Experiencing an issue when trying to open a Solidworks assembly. See screenshot.
Monitoring system when attempting to open the file, there is no memory usage spike, very little system memory is being used.
It is a large assembly. I can open the same file, however, if exported to STEP or IGES.
I really need to preserve the assembly structure, though, so those export options are not ideal.
System is 64bit, 32gb RAM, i9 processor
Any help would be greatly appreciated!
Tim K
Addition- Rhino also “soft crashes” when trying to open the assembly- ie; “freezes” and has to be shut down through task manager and restarted.
Hello - if we can have the assembly and any part files that go with it, please send to tech@mcneel.com, with a link back here in your comments.
Please also run SystemInfo in Rhino and copy/paste the results here.
Windows 10.0.19041 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro P1000 (NVidia) Memory: 4GB, Driver date: 2-23-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 461.72
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 9-24-2020 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-23-2021
Driver Version: 27.21.14.6172
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Orca3D V2\Orca3D.rhp “Orca3D” 2.0.19.0
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
This is almost certainly a Rhino problem. I have the same issue now when I try to initiate a render with V-ray.
Rhino freezes. The command line then “seems” to function, ie; accepts commands and commands are shown on the comand line, but Rhino is actually frozen and commands aren’t executed. The model can still be manipulated in the graphics view.
