hi Steve, you can call anywhere in the US for free (e.g. from outside the US) using https://hangouts.google.com, at least for a while longer (it now shows a notice they’re going to discontinue the service). I use it all the time to call family.
Hi everyone.
I have a solution:
first step: Tools > Options > View > OpenGl: turn off/ set none: GPU Tessellation
second: Tools > Options > Advanced > then turn off: Rhino.Options.OpenGL.UseHardwareDriver
Thanks for the solution, HungaroCAD Budapest and Rhino Barcelona.
Have a nice day!
Please note that this is ONLY a solution if you are running very old or underpowered hardware and should only be applied when all other options have been tried. You are basically crippling Rhino to run on the bare minimum of instructions in terms of graphics, and you use none of the (potential) power in your graphics card.
-Jakob
WAIT!! before you do this… make sure to check all your graphic driver dates.
if all you have is an intel hd, grab this tool and update your intel driver.(IMPORTANT!! don’t use the update driver function of the device manager it’s a complete POS and does NOT work)
update your intel drivers, restart your machine and try rhino again.
if it fails, don’t cripple the gpu as stated above, use the open GL slider instead. drag it one click to the left at a time and try rhino. if it does not work, drag one more click to the left until it works correctly.
