Rhino 7 can't be started on windows 11
Hi there.
Since I installed Windows 11 on my Computer, I am not abble to start Rhino 7.
Are there someone with the same problem or someone who had the same problems and could solve it to give some help?
Thank you in advance.
Hugs Archie
Hi Archie -
Reboot your machine. Then, from Windows Control Panel → Programs, right-click on “Rhino 7”, pick “Change”, and then repair the installation.
Wim’s suggestion is the likely fix.
If that doesn’t sort it, report back and we’ll try the next steps.
Hi Wim.
Thank you for your information.
I did it and now everything works propperly.
Hugs
Archie
Hi John.
The sugestion of WIM has worked.
Thank you all for your help.
Hugs
Archie
