dan
(Dan)
41
Rhino WIP for Windows 7.0.19176 is now available
Bugs Fixed:
- CommandPaste: Paste command haywire (RH-53368)
- Display: In EdgeContinuity, Labels drawn with CRhinoDisplayPipeline::DrawDot() need tuned up a little (RH-49158)
- GumballAlignment: “Align to Object” does not work for SubD edge point (RH-53281)
- Join: Joining SubDs makes Brep when input is prepicked (RH-53354)
- MeshIntersect: Failure case (RH-53205)
- SubD:
- Deleting a control point in a SubDFriendly+ curve is off by one, and makes the curve SubDFriendly (RH-53258)
- ON_SubD::SplitEdge makes SubD invisible (RH-51512)
- Preview not available (RH-52946)
Enhancements:
- Display: Sort text dots by depth (RH-31915)
- Section: Add SubD support (RH-53228)
- SubD: Add SubD support to EMap and Zebra (RH-49781)
Features Added:
- Properties: Add Per Object to “Draw Line Between Extension Lines…” (RH-52941)
- SDK: RhinoCommon: SubD.IsClosed property (RH-53341)
SDK Enhancement:
- SDK: RhinoCommon: Add QuadRemesher functionality to RhinoCommon (RH-52444)
brian
(Brian Gillespie)
42
Bugs Fixed:
- 3DFace: Picking the first point should end the command (RH-53269)
- BoxEdit: Buttons hidden (RH-53393)
- Contour: Contour makes SubD invisible (RH-53309)
- Display: Grasshopper point cloud colours are mixed up (RH-50767)
- FilletSrfCrv:
- Isolate: Isolate and save (RH-52716)
- Panels: Panels missing (RH-53410)
- QuadReMesh: Can only select one object with post-selection (RH-53539)
- RDK: CLBP_CRC32::Chop(float) - generates FPU exceptions - check that f is not a nan or unset value before converting to int in Chop. (RH-52548)
- SubD:
- :AppendDisjoint() for Lowell (RH-53440)
- Direction is flipped by the Mirror command (RH-52563)
- Export SubD objects as breps to IGES, STEP and DWG (RH-41169)
- TextField: DimCurveLength gives an odd value on SubD edges (RH-51689)
- Toolbar:
Crashes Fixed:
- Delete: Crash when deleting SubD faces (RH-53456)
- No Subsystem:
- RhinoCore!CCommandTestFilletSrfToRail::RunCommand – Access Denied (RH-52802)
- RhinoCore!CCommandTestFilletSrfToRail::RunCommand – Access Denied (RH-53332)
- tl!TL_Distance – Access Denied (RH-52801)
Features Added:
- No Subsystem: New command (RH-52029)
- SubD: New command (RH-52059)
- QuadRemesh: New command to create quad meshes from surfaces and meshes.
SDK Enhancement:
- SDK: RhinoCommon:
- Add GetMesh options to existing primitive getters (RH-53487)
- Needs a Torus picker (RH-53461)
- SubD: Minimal SubD .NET SDK (RH-53195)
UI Changes:
brian
(Brian Gillespie)
43
Rhino WIP for Windows 7.0.19189 is now available!
Bugs Fixed:
- Annotation: DimRadial: Off the curve (RH-53386)
- Cap: Should not convert a SubD to a Brep (RH-53364)
- Installer: Make sure Cycles renderer installs in V7 (RH-42877)
- MeshIntersect:
- MeshSplit:
- QuadMesh: Does not return a valid mesh if Smart UseSurfaces is on (RH-52923)
- QuadReMesh:
- Splash and About: RhinoSplash Resource Warning (RH-53544)
- SubD:
- C++ SDK cleanup - clearly distinguish between control net points, subdivision points, and surface points (RH-53532)
- SubDTorus is an unknown command (RH-52155)
- Toolbar:
- New in V7 toolbar: Typo in Named Selections menu (RH-53379)
- Stitch icon on SubD tb needs tooltip refinement (RH-53500)
Cosmetics:
- QuadReMesh: Move checkboxes to the left (RH-53614)
Enhancements:
- Cap: Should work on SubD and Mesh objects (RH-49842)
- MeshIntersect: Change to use new MeshXtor (RH-41981)
- Pipe: Add SubD support (RH-53203)
- QuadReMesh:
- QuadRemesher plugin needs to be included in wip 7 installers (RH-52976)
- Unweld angle option causes issues with remeshing certain meshes (RH-53632)
- SubD:
- Change to use new GetMesh (RH-53503)
- Change to use new GetMesh (RH-53515)
- Subd Properties should report if a selection is closed (RH-53482)
Features Added:
- MeshSplit: Change to use new MeshXtor (RH-52094)
- QuadReMesh: Create new UI and View Model for new Quad Mesher (RH-52439)
- SubD:
Regressions Fixed:
- NamedCPlane: Named CPlane doesn’t do anything on RH7 WIP (RH-53360)
- Subobject Selection: Subobject selection broken (RH-53654)
SDK Enhancements:
- SDK: Rhino.Input.Custom.GetEllipsoid should accept int value to change vertical /around faces (RH-53527)
- SDK: RhinoCommon: Requires an Ellipsoid picker (RH-53466)
Usability Problems Fixed:
- RemoveCrease: Inconsistent picking with Crease command (RH-53267)
- ToSubD: Creates open SubD when input mesh is closed (RH-41476)
dan
(Dan)
44
Rhino WIP for Windows 7.0.19197 is now available!
