I am using Rhino7 Windows. On the last day, I can open the file and edit it. But today I cannot open the file. Other rhino file works well. Does somebody know how to deal with it?
Thank you.
Thank you.
Your license on our side looks fine.
What specific error message are you seeing?
It appears to be hanging when loading the V-Ray plugin.
Start Rhino in Safemode, disable the V-Ray plug-in in Options > Plug-ins.
Restart Rhino normally (not safemode),
Any luck?
How to start Rhino in safemode?
Thank you.
Hi -
On your keyboard, use the Windows key and type “Safe”. Rhino in safe mode should pop up in the list that appears.
Since you say that other files open fine, you could just start Rhino without loading a file and disable V-Ray in the plug-ins manager. Then restart Rhino and open your file.
Also, when you start Rhino normally (without opening a specific file), please use the SystemInfo
command and copy-paste the result here.
Here is the information.
Rhino 7 SR12 2021-11-9 (Rhino 7, 7.12.21313.06341, Git hash:master @ 5590153808223b57a9f41516a969fd949aa81bff)
License type: Educational, build 2021-11-09
License details: Cloud Zoo
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Unplugged [99% battery remaining] ~100 minutes left
Primary display: Intel(R) UHD Graphics 620 (Intel) Memory: 1GB, Driver date: 9-6-2020 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1060 (NVidia) Memory: 6GB, Driver date: 10-26-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.47
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-26-2021
Driver Version: 30.0.14.7247
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.12.21313.6341
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.12.21313.6341
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.12.21313.6341
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.12.21313.6341
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.12.21313.6341
C:\Users\zzcfq\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
Hi -
Thanks. That looks fine.
Can you post the file that does not open?
If you’d rather not send it on a public forum, you can upload it on Rhino - Upload to Support. If you chose that option, make sure to copy the URL of this thread into the comments field on that page.
