Rhino 7 - Curve Length showing value ####
In a model I’m trying to measure the length of a Curve but it keeps showing the value ####.
The same applies to a textbox where an auto-date value should display but this shows #### instead of the date as intended.
As this might be a script related issue I tried a reinstall so system defaults would be restored but the issue is still there.
This is difficult to find out without a file.
I was able to reproduce the #### with a typo in the Text Field Expression so that might be a starting point…
Hi Martin,
Thanks for your reply. I’ve attached a file in this reply
Attached is the Rhinofile with a couple of models > 3D original shape + coresponding 2D views with dimensions (created using: Drafting/Create 2D-draft) aswell as a single arc-line + datestamp
Model R2500.3dm (378.3 KB)
Curve length:
It’s a newly created dimension line, so therefore shouln’d be a typo (as it’s automated > Dimension/CurveLengthDimension).
I don’t think its related to the shape i created as i’m creating using 2D extracted from that shape “drafting/Make 2D-drawing” to begin my measurements (so dim-line is not lost in the 3D dimension).
Even with a “clean” new single arc-line the length measurement is ####
Date/timestamp
Not just in this new drawing but also in old drawingfiles (that used to work previously)… now show the date as ####. The textfield indicates %<Date(“d-M-yyyy”)>% which should be correct as far as I can tell
I just opened your file in Rhino 8 and this is how it looks:
Yes that’s what it should look like
Mine looks a bit different.
It looks correct in Rhino 7 here too.
Hi Dennis -
Please try to disable the 3rd party plug-ins that you are running and restart Rhino. Does that make things work as they should?
  1. unstalled Enscape render (+system reboot) which had a plugin,
  2. removed IFC toolbar in the (properties/Toolbars/File list)
  3. disabled all plugins (properties/Plug-ins) curently in use
After system reboot and rhino restart still same output.
Hi Dennis -
Please run the Rhino SystemInfo command and copy-paste the result here.
Rhino 7 SR34 2023-9-24 (Rhino 7, 7.34.23267.11001, Git hash:master @ a37d83041828484840f2448d5b3e3770e46694f9)
License type: Commercial, build 2023-09-24
License details: Stand-Alone
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Plugged in [98% battery remaining]
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 12-21-2022 (M-D-Y).
- Windows Main Display attached to adapter port #2
Primary OpenGL: NVIDIA T500 (NVidia) Memory: 4GB, Driver date: 5-30-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 529.08
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-30-2023
Driver Version: 31.0.15.2908
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.34.23267.11001
Hi Dennis - can you select one of the incorrect-looking leaders and take a screen shot, or copy/paste what shows in Properties?
Hi Wim,
After disabling all plugins as mentioned in my previous post (step 3) I just now re-enabled all plugings (properties/Plug-ins/enable manually checking each item) which seems to have solved the problem (for now).
-Dimension for curves show as intented
-Date/timestamp work again in my old drawings.
Thanks for helping find a solution.
