Hi all,
I need help regarding an installation. After installation, Rhino crashes after logging in.
I am able to go through if I use serial number option but I need to login as the license is shared.
I have tried, uninstalling and fresh installation, does not work. I also tried to enter serial number and then switch to login and it still crashes.
If Rhino crashes after installation, it is generally a better idea to repair the installation than to reinstall. Repair will reinstall the .NET stuff from Microsoft that Rhino depends on.
I looked at the crash reports you had sent in. They all pointed at a crash in a DLL that is known to inject itself into processes. Disabling that or just simply removing it altogether will ensure this DLL doesn’t inject itself. And thus no longer causes the crash.
The crash dump file is written to the desktop. When you send in the report, that gets automatically deleted. So you can look at that file prior to sending in the report.
