Rhino 7 Feature Text Formula Enhancement
Text can dynamically update. For example, title blocks and notes can update with model changes by using the formulas (Fx) feature in Text.
Next Steps:
Feature Introduction:
  • Access User Text from the Document, Layout or Object: Pull user text along with user text with functions into blocks and layouts more easily.
  • Math Formulas supported: Using the Python Math library
  • Unit System support
  • Nest formulas for advanced formatting
  • New data sources:
    • Layout UserData
    • Layer Name
    • Object layer
    • Detail Scale
    • Number of Pages
    • Point Coordinate
    • Area and Volume
    • Page Width, Height, and Name
First of all, great addition to the usertext toolset!
To display the DetailScale of the current layout in a titleblock I would like to specify a name, or the current layout’s first created Detail
Currently you can only refer to the detail view by it’s object ID
So you have to specify it for every layout.
EG. one could label the deail view D1 and refer a ‘D1DetailScale’ Layout user Text
So the title block scale label text can refer to %<LayoutUserText(“D1DetailScale”)>%
Great Feature! can these features be accessed somehow in grasshopper?
That’s an important enhancement, thanks for that feature!
Anyway, could you please elaborate if and how text fields work with blocks?
Example: a height annotation that displays the coords of the point it is placed at.
Thanks a lot!
With the Block attribute text how do i edit it once i have inserted the block? Can we have block attributes that are instance based and family based? so one block attribute if updated would change the field in all of situations of the block and then have instance attributes that only effect that individual block?
They do work with Blocks as attributes: https://discourse.mcneel.com/t/new-in-rhino-7-block-attributes/
RH-57962 is fixed in the latest WIP
Awesome new feature!
Wish: It would be awesome if we had a “Result” field in the dialog which we could copy/paste from.
Often I’ll want the results of a text formula somewhere else, ie: A file name, spreadsheet, etc. To be able to copy the results directly, rather than retypiing, will reduce the chance of errors and save time.
hi there,
this is regarding Usertext export to csv i am getting formula text instead of values also grasshopper shows the same output export csv.csv (55 Bytes)
how can i get values insted of formula text
Regards,
Ranjit
I agree. Much needed feature. I would also like to have the “Result”-option and also an easy access to standard “rounding”, such as “floor” and “ceiling” plus a way to limit the number of decimals in “volume”, “area” & “curve lenght”.
Finally it would be preferable to use an objects “Rhino-name” over ID if is such a name exists.
Maybe the “Select Object/Pick Object” button could be moved to the first dialogue-box, if a “dummy ID” existed in the text-box? If so, you could “preselect” the text and just pick a new object to fill-in the ID.
Ideally you could add a semi-complete text as your default to the “New Layout” (Printer, Papersize, Paperorientation, Layoutname) and “New Detail” (Modelscale, “@“, Papersize)?
