Hi, this is my first post on the forum, so hopefully I put it in the right category and it isn’t too long or missing obvious information.
I’ve had a search through the forum but can’t find anything exactly like the problem I’m having, I did find this post, Crash when scrolling
It seemed more specific than my issue - but as it involves rendering and an AMD gpu maybe they’re related?
I’m not sure if this is a hardware issue or software issue, but I’ve been having problems with rendering since upgrading to Rhino 7, specifically trying out PBR textures.
It breaks down into two issues, the first I sort of resolved through bypassing it, the second is possibly related to the first and a bit more problematic.
I upgraded my machine from a Quadro M4000 (that had been in my previous machine) to a Radeon 5700xt a year ago, this worked fine with Rhino v6, and everything seemed to run OK.
The first problem I had was running with a rendered view in Rhino v7 with just the AMD card it would sometimes throw up a small window that said something similar to ‘Server is busy’ with a greyed out button and a ‘switch to …’ button.
Pressing the 'switch to. . ’ button opened windows start menu, I could launch a second instance of Rhino, but nothing I tried would remove the pop-up window or close the first Rhino window other than a force quit from task manager.
I found two ‘solutions’ to this problem, one was setting cycles to CPU rendering, which was much slower and less responsive, the other, which I stuck with, was to re-install the Quadro as a second card and use it just for CUDA in cycles.
This seemed to work really well, especially for keeping Rhino responsive while having a rendered view visible.
. . . that’s also my explanation for having a possibly slightly odd combination of graphics cards.
Then as I experimented more with textures I came across my second problem:
Rhino will just disappear without warning while rendering, this can happen in the viewport and but mostly in the dedicated render window.
It happens pretty consistently, The model I first noticed it one wasn’t particularly complex, but had 4 3K PBR materials applied to it. I recreated the same situation with the model with task manager open and noticed while rendering, along with the M4000 chugging along with ~90% ‘Compute_0’ and maybe 6Gb of VRAM used, the 5700xt’s VRAM would creep up in usage until it hit 8Gb, the same with system RAM it keeps creeping up until I hit 90%+ usage, at that point it will sit apparently stable for a few minutes more, but then Rhino will just close, or more accurately disappear, without error message as if it hadn’t have been running at all.
Just at that moment there will be a 100% spike in both the M4000 and 5700xt’s, usage.
I also monitored temperatures, the 5700xt never gets above 60ish, the M4000 sits at about 71, so neither are at danger of overheating.
I repeated the set up with a simple scene, a sphere, a cube and a ground plane, all with PBR textures and the same thing happens when I go to render it, RAM usage creeps up until it hits it’s limit, both GPU’s usage spike and Rhino closes.
I tried using ProRender as the renderer, it displays the same behavior, but with some of the textures not rendered properly and no focal blur is applied, but thats a different issue I guess.
I also tried CPU rendering in cycles, which worked better, but the 5700xt’s memory usage still rises until it hits 8Gb and the system RAM now rises to 98% then drops to 74% and repeats the cycle a couple of times before crashing in the same way, with a spike in both GPU’s usage and Rhino disappearing at the same moment.
It takes longer to crash, but maybe that’s just proportional to the slower speed of CPU rendering.
With CPU rendering Rhino does manage to make an autosave file and recognize that it didn’t close properly, which is more than with CUDA rendering or ProRender crashes.
I would assume if it was simply a lack of RAM I’d get a specific ‘out of memory’ type error and Rhino would close a bit more gracefully.
I’m hoping this is just a software bug relating to the AMD graphics card that can be resolved, given the current GPU market I really don’t want to have to upgrade from my 5700xt anytime soon, and I would prefer not to have to go back to the M4000 as my main GPU.
Here’s my systeminfo:
Rhino 7 SR2 2021-1-21 (Rhino 7, 7.2.21021.07001, Git hash:master @ 96ff97351fbdf5d2acdeaf781aea1577f2ff60f7)
License type: Commercial, build 2021-01-21
License details: Cloud Zoo
Windows 10.0.18363 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: AMD Radeon RX 5700 XT (AMD) Memory: 8GB, Driver date: 12-4-2020 (M-D-Y). OpenGL Ver: 4.6.14757 Compatibility Profile Context 20.12.1 27.20.14501.28009
> Accelerated graphics device with 8 adapter port(s)
Secondary graphics devices.
NVIDIA Quadro M4000 (NVidia) Memory: 8GB, Driver date: 12-11-2020 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 5-15-2020
Driver Version: 26.20.15029.27017
Z-Buffer depth: 24 bits
Total Video Memory: 8176 MB
C:\Users\Jon\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\AMDDenoiser\0.4.1\AMDDenoiser.Windows.rhp “AMDDenoiser.Windows” 0.4.1.0
C:\Users\Jon\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.0\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.0.0
C:\Users\Jon\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\ProRender\1.0.0.0\ProRender.Windows.rhp “ProRender” 1.0.0.0
C:\Users\Jon\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\raytraced-materials\0.1.3+v6.15\RaytracedMaterials.rhp “Raytraced Materials” 0.1.3.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.2.21021.7001
