Rhino 7 error: black screen
I have just started working on my new computer. The work that I do is mostly 2D drawings. I use Rhino 7.
I can open most of the files and they work well. The computer is very slow - I suspect it is because of low RAM storage which is 4GB.
The files that do not work are the ones that someone worked on with Rhino 8 - they would save as Rhino 7 so that I could work on them. The files are not that heavy - 2,530 KB - 11,346 KB
The file is read successfully (which is displayed in command line). The view is fully black. When I ‘SelAll’, Rhino responds and selects all elements. Also, when I randomly try selecting objects - they do select.
I checked the color of the background - set to grey.
I reduced OpenGL level.
Unchecked the GPU Tesselation.
Modified the Antialiasing settings.
None of these seem to improve the situation.
Here is also the information I get from ‘SystemInfo’
Rhino 7 SR38 2024-12-3 (Rhino 7, 7.38.24338.17001, Git hash:master @ 97e36efa02d7f71638988290bb2d190fcf1b18c5)
License type: Commercial, build 2024-12-03
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 3.3Gb)
Computer platform: LAPTOP - Plugged in [67% battery remaining]
Primary display and OpenGL: AMD Radeon™ 610M (AMD) Memory: 1GB, Driver date: 8-17-2026 (M-D-Y). OpenGL Ver: 4.6.0 Compatibility Profile Context 26.8.1.260806
Integrated accelerated graphics device with 5 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 8-17-2026
Driver Version: 32.0.21045.5002
Z-Buffer depth: 24 bits
Total Video Memory: 2214 MB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.38.24338.17001
I would appreciate your help. Thank you.
Have you tried changing the Display Mode?
If you start a new file and add a few objects is it displayed properly?
Does the problem occur with only the one file, or with any file?
Hi @Gaba_Nycz,
Unfortunately, your system’s video display doesn’t meet the minimum requirements of 4GB of video memory. I’m pretty sure this is the cause of the black screen.
BTW, your system also does not meet the minimum memory requirements - 8 GB memory (RAM) or more is recommended.
– Dale
this page may help-
unplugged, your machine is defaulting to the onboard video unless you force it not to in your video card driver settings.
I’d do a clean install of a fresh video card driver then look at the windows settings in this thread.
the video card setting are for an nvidia, but if there is something similar for amd I’d set it to always force to the video card.
but Dale is right in his assessment… this machine does not meet our system requirements so the performance is going to be meh at best… but we should be able to not have black screens…