Bugs Fixed:
- BooleanUnion: BooleanUnion failure between pipe and sphere (RH-53304)
- CullDegenerateMeshFaces: Instance where ON_Mesh::CullDegenerateFaces() and ON_Mesh::CullDegenerates() does not remove bogus faces. (RH-53708)
- File IO:
- MeshSphere: Set Subdivisions default to 2 (RH-53729)
- OpenNURBS: ON_PhysicallyBasedMaterial doesn’t get textures added/removed (RH-52509)
- RDK: SubD object can not display in Raytraced display mode (RH-41346)
- SDK: GHPython: GhPython not working (RH-53648)
- SubD: SubD example for Dale (looks inside out or something) (RH-53545)
Enhancements:
- File IO: In Rhino 7, support SubD objects in STL, RAW, VRML, …, and other “simple mesh” file formats export (RH-50429)
- Loft: Loft/Sweep1/Sweep2 - New SnapToKnots option (RH-52200)
- Project: Make Project command support SubD vertices (RH-53434)
- Pull: Support SubD vertices (RH-53329)
- Select: Make Mesh edges pick as Curves (RH-51830)
- SubD: Add test function to ON_SubDEdgeChain that determines if it’s convex. (RH-53546)
Features Added:
- Grasshopper: Add a Sub-D data type + Parameter (RH-51494)
- Gumball: Add SDK tool to move a single SubD surface point to a specified new location. (RH-53526)
- MergeFaces:
- MergeFaces - make it works on SubDs and meshes (breps later) (RH-51981)
- New command (RH-53720)
- PackageManager: New command (RH-47318)
SDK Enhancement:
- SDK: GHPython: Allows to use ExecuteFile (RH-53391)
- SDK: RhinoCommon: Retrieve curvature inflection and min/max radius points (RH-53747)
UI Change:
dan
(Dan)
45
Rhino WIP for Windows 7.0.19204 is now available!
Bugs Fixed:
- Cap:
- Does not flip normal when SubD is closed (RH-53810)
- Unexpected corners on SubD (RH-53809)
- Help: Hook up help page for QuadReMesh (RH-53165)
- Localization: Lights Panel - right-click menu > Properties doesn’t work (RH-52708)
Enhancements:
- Cap: Cap on SubD and Meshes should have options for Crease/Smooth cap boundaries and Ngons/Triangles cap structure (RH-53639)
UI Change:
brian
(Brian Gillespie)
46
Rhino WIP for Windows 7.0.19212 is now available!
Bugs Fixed:
- Grasshopper: Add Grasshopper SubD object (RH-53206)
- Grasshopper: Components: The Color typehint doesn’t compile. (RH-53920)
- MergeFaces: Make it work on mesh objects the same way it works on SubD objects (RH-53834)
- QuadReMesh: F1 doesn’t open the help topic (RH-53839)
- Rendering: Test VRay in Rhino WIP for Windows and see if it will render SubD objects (RH-53836)
- Rendering: Materials:
- Ensure that all material comparison and hashing functions are updated to include PBR (RH-53779)
- No anisotropic rotation texture found using ON_PhysicallyBasedMaterial::FindTexture (RH-53790)
- ShowEdges: ShowEdges - recently broken on SubDs (RH-53913)
- SubD: :CreateSubDBox() function (RH-53634)
- Subobject Selection: Crash when subobject selecting a mesh face (RH-53940)
- Toolbar: QuadRemesher macro and icon (RH-52930)
Crashes Fixed:
- Annotation: Hatch: System.ArgumentOutOfRangeException: System.ThrowHelper.ThrowArgumentOutOfRangeException (ExceptionArgument argument, ExceptionResource resource) (RH-53824)
- NamedSelections: ArgumentNullException: Value cannot be null. Parameter name: source (RH-53814)
- Patch: opennurbs!ON_Surface::NurbsSurface – Access Denied (RH-53819)
Enhancements:
- File IO:
- Mesh density of SubD can’t be controlled (RH-53943)
- Support SubD objects in OBJ export (RH-50425)
- Grasshopper: Group insertion order matters based on content (RH-53921)
- MergeFaces: Delete vertices or edges without leaving holes on SubD or Mesh (RH-51983)
- MeshSphere: Add Ico and Quad options to MeshSphere command (RH-41559)
- QuadReMesh: Add Multi-Axis symmetry to QuadRemesher (RH-53793)
Features Added:
- Grasshopper: Grasshopper - New component “Mesh from Sub-D” (RH-53448)
- Grasshopper: Components: New Sub-D from mesh component (RH-51495)
- QuadMesh: Mac version of QuadRemesh (RH-53378)
- SubD:
SDK Enhancements:
UI Changes:
- Mesh: Face count options don’t match with SubDEllipsoid (RH-54017)
- QuadReMesh: Remove “On:” from options? (RH-53838)
brian
(Brian Gillespie)
47
Rhino WIP for Windows and Mac 7.0.19212 is now available!
Bugs Fixed:
- Display:
- Dashed lines display glitch (RH-43077)
- Linetype display is dodgy (RH-51554)
- SubD edges and isocurves always show now (RH-53624)
- Localization: Emap dialog needs more padding on right side (RH-53629)
- No Subsystem: RhinoCommon DrawGradientHatch System.AccessViolation Error when setting boundaryThickness parameter (RH-54095)
- QuadReMesh: Does not use the Creases on Option and should (RH-52921)
- Rebuild: Add a SubDFriendly checkbox to the Rebuild command (RH-53339)
- Rendering: Replace Rhino Render with Cycles engine (RH-44597)
- Toolbar: Change QuadRemesher to QuadMesh? (RH-53324)
Enhancements:
- CullControlPolygon: Supports SubD (RH-51149)
- DraftAngleAnalysis: Needs to work on SubDs (RH-53745)
- File IO: Add unit dropdown to Iges simple settings (RH-43390)
- MeshCylinder: New CapFaceStyle=Tri/Quad options (RH-53966)
- Zebra: Apply “Show edges and isocurves” changes (RH-54085)
Features Added:
Tasks Completed:
- Rendering: Phase out Cycles for Rhino plug-in (RH-44598)
UI Change:
- Display: Subd isocurves show up incorrectly in Emap (RH-53623)
brian
(Brian Gillespie)
48
Rhino WIP for Windows and Mac 7.0.19233 is now available!
Bugs Fixed:
- Annotation:
- Dim -> Vertical - not vertical in Top CPlane (RH-51445)
- Numeric text boxes in Dim Properties scroll too easily (RH-52437)
- Annotation: DimLinear: “Dimension line location (Horizontal Vertical)” options are reversed (RH-54136)
- Cap: Cap no longer produces joined subd (RH-54122)
- Circle: Deformable circle not created (RH-54114)
- ClippingPlane: Properties dialog doesn’t work (RH-53005)
- Dir: Flipping normal converts SubD to NURBS (RH-53680)
- Display:
- Esc doesn’t restore subd render mesh (RH-50787)
- Locking and sub-object materials (RH-53130)
- Silhouette curves and blocks in technical (RH-53300)
- Subd wires, edges and creases are aliased in technical modes (RH-54121)
- Eto:
- Dragging onto Eto (named item) dialog fails with DV_E_TYMED error on Windows (RH-52640)
- Modifier key events (RH-53024)
- Explode: Extrusions cannot be exploded (RH-54316)
- LayerBook:
- Add to toolbars (RH-52377)
- LayerBook > Advanced > InitialViews - make current initial view the default (RH-52489)
- Panels: Context menu shows 2 “Layer States” menu items (RH-54104)
- RDK: Selection lost when editing texture (RH-53207)
- Rebuild: SubDFriendly is not respected (RH-54088)
- SDK: RhinoCommon: Brep.CreateFromLoft failed when used with one point and one curve (RH-54074)
- ShowEdges:
- ShowEdges - recently broken on SubDs (RH-53913)
- ShowEdges on SubD - broken by recent changes in display code - worked a few days ago (RH-53132)
- Sphere: Many circle-based primitive commands fail (RH-54315)
- SubCrv: MarkEnds fails on edges (RH-53674)
- SubD: Check reports degenerate SubD geometry as valid (RH-52301)
- Sweep1: Fails with a closed cross section curve (RH-54314)
- Sweep2: Normal is flipped in preview with subd output (RH-54272)
- ToSubD: ToSubD on nurbs or extrusion sometimes reverses surface direction (RH-53374)
- Zebra: Add and Remove Object buttons don’t work on SubD objects (RH-51869)
Crashes Fixed:
- Ribbon: System.NullReferenceException: Commands.UI.RibbonOffsetCommandDialog.RibbonOffsetCommandDialog_Closing (Object sender, CancelEventArgs e) (RH-53818)
Enhancements:
- ClippingPlane: Port Clipping Plane UI to ETO (RH-53022)
- DivideAlongCreases: Displays options when objects are pre-picked (RH-53670)
- ExtractPt: Extracts vertices from selected mesh faces (RH-54022)
- InfinitePLane: Added AroundCurve option (RH-54287)
- Lasso: Added internal Undo option (RH-54037)
- LayerBook:
- Enhanced PrintLayerBook information. (RH-52375)
- LayerBook > Advanced > PrepareToSave - make it easy to apply finishing touches to a layer book (RH-52521)
- SDK: RhinoCommon: Add CapStyle to Mesh primitives (RH-54158)
- SelPrev: Recognize sub-object selection (RH-54096)
- Sweep1: Add SubD output option (RH-53904)
Features Added:
- Drag: DragCopy - New command (RH-53561)
- Inset: New command (RH-32697)
- LayerBook: LayerBook - New command (RH-52339)
- SDK: RhinoCommon: VS2019 RhinoCommon and GH templates (RH-53789)
** Regressions Fixed:**
- Zebra: Can’t preview analysis mesh when “Show edges and isocurves” is off (RH-54105)
SDK Enhancement:
- Annotation: Text: Add native bool function “HasMeasurableTextField” that will be wrapped by Rhino.Geometry.AnnotationBase (RH-54214)
- RDK: Rename RhMaterialEditor project to RDK project (RH-33760)
- SDK: RhinoCommon:
- Gradient Curves (RH-54176)
- Rhino.Display.DisplayPipeline needs DrawSubD (RH-53796)
Tasks Completed:
- Installer: Eto.Code editor assemblies need to be included in V7 installer for Windows (RH-54117)
UI Change:
- Inset: Add to menus (RH-51417)
- LayerBook: LayerBook - Add to menus (RH-54230)
- MergeFaces: Add to menus (RH-53721)
- Options: Display options - Move Surface settings from general to surfaces (RH-54137)
- PackageManager: Add to toolbars (RH-53499)
- QuadReMesh: Add to menu (RH-53675)
brian
(Brian Gillespie)
49
Rhino WIP for Windows and Mac 7.0.19239 is now available!
Bugs Fixed:
- OpenNURBS:
- ON_Texture doesn’t find normal texture (RH-52845)
- When converting ON_PhysicallyBasedMaterial to legacy material, Opacity -> Transparency is handled incorrectly (RH-52846)
- Osnap:Point: Point snap doesn’t work while revolution surface is visible (RH-54341)
- Panels: Save to file inactive (RH-54311)
- RDK: Adding a texture map doesn’t automatically check the checkbox (RH-53791)
- SDK: RhinoCommon: RhinoCommon QuadRemesh GetEnginePath needs updated for Mac version (RH-54344)
- Selection: Ctrl-click may not deselect object with control points be automatically turned on (RH-54384)
- SubD: SubD wireframe object picking is broken (RH-54369)
- TextField: Mechanism for getting nested InstanceObject when computing %<UserText “block”>% (RH-54332)
Enhancements:
- CursorTooltip: Point option displays coordinates when an object snap is active at the initial dragging point (RH-54338)
- Gumball: “Align to Object” supports hatch plane (RH-54385)
Features Added:
- Analytics: New command (RH-53608)
- Eto: auto indent for C# in CodeEditor (RH-54177)
SDK Enhancement:
- SDK: RhinoCommon: Expose CRhinoHatch::SetHatch (RH-54356)
UI Change:
- Analytics:
- BlendCrv: Rework Show Curvature as button instead of checkbox (RH-38091)
- MergeFaces: Add to toolbars (RH-53722)
- Toolbar: SubDEllipsoid and SubDTruncatedCone add to toolbars (RH-53524)
brian
(Brian Gillespie)
50
Rhino WIP for Windows and Mac 7.0.19246 is now available!
Bugs Fixed:
- Controls are not dismissed when properties panel is not in focus (RH-54530)
- Crash when clicking the middle stop (RH-54399)
- ESC incorrectly deletes a hatch or removes a stop (RH-54460)
- First move is rejected (RH-54531)
- Gradient editing does not support undo (RH-54461)
- Make the Hatch command dialog that matches the Hatch properties page (RH-51965)
- BoxEdit: Preselected objects do not enable BoxEdit UI (RH-54401)
- File IO: Import fails to undelete linetypes used by imported geometry. (RH-54036)
- Grid: Extends does not update in real-time (RH-54358)
- Rhino Inside: Rhino.Inside is throwing a license, loading error. There are a series of these (RH-53893)
- Selection: CRhinoGetObject::CustomGeometryFilter() isn’t called for SubD edges selected by double-click chaining (RH-54420)
- Smooth: Clipping plane impacts preview of Subd in Smooth (RH-54318)
- SubD:
- ON_SubD::SplitFace results in invalid SubD geometry (RH-50879)
- Updating SubD display override from GetPoint (RH-49796)
- Deleting SubCrv breaks the curve at its seam (RH-54383)
- Deleting SubCrv deletes previous curve offset (RH-54382)
- ViewCaptureToClipboard: Tile in viewcapture (RH-54116)
Enhancements:
- Bridge: Changing alignment and direction should not require vertex osnap (RH-53213)
- Delete: Delete SubD faces - new boundary edges should be returned selected (RH-53951)
- Display: SubD objects don’t support custom render meshes (RH-54465)
- InsertEdge: SubD support (RH-49860)
UI Change:
- Annotation: Hatch: Draw hatches in UI list boxes as non-inverted color even when selected (RH-54468)
- Annotation: Hatch: Gradient controls does not support Ortho (RH-54458)
brian
(Brian Gillespie)
51
Rhino WIP for Windows and Mac 7.0.19253 is now available!
Bugs Fixed:
- Annotation: Hatch: Color confusion (RH-54347)
- Annotation: Linetype: Not updated (RH-53956)
- ApplyShutLining: Shutlining doesn’t work on Subd objects (RH-54536)
- Bridge:
- Bridge - fails on these SubDs (RH-53064)
- Bridge command - unexpected creases (RH-53065)
- Bridge needs a option of alignment (RH-52684)
- Bridge options inconsistent (RH-53259)
- Bridge seam point (RH-52135)
- Bridge should use Weld as the default (RH-53602)
- Hard time selecting alignment dots (RH-53906)
- Limit edge loop selection to open edges (RH-46838)
- ClippingPlane: Subd objects don’t show clipping plane edges (RH-54471)
- Copy: Copying a SubD edge/point makes a copy of the whole SubD (RH-54664)
- Help: Help article for PrintDisplay should say the command isn’t sticky (RH-54387)
- MeshIntersect:
- MeshIntersect finds a few erroneous cases (RH-53626)
- Test case for intersections with weird triangle cases (RH-51182)
- MeshSplit:
- Make MeshSplit work with Infinite Planes (RH-53735)
- MeshSplit creates output which, when joined, has a non-manifold face (RH-44607)
- MeshSplit does not work on the tiny and redundantly pre-divided strip (RH-54275)
- MeshSplit failure (RH-54543)
- MeshSplit gets it wrong when splitting curve passes through multiple vertex point (RH-34559)
- Splitting a disjoint mesh removes areas of the mesh that do not get an intersection result (RH-42678)
- RDK: Delete curve and shut lining still shows the curve. (RH-52998)
- Rendering:
- Glow PEP data not initialized (RH-54492)
- New PEPs - DisplayHelp function missing on peps (RH-54490)
- Rendering: Texture Mapping: Subd objects don’t have a texture mapping property icon (RH-50789)
- Rhino Inside: Exceptions thrown when working with headless doc (RH-54552)
- Settings: UI - Assert fires when changing background color (RH-51376)
- SmartTrack: Smart Ortho typed distances (RH-54559)
Enhancements:
- Annotation: Hatch: Match hatch at creation time. (RH-37578)
- RDK: Import plug-ins should create RDK materials (RH-51432)
- SelChildern: New DeselectOthersBeforeSelect option (RH-54164)
UI Change:
- Annotation: Hatch: Enable new ETO Hatch create dialog as the default for wip 7 win & mac (RH-54555)
brian
(Brian Gillespie)
52
Rhino WIP for Windows and Mac 7.0.19260 is now available!
