.17002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.38.24338.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.38.24338.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.38.24338.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.38.24338.17002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.38.24338.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.38.24338.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.38.24338.17002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.38.24338.1002
Hi Gordon -
Since this is crashing for you in Rhino 7 (in Rosetta2), I would like to check how that goes in Rhino 8 or Rhino 9. What file format is that 636 MB file in? Could you upload this file to us so that we can take a look?
Apart from that, you could probably use something like CloudCompare to decimate the mesh.
Thanks Gord
How are you reducing? If you run Check you will see a number of degenerate faces, run Mesh Repair and then weld before doing and Reduction.
If you can upgrade your OS and Rhino there are a lot of mesh improvements through the years. I did crash on an M5 trying to run Rhino 7 on your file. Rhino 8 had no issues with the repair and reduction.
