Rhino 7: command prompt loses focus when selecting geometry
Hi! Hope I’m posting this in the right part of the forum, or should it go to PaperCuts instead?
On Rhino 7, whenever I click away from the Command Prompt (e.g. to select some geometry) it loses its focus and any input I write on the keyboard (commands, for example) is ignored. If I click inside the Command Prompt again, my written commands appear as normal, but as soon as I click outside of it, the problem reappears. It’s not a big issue, but it can get quite annoying after modelling for a while.
Am I missing some options that I need to configure?
Cheers,
Pol
Duplicate post: Rhino 7: command prompt loses focus when selecting geometry
@polforeman You can delete your post by clicking on the three dots icon near Reply below the post, and then clicking on the trash can icon.
Hi -
I’ve deleted the duplicate post, thanks @davidcockey!
Pol, could you please run the Rhino SystemInfo command and copy-paste the result here?
Hi! Thanks for deleting the double post. I got a “server error” both times when posting so I assumed it hadn’t been posted at all. When I checked the newest posts there was nothing there.
Running Rhino in Safe Mode did not solve the problem.
Anyway, here is the SystemInfo:
Rhino 7 SR1 2020-12-8 (Rhino 7, 7.1.20343.09491, Git hash:master @ 350b20978b4fcd75493212fbd3c4248983612f86)
License type: Kommerziell, build 2020-12-08
License details: Cloud Zoo
Windows 10.0.18363 SR0.0 or greater (Physical RAM: 16Gb)
Primary display and OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 1-31-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 442.23
> Integrated acclerated graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-31-2020
Driver Version: 26.21.14.4223
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\Fologram for Rhino (468a328b-20d9-494b-b9e1-cbe9f827d3a2)\2020.2.2.0\6\Fologram.IO.Rhino3d.Win.rhp “Fologram for Rhino” 2020.2.2.0
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Twinmotion Direct Link 2020.2 (e24ee14a-9514-47da-8fe6-f6e61b20160e)\Twinmotion Direct Link 2020.rhp “Twinmotion Direct Link 2020” 1.0.6.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.1.20343.9491
This might be unrelated to the problem, but I realised that the command prompt also has no autocomplete.
The problem seems to be gone, after closing the Macro Editor panel and restarting Rhino (I had tried restarting Rhino before, that was not the issue). In case anyone reads this post looking for solutions.
Autocomplete is still not working, though.
@polforeman Is autocomplete turned on?
Options > Rhino Options > Appearance > Command prompt > Autocomplete commands
It wasn’t! Works perfectly after turning it on.
Thank you so much!