Bugs Fixed:
Annotation: History lost between sessions (RH-53874)
Annotation: Hatch: Match the gradient (RH-54636)
Annotation: Text: Move up the ‘Unit - Format’ drop down and view models to Annotation panel and AnnotationViewModel (RH-54213)
BlendSrf: Resetting the blend (RH-54658)
Curve: Adding SubDFriendly option breaks ‘U’ for Undo option (RH-54649)
Extend: Cursor tune up (RH-53852)
Extrusion Object: Cylinder extrusion direction (RH-54661)
Help: Cross reference for MergeEdge and SplitEdge (RH-54613)
Installer: Change default folder for Rhino WIP install (RH-54680)
MeshIntersect: MeshIntersect output is unexpected (RH-49281)
MeshSplit:
- MeshSplit fails to do anything (RH-25821)
- MeshSplit fails without an explanation (RH-30273)
- MeshSplit failure (RH-54541)
- This is a similar issue that fails to split (RH-53550)
Panels: Sun from Skylight in Lights panel (RH-53384)
Properties: Crash in properties pages (RH-54641)
QuadReMesh: Have Quad Remesh use RhinoCommon functions (RH-54325)
RDK: A way to add a childslot texture by giving the filename of the texture as a parameter. (RH-54574)
Rendering:
- New Pep system - Access to GetChannelValues for color picking in the rendered image (RH-54572)
- New Pep system - Splitter position from data source (RH-54571)
Rhino Inside: CRhinoDoc destruction on a background thread causes RDK asserts (RH-54565)
RibbonOffset: Offset to the wrong side (RH-54364)
Crashes Fixed:
Display: Rhino crashes when running the display regression tester (RH-54547)
Eto: Eto bitmap loading fails (RH-50624)
Rendering: Materials: Rendered mode crashes Rhino if procedural texture is in a material for a SubD (RH-54587)
Enhancements:
- Annotation: Describe locations for new controls in DimStyles (RH-52418)
- ApplyDisplacement: Displacement doesn’t work on SubDs (RH-54645)
- Bridge: Bridge should only select naked edges (RH-53260)
- DragMode: ControlPolygon mode works with a single mesh/SubD control point (RH-54148)
- Mesh: SubD objects do not create meshes with texture coordinates (RH-54603)
Meta Issue:
- No Subsystem: Test BOZO_MANUAL_ANNOUNCE (RH-54802)
SDK Enhancement:
- SDK: RhinoCommon: Add missing methods for quad remesher (RH-54628)
Tasks Completed:
- Properties: Replace V6 properties manager with new properties system and remove old manager (RH-52790)
- Annotation: Styles:
- Control for the Dimension Line When Arrows Are Placed on Outside (RH-50656)
- Expose Fit Arrow and Fit Text options in annotation style (RH-49911)
- Loft: -_Loft _RebuildCount=n not being interpreted correctly (RH-54665)
brian
(Brian Gillespie)
53
Rhino WIP for Windows and Mac 7.0.19267 is now available!
Bugs Fixed:
- Annotation: Hatch: Gradient controls missing in properties when a non-gradient hatch is selected (RH-54839)
- Block:
- Block attribute should display #### when user string is not found. (RH-54738)
- Add a check to make sure InstanceReference transforms are affine (RH-54856)
- Cycles: Texture in PBR material looks wrong in Raytraced (RH-54797)
- Display:
- Selection only highlights border curves of gradient hatches (RH-54308)
- Transparent PBR material doesn’t look right (RH-54764)
- Guides: SmartTrack off in the AddGuides command deactivates guides (RH-54647)
- Gumball: Gumball on sub-selected point cloud points (RH-54748)
- MeshSplit:
- QuadMesh: QuadMesh plug-in should be removed (RH-54826)
- QuadReMesh: ToSubd option in QuadRemesh dialog doesn't produce anything if Preview is not also checked (RH-54682)
- RDK:
- ChangeQueue.ApplyDynamicClippingPlaneChanges() not called interactively when moving a clipping plane (RH-35228)
- Click/Drag response needs adjustment for editing PBR textures (RH-54798)
- Rendering: Thumbnail previews are over or under exposed (RH-54699)
- PBR material doesn’t cast shadows in display (RH-54698)
- Custom Render Content preview is always sphere (RH-54763)
- BRDF/PB material (RH-54807)
- Rendering: Realtime SDK: ApplyClippingPlaneChanges not invoked after moving clipping plane (RH-53840)
- Stitch: Stitch location clumsy (RH-53264)
- Subobject Selection: Edge loop selection doesn't work if SubD is in front of polysrf (RH-54801)
- Textures:
- ToNURBS: ToNurbs - SubD to brep with bigger brep faces - issue on some "landlocked" patches (RH-54511)
- ToSubD: ToNURBS - SubD to brep with bigger faces - issue with creased edges / boundary edges (RH-54509)
Enhancements:
- Build Process: Compiler: Add Boost to the include paths of RhinoCore project (RH-54550)
- Cycles: Cycles RR material thumbnails (RH-54472)
- File IO: Add ability to omit view info from FBX export (RH-45835)
- Rendering: Materials: Linear workflow gamma correction should be optional for bitmap textures (RH-53432)
- RibbonOffset: Remember the settings (RH-54365)
Features Added:
- Cycles: Implement Raytraced clipping planes (RH-45741)
- TextField: Text field - page number - limit range (RH-42968)
Regressions Fixed:
- Mesh: Mesh - Cannot delete part of mesh by deleting its points (RH-54778)
SDK Enhancement:
- SDK: RhinoCurveBoolean C++ SDK function request (RH-47891)
- SubD:
- Add C++ SDK tool ON_SubD::CreateFromLoftCurves() to loft subds (RH-54809)
- Add ON_SubD::FindOrCreateVertex( control_net_point ) for Lowell. (RH-54810)
Mac-Only Changes
Bugs Fixed:
- CommandPrompt: Pasting a command to the command line does not automatically execute (RH-48912)
- Display:
- SubD edges and isocurves always show now (RH-54120)
- Clipping plane ‘Show Fills’ is not in the Display panel for Shaded modes (RH-54470)
- Control point transparency number formatter is wrong on Mac. (RH-54619)
- DragMode: ControlPolygon mode works with a single mesh/SubD control point (RH-54710)
- Licensing: UI: Mac Dark Mode - Cannot read licensing dialogs RH7 WIP (RH-50765)
- Options: Display preferences doesn't open to the active viewports display mode page (RH-53922)
- Rebuild: SubDFriendly is not respected (RH-54207)
- SDK: RhinoCommon: NumericUpDownWithUnitParsingUpdateMode.WhenDoneChanging Mac OS failure issue (RH-54295)
- SelBoundary: No SelID (RH-49458)
- Smooth: Clipping plane impacts preview of Subd in Smooth (RH-54476)
- Split: InfinitePlane bails splitting a polysurface (RH-54326)
- Toolbar: UntrimHoles left button tooltip and macro issues (RH-52569)
Incomplete Port:
- Selection: Chain select Mesh/SubD faces in command that only accepts faces (RH-51074)
- Toolbar: Add command button and keyboard shortcut for _NextViewport (RH-41250)
UI Change:
Windows-Only Changes
Enhancements:
- Selection: Chain select Mesh/SubD faces in command that only accepts faces (RH-50917)
Performance Improvements:
- Display: Objects with textures that have an alpha channel are treated as transparent by default (RH-54865)
brian
(Brian Gillespie)
54
Rhino WIP for Windows and Mac 7.0.19274 is now available!
Bugs Fixed:
- Cycles: PBR base color needs to be gamma corrected. (RH-54937)
- Display: SubD wires are Xray in Raytraced with texture applied in assigned material (RH-54708)
- DissolveEdge: Incorporate DissolveEdge into Delete (RH-54771)
- Fill: Flips normal of fill faces if crease is in the edge loop (RH-54243)
- Layout:
- Multiple delete layouts (RH-24893)
- Remove detail count column from Layouts panel (RH-54729)
- Remove column sorting (RH-54730)
- Use Document Display Precision in Layout Panel (RH-54901)* Rendering: Materials: Colors need to be gamma corrected (RH-54890)
Crashes Fixed:
- : Non-mesh object passed CustomGeometryFilter in GetNgonEdgeLoop (RH-53804)
- Append: Append crash (RH-51705)
- Mesh: Non-mesh object passed CustomGeometryFilter in GetFaceLoop (RH-53591)
- Stitch: Stitch crashes (RH-54903)
Enhancements:
- File IO: Added Import lights and Import cameras options (RH-54852)
- WeldEdge: Removed the selecting mesh/subD step (RH-49838)
Features Added:
- Cycles: Mirror alternate tiles doesn't work in Raytraced (RH-42743)
- Layout: Layouts Panel (RH-16967)
SDK Enhancement:
- SubD: SubDLoft - enhance selection tools and provide example for Lowell (RH-54776)
Tasks Completed:
- QuadrangulateMesh: Make it a hidden command so it doesn't autocomplete (RH-54821)
UI Change:
- Annotation: Hatch: Gradient hatch UI has too many columns (RH-54872)
- Layout: Add to menu (RH-54971)
- Layout: Improve duplicating layout (RH-54978)
Mac-Only Changes
Bugs Fixed:
- Cycles: PBR material with anisotropy renders with artifacts (RH-54935)
- Keyboard Shortcuts: Tap Alt to toggle copy options (RH-42275)
- Layout:
- Implement new Layouts panel on the Mac (RH-54503)
- Issues in the gear menu on Mac (RH-54977)
- Panels: Show Edges checkbox for shaded display modes is only half clickable (RH-54806)
- Textures: Display of existing textures (mac, 7) (RH-54858)
- Toolbar: Stitch icon on subd tb needs tooltip refinement (RH-53621)
- Display: Objects with textures that have an alpha channel are treated as transparent by default (RH-54892)
Tasks Completed:
Bugs Fixed:
- ApplyThickness: Render mesh modifier support for Subd (RH-54111)
- Cycles: PBR material with anisotropy renders with artifacts (RH-53686)
Crashes Fixed:
- : Non-mesh object passed CustomGeometryFilter in GetEdgeLoop (RH-52750)
- Bevel: ArgumentException: Invalid objects passed to BevelGetMeshEdgePoint (RH-52756)
Features Added:
- Grasshopper: Params > Geometry needs an empty subd component (RH-53973)
brian
(Brian Gillespie)
55
Rhino WIP for Windows and Mac 7.0.19282 is now available!
Bugs Fixed:
- Directional light shouldn't expose falloff UI since it doesn't affect directional lights (RH-54891)
- End color does not extend (RH-55042)
- Color gradient may not display while editing stops (RH-55044)
- Gradient stops won’t display when a model is re-opened in the same Rhino window (RH-55045)
- Bridge: Preview is not removed from display when Esc is used (RH-55030)
- Cycles: Starting a v7 Rhino Render should pause Raytraced mode if running (RH-54982)
- Display: SubD boundaries are not drawn (RH-54981)
- ExtractControlPolygon: A SubD object can not be converted to Mesh through the command ExtractControlPolygon (RH-55103)
- Grasshopper: Components: Grasshopper components not solving on Compute (RH-54156)
- Rendering:
- New Pep system - PickPointOnImage and PickRectangleOnImage missing (RH-54643)
- Crash when rendering (anything, any renderer) (RH-55017)
- Rendering: Materials: New custom materials have bogus textures in all four slots (RH-54958)
- Stitch: Stitch makes a mess (RH-54828)
- SubD:
- SubD surface texture mapping does not display in rendered mode (RH-54663)
- Creamy or Crunchy display - make picking work (RH-54999)
- Toolbar: Convert macros to python (RH-54426)
Enhancements:
- Lights: Light falloff / attenuation support in Display (RH-54883)
- OSnap:Between: Ortho support enhancement (RH-53774)
- SubD: Creamy or Crunchy SubD display - make CRhinoSubDObject have 2 VBOs - one for smooth and one for control polygon display. (RH-54965)
Regressions Fixed:
- Licensing and Validation: Running Rhino WIP makes Rhino 6 ask for license key (RH-54954)
SDK Enhancement:
- SDK: RhinoCommon: Wrap RhinoCurveBoolean function in C# (RH-54846)
- SubD: SDK tool - Make it possible to have disjoint SubD joins and return a map to show where appended vertices ended up in "this" (RH-54947)
UI Change:
- Layout: Easier re-arranging of pages (RH-37597)
Mac-Only Changes
Bugs Fixed:
- Annotation: Hatch: Crash on hatch select (RH-55006)
- ApplyThickness: Render mesh modifier support for Subd (RH-54899)
- ExtractSrf: Alt to toggle Copy (RH-42274)
- Properties: Crash on Properties > Material (RH-54985)
- UI Cleanup: Run single UI for gumball settings (RH-53034)
Enhancements:
- Display: Unwelded and naked mesh edges display with 2 pixels by default (RH-54994)
Tasks Completed:
- Layout: Missing help button on Mac (RH-55013)
Bugs Fixed:
- Annotation: Hatch: Apply color change when Select Color dialog is closed (RH-55046)
- Properties: Assign Material - does not work through command line (RH-54976)
Enhancements:
- Display: Unwelded and naked mesh edges display with 2 pixels by default (RH-54912)
Tasks Completed:
dan
(Dan)
56
Rhino WIP for Windows and Mac 7.0.19288 is now available!
