Rhino WIP 7.0.20168 for Windows and Mac is now available
Bugs Fixed:
- 3DFace: SubD preview issue (RH-55749)
- Append:
- Color Picker: Custom colors aren't showing details but look like they want to (RH-58809)
- Display:
- DraftAngleAnalysis:
- Eto: Some command dialogs have 0 padding (RH-59076)
- ExtrudeSubD: Does not trigger Reflect update (RH-58379)
- FilletSrf: Trim option does not work (RH-58998)
- Grasshopper: The Grasshopper placeholder does not correctly keep Parameters connected. (RH-56215)
- LayerStateManager: Gets width slider for no apparent reason (RH-58885)
- Lock: Locking/hiding layers does not turn off automatically turned on control points (RH-58816)
- MergeAllFaces: Goes on forever (RH-57219)
- MergeFace: Locks up Rhino (RH-58196)
- MeshIntersect: No result with these two triangles (RH-58694)
- OSnap:
- OpenNURBS: Fix example_test and the subd logo test model so public opennurbs tests pass (RH-58890)
- PlanarUnion: Planar boolean commands: Prompt tune up (RH-58989)
- Polyline: Direction shifts from Helper for Arc (RH-59000)
- RDK:
- Rendering:
- Rendering: Materials:
- Rendering: Texture Mapping:
- SDK: Mesh vertex precision data loss in plug-ins and internal code (RH-58829)
- SDK: Python: SDK Python: Rhino.WindowPick not the same as rhinoscriptsyntax.WindowPick (RH-58495)
- SDK: RhinoCommon:
- Selection: SubObject selecting fails (RH-58774)
- SelectionFilter:
- SubD:
- SubD Editing: SubD mesh update needs to set texture mapping tag (RH-58507)
- SubDLoft: Does not work with Chain option for rails (RH-58815)
- ToNURBS: ToNurbs - SubD to brep - add option to make bigger brep faces (RH-53157)
- Unwrap: Ruins SubD preview in Rendered mode (RH-58392)
- ZoomExtents: Zoom Extents All in Model Space zooms out in Layout (RH-48834)
Crashes Fixed:
- Rendering: "Safe Frame Settings" in Render menu causes crash (RH-59003)
- Stitch:
- SubDLoft: Causes crash with two curves (RH-59018)
Enhancements:
- BlendEdge: More progressive (RH-54486)
- File IO:
- FilletSrf: New BlendType=CircularFillet/G2Blend option (RH-58921)
- Loft: Made SnapToKnots on by default for closed curve matching (RH-58650)
- OSnap:Quad: OSnap Quad: Supports SubD edges (RH-58079)
- Polyline: New ThroughPoint option when Mode=Arc (RH-58905)
Features Added:
- BooleanDifference: Finalize TestPlanarDifference SDK in C++/RhinoCommon (RH-58516)
- BooleanIntersection: Finalize TestPlanarIntersection SDK in C++/RhinoCommon (RH-58514)
- BooleanUnion: Finalize TestPlanarUnion SDK in C++/RhinoCommon (RH-58512)
- Grasshopper: New "Preview Boundary" display option (RH-58981)
SDK Enhancement:
- RefitTrim: Expose in the SDK (RH-54621)
- SDK: RhinoCommon: SDK RhinoCommon: Add functionality behind Plane > Deformable to RhinoCommon (RH-58858)
UI Change:
- MatchSrf: Option "CurveNearSurface" is renamed "OnSurface" (RH-58854)
- Menu: Add ClearAnalysisMeshes command (RH-58831)
- Rendering: Materials: Rendering Materials: Preview geometries now use a fixed real-world size (RH-56806)
Usability Problems Fixed:
- Color Picker: Color picker: Larger current color swatches (RH-58731)
- FilletEdge: Option shortcuts are unstable (RH-58852)
- Offset: Shift Trim option (RH-58853)
Mac-Only Changes
Bugs Fixed:
- ApplyDisplacement: Displacement mesh modifier does not obey OCS frame (RH-57609)
- Color Picker:
- Export: Information irrelevant to exported objects is also saved (RH-59014)
Crashes Fixed:
- Displacement: com.mcneel.rhinoceros.RhCore:-[MROpenGLLayer drawInOpenGLContext:pixelFormat:forLayerTime:displayTime:] (RH-58615)
Enhancements:
- Grasshopper:
Incomplete Port:
- EditPythonScript: Search, replace, cut, copy, paste menus in EditPythonScript on macOS (RH-54432)
- SDK: GHPython: SDK GHPython: Search, replace, cut, copy, paste menus in GhPython on macOS (RH-54431)
- Display: Reflect confusion regarding which side is the parent (RH-58585)
Windows-Only Changes
Bugs Fixed:
