x2design
(Hello)
February 27, 2021, 10:03am
1
Hi!
I’m just curious about if someone else is experiencing trouble with Rhino 7 crashing from time to time when trimming lines? I just bought the upgrade version, have never encountered the problem with Rhino 6…
I’m drafting in Rhino, thus no complicated geometry or curves. Only simple lines and circles. During this worksession Rhino 7 has crashed three times while entering the trim command.
It’s getting annoying since I have to redo work, I’m trying to save as much as I can now … how can I fix this?
Best
Li
nathanletwory
(Nathan 'jesterKing' Letwory)
February 27, 2021, 11:12am
2
Please post with the text result from the Rhino command _SystemInfo
x2design
(Hello)
February 27, 2021, 11:14am
3
nathanletwory:
_SystemInfo
Hi Nathan, thanks for the reply. Here you go!
(During this time I have run in to three more freeze and crashes while trimming curves and lines)
EDIT: An observation, it seems like it is more likely to crash when I’m trying to trim a circle. Maybe that info helps …
System Info below:
Rhino 7 SR3 2021-2-8 (Rhino 7, 7.3.21039.11201, Git hash:master @ 7bcc02a54515376cb2bd3d05f62d9473ab4bc38c)
License type: Commercial, build 2021-02-08
License details: Cloud Zoo
Windows 10.0.19041 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Plugged in [79% battery remaining]
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 3-9-2020 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 2080 Super with Max-Q Design (NVidia) Memory: 8GB, Driver date: 12-31-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 461.09
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-31-2020
Driver Version: 27.21.14.6109
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V6\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.3.21039.11201
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.3.21039.11201
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.3.21039.11201
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.3.21039.11201
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.3.21039.11201
nathanletwory
February 28, 2021, 10:25am
4
I am unable to reproduce freezing and crashing while trimming.
You could try with the V-Ray plug-in disabled, although I highly doubt thhat is related.
x2design
(Hello)
February 28, 2021, 11:44am
5
Thanks for the reply. Ok I’ll try that.
Also I’ve just updated the version, maybe that will fix it.
Best,
Li