Bugs Fixed:
- Edit places gradient end (RH-55004)
- A ghost gradient hatch may stay on screen (RH-55165)
- Bridge: EdgeLoop option does not work (RH-55014)
- Build Process: opennurbs\opennurbs_curve.cs(323, 45): error CS0246: The type or namespace name 'CurveSegment' could not be found (RH-55093)
- SDK: RhinoCommon: Rename RhinoDoc New and Load functions (RH-55081)
- SelectionFilter: Move selection filter definition into new class that can be used on both Mac and Windows (RH-54720)
- Stitch:
- Stitch doesn’t work on a mesh if the two edges touch at a vertex (RH-50087)
- SubD - Ability to “weld” / “stitch” (RH-53126)
- Stitch Average option inconsistent (RH-53263)
- Stitch position marker strange color (RH-53265)
- No visible feedback in EdgeLoop mode picking (RH-55015)
- SubD: Shading inconsistent in Crunchy display (RH-55107)
- ToSubD: ToSubD, Revolve, Loft, … support creases (RH-50746)
Enhancements:
- : CRhinoWorkerThread enhancement request (RH-55055)
- Allow selecting a comma or period as the decimal separator (RH-54853)
- Add a control in DocProps Dimstyle page for decimal separator in dimensions. (RH-54881)
- ExtrudeCrv: ExtrudeCrv - Add ability to create a SubD object as output (RH-50616)
- Insert: Review the block attribute panel (RH-54725)
- Stitch:
- Unwrap: SubD objects can't be unwrapped (RH-54604)
Features Added:
- Fill: Fill command - add ability for multiple edges to be prepicked. (RH-50748)
- Layout: Interface improvement (RH-20169)
- Stitch:
- Does not work on SubD objects (RH-54819)
- Result in creases on SubD, joined edges on Mesh (RH-54917)
- SubD Editing: Support picking control points (RH-30595)
Mac-Only Changes
Cosmetics:
- Context Menu: Change wordings in Layers panel Menu on Mac to match with Windows version (RH-44156)
Bugs Fixed:
- Rhino Installer Engine: Please wait… Updating toolbars…shown when switching between Rhino 6 and WIP (RH-54278)
SDK Enhancement:
- SDK: RhinoCommon:
- Support running commands on headless docs (RH-55034)
- Saving other file format while headless (RH-55065)
brian
(Brian Gillespie)
57
Rhino WIP for Windows and Mac 7.0.19295 is now available!
Bugs Fixed:
- Annotation: Hatch: Re-use last distance (RH-55150)
- CreateSolid: CreateSolid preview and command line toggle (RH-55159)
- Curve-surface intersection: Curve-surface Intersection incomplete (RH-11429)
- Display: Highlight the wires (RH-54953)
- FindTxt:
- “Replace All” should be available before clicking “Find Next” (RH-55277)
- “Replace Next” should be “Replace” (RH-55278)
- “Find Next” does not deselect the previous match (RH-55280)
- Does not cancel (RH-55285)
- Layer: Full path in -Layer > Color (RH-55130)
- Layout: Easier page organizing (RH-10765)
- Lights: Too many Undo actions for sliders in lights (RH-54863)
- NetworkSrf: Extrusion edges do not support history (RH-55247)
- Properties: Light properties page should be cross platform (RH-54666)
- Rendering:
- New Post Effects - Assert when closing render window (0 == m_iOpenCount) (RH-55216)
- New Post Effects - Assert when closing render window (m_iProgressBracket > 0) (RH-55217)
- Rendering: Materials: PBR basic sliders disabled if a texture is assigned (RH-55062)
- SelPrev: Does not work with SubD edge loop selection (RH-55218)
- Select: SubD boundary chain selection fails in command session (RH-55289)
- SubD:
- SubD Final C++ SDK cleanup (RH-53982)
- SubD - Clipping Plane shows Creamy intersection in Crunchy Mode (RH-55072)
- Some crunchy faces cannot be sub-selected (RH-55187)
- Crunchy SubD display broken at extraordinary vertices. (RH-55206)
- inconsistent box selection in crunchy mode (RH-55234)
- ON_SubD::SplitEdge splits at wrong position (RH-55245)
- SubDAppearance:
- SubD appearance - New commands - SubDDisplaySmooth, SubDDisplayFlat, SubDDisplayToggle (RH-53220)
- Toggle inside 3DFace (RH-55235)
- SubD edge and vertex snap locations need to pay attention to flat/smooth (creamy/crunchy) appearance. (RH-55243)
- SubD snapping in “flat” display mode - draw control net edge instead of surface edge (RH-55248)
Enhancements:
- Annotation: Hatch: Move the base with the hatch (RH-55109)
Features Added:
- TextField: Add new "Page Contents" field in Layout Properties (RH-55063)
SDK Enhancement:
- SDK: RhinoCommon: Expose Selection Filter settings to RhinoCommon (RH-54678)
Bugs Fixed:
- NetworkSrf: Edge of Mesh can not be filtered (RH-55101)
- SelectionFilter: Selection filter toolbar not paying attention to application settings change events (RH-55185)
Features Added:
- Rhino Inside: NuGet package for Rhino.Inside (RH-54969)
brian
(Brian Gillespie)
61
Rhino WIP for Windows and Mac 7.0.19302 is now available!
