Hi!
Imported .dwg (AutoCAD 2004) files cause my computer to lag and crash when moved around. I tried exploding them and it worked to a point, but the Rhino model eventually crashes nonetheless when I’m working with it.
I’m using Rhino 7 on a Surface Pro 6, 8 GB RAMA-40-P-020.dwg (379.3 KB) A-40-S-001.dwg (473.5 KB) A-40-S-003.dwg (1.1 MB) . It can be that my computer is too slow to run Rhino, but I doubt it.
Please find attached the dwg files I’m working with. Thank you!
Well, from what I can see above, your computer does not meet the minimum spec for Rhino 7 - as far as video memory goes. Plus your driver is out of date, I would try updating that first.
Maybe the driver update will help, but it’s still not going to be an ideal solution for heavier display tasks.