Bugs Fixed:
- Annotation: Hatch: Selecting hatch changes pattern (RH-55254)
- Curve-surface intersection: Missing intersections (RH-18945)
- FindText: "Find Next" does not deselect the previous match (RH-55280)
- InsertEdge: InsertEdge doesn't support preselection (RH-54480)
- Layout: RhinoView.PageContents() needs to raise a doc change (RH-55293)
- Licensing: Cloud Zoo: Rhino shows dialog when starting asking me to copy non-existent URL into web browser (RH-48426)
- Rendering: Light falloff UI for PBR (RH-52076)
- Rendering: Materials: Confusing behavior in Textures panel (RH-54940)
- SubD: SubD - not snapping to 'points' in Crunchy mode (RH-55068)
- TextField:
- Blocks produce “$temp_object$” Keys in Attribute User Text (RH-55275)
- BlockInstanceCount always returns 1 (RH-55287)
Enhancements:
- InsertEdge: Preview would be more helpful on limit surface for SubD (RH-54481)
Features Added:
- InsertEdge: support for multiple loops (RH-48331)
UI Change:
- InsertEdge: InsertEdge auto selections (RH-54484)
Bugs Fixed:
- Grasshopper: Components: Curve Explode fails on NURBS curves (RH-55262)
- TextField: Rhino application sent to back (RH-55273)
- UI Cleanup: Use multiple mapping channels field is too small (RH-55087)
brian
(Brian Gillespie)
62
brian
(Brian Gillespie)
63
Rhino WIP for Windows and Mac 7.0.19324 is now available!
Bugs Fixed:
- Annotation: Hatch: "Match" Not Working (RH-55669)
- BooleanSplit: Boolean with Infinite planes leaves very large underlying surfaces (RH-55039)
- Curve-surface intersection: Incomplete (RH-55656)
- Display:
- Subd objects have clipped sun shadows (RH-53761)
- Splop preview is missing for SubD objects (RH-55561)
- Display - Shading completely broken in current build of 7 WIP - more so with a SubD object (RH-55773)
- Eto:
- Eto Gridview dragging multiple grid rows not working (RH-55157)
- Eto Gridview dragging in editable grid column not working (RH-55301)
- File IO: Missing trimmed surfaces in IGES import (RH-55728)
- MeshIntersect: MeshIntersect finds two intersections, where only one is actually the right answer (RH-55448)
- NamedView: Re-opening floating panel makes problems (RH-55707)
- OpenNURBS: The public opennurbs GitHub repo needs to include the example files (RH-55367)
- Pipe: SubD pipe caps have flipped normals (RH-55652)
- RDK:
- Texture percent doesn’t work in PBR material in Rendered mode (RH-54796)
- NewContentControl DropDown list should have the same size thumbs in the list as the main NewContent Control has (RH-55715)
- When using “GPU render window drawing” LockDib() gets repeatedly called, which leads to executing PEPs on the main thread (RH-55727)
- Rebuild: Value field input is not working right (RH-55614)
- Rendering:
- Apply tone mapping while rendering is intermittent (RH-53385)
- Tone mapping does not stick (RH-53681)
- Renderings using the new PEP pipeline are much brighter (RH-55725)
- Changing plastic to custom materials has problems with bump amounts (RH-55635)
- PBR roughness slider is broken (RH-55676)
- Textures are not preserved when moving from Plastic to PBR (RH-55726)
- SDK:
- ON_MeshTree::IntesectLine tolerance issue (RH-29440)
- Make C++ samples RDK compliant (RH-55617)
- SDK: RhinoCommon:
- MeshMeshFast NullReferenceException (RH-55494)
- Move ThumbGrid panel class to Rhino.UI (RH-55577)
- SubD: SubD sub object selections shows additional selections (RH-54200)
- TextField: Block UserText Field (RH-48161)
- UserText: Properties panel resolves Value as error #### (RH-55621)
Crashes Fixed:
- Offset: tl!TL_EvBezier – (NTSTATUS) 0xc00000fd - A new guard page for the stack cannot be created. (RH-50447)
Enhancements:
- Annotation: Text: Draw Frame Option for Annotation (RH-55096)
- LayerStateManager: Add a clickable column header to the layer state manager (RH-52861)
- Rendering: Materials: PBR implementations for template materials (RH-55573)
- SelDup: Add SubD support (RH-55718)
- TextField:
- Attribute User Text on Block Instance resolves as code, not text (RH-55266)
- New ObjectLayer function (RH-55664)
Features Added:
- Display: Add physically-based rendering material support to the Rhino display (PBR material) (RH-51741)
- TextField:
- New BolckAttributeField function (RH-27112)
- TextFields - New “LayerName” textfield (RH-55633)
SDK Enhancement:
- DraftAngleAnalysis: Wrap CRhinoDraftAngleAnalysisSettings (RH-55757)
- SDK: RhinoCommon:
- Support JSON IO (RH-55720)
- Wrap RhAnalysisAdjustMeshes( RHINO_DRAFT_ANGLE_ANALYSIS_MODE_ID ) for RhinoCommon (RH-55758)
Tasks Completed:
- Installer: Remove MeshUtilities plug-in from the installer (RH-55746)
- TextField: Need to be able to move (or hide) the Block Attributes dialog box (RH-55620)
Bugs Fixed:
- Detail: Detail property page not showing when activiating detail (RH-55512)
- InsertPoint: Unable to split ngon (RH-47797)
- PropertiesPage: Panel content is shifting (RH-55377)
- Rendering:
- Glare (Post effect) is slow (RH-52511)
- Flickering when re-sizing Post effect panel on Windows (RH-55589)
Enhancements:
- NamedView: Display * in viewport title when a named view is modified (RH-52896)
- Rendering: Materials: New "Sort Alphabetically" menu item (RH-46076)
- Rendering: Texture Mapping: Texture property to control the texture mapping method used in assigned materials is needed (RH-54983)
Features Added:
- NamedView: Ability to drag to reorder the items (RH-54425)
UI Change:
