Rhino 7 BETA Available Now!
Rhino WIP 7.0.20105 for Windows and Mac is now available
Bugs Fixed:
  • RDK: We need a Normal XYZ wrapper channel (RH-57270)
  • Code Editor: C#: Code Editor C#: Writing a function crashes Rhino (RH-57741)
  • DraftAngleAnalysis: Draft curve results for this model are not desirable. (RH-56467)
  • Eto: Eto UI: Made Delete key work properly in Material Editor (RH-56246)
  • Grasshopper: Components: Grasshopper: Polygon Edge component has Error in mouseover tooltips (RH-57593)
  • Installer: Remove OptionsManager.rhp from installer (RH-57604)
  • Layout: Double-clicking in editable GridView begins editing (RH-57720)
  • Loft: Creases missing in Loft to SubD (RH-51391)
  • MeshIntersect: Should provide correct result for this case (RH-57464)
  • Offset:
  • Pull: Changed back to not supporting whole polysurfaces or SubDs (RH-53322)
  • QuadRemesh: Makes gaps if used on polysrf versus mesh (RH-57472)
  • RDK:
    • Attempt plug-in load when loading file with custom material (RH-42856)
    • Preview pipeline uses ActiveDoc (RH-45059)
    • RenderWindow channel SDK breakage (RH-57751)
  • Rendering: Materials: Rendering Materials: Asynchronous rendered previews do not appear after 8th April 2020 (RH-57821)
  • RibbonOffset:
    • Incorrect with some pick points (RH-57718)
    • Depends on pick point location (RH-57840)
  • SDK: RhinoCommon:
    • SDK RhinoCommon: RhinoGetTightBoundingBox() SDK function not wrapped for RhinoCommon (RH-30819)
    • SDK RhinoCommon: Intersection.RayShoot should return Brep face(s) that were hit (RH-57098)
  • SelectionFilter: Active selection gets cleared when toggling off selection filters (RH-57784)
  • SubD: Add ON_SubD::ComponentStatusSerialNumber() to detect when component status (hidden, locked, highlighted) has changed. (RH-57815)
  • SubDLoft: Increasing DivisionsAcross does not change the shape (RH-57675)
  • TextField:
    • Attribute Text Function Dialog > Document Text string not always applied (RH-57728)
    • Convert lcase functions so that they parse correctly (RH-57756)
  • Textures: Texture: Incomplete preview (RH-57817)
Crashes Fixed:
  • ExtrudeCrv: opennurbs!ON_ClassArray<ON_MaterialRef>::Count – Access Denied (RH-57758)
Enhancements:
  • Align: Supports sub-selected SubD vertices (RH-57530)
  • Display: Allow for more aggressive skylight shadow resolution degrading through advanced options (RH-57804)
  • ExportOptions: Does not export "Never repeat these commands" list (RH-51411)
  • SDK: GHPython: SDK GHPython: Add utility functions to show messages on Grasshopper python components (RH-57039)
  • SubDLoft: "Adjust Seam" step is renamed "Adjust edge loop position" (RH-57678)
  • SystemInfo: Plug-ins shipped and not shipped with Rhino are listed in two groups (RH-57608)
Features Added:
  • Offset: New Corner=None and Trim=Yes/No options (RH-42854)
  • SubDLoft: New command (RH-57232)
  • TextField: Add Layout User Text for Title Block Specific Information (RH-55876)
Meta Issue:
  • PackageManager: Platform-specific (w.r.t. OS and Rhino version) package versions (RH-52382)
SDK Enhancement:
  • SDK: RhinoCommon:
    • SDK RhinoCommon: Added Curve.Offset override that allows loose offset and end cap (RH-57413)
    • SDK RhinoCommon: Expose rail sweep frame calculators (RH-57699)
  • SubD: Add per face color properties to ON_BrepFace and ON_SubDFace (RH-57661)
Tasks Completed:
  • Menu: Change Slide command to Slide Edge in menus (reverted to Slide) (RH-52420)
  • Rendering:
    • In-viewport post effects are only implemented for the RhinoCommon case. (RH-57384)
    • Create a denoiser PEP using NVIDIA’s OptiX SDK (RH-57707)
UI Change:
  • Menu: Add SubDLoft command (RH-54920)
  • SubDLoft: SubDloft: Made the SnapToKnots option default to No (RH-57677)
  • Toolbar:
Usability Problems Fixed:
  • SystemInfo: Remove user data (RH-57607)
Mac-Only Changes
Bugs Fixed:
  • Annotation: DimAngular: Annotation DimAngular: DegreeMinutesSeconds ignored (RH-57765)
  • Grasshopper:
    • GrasshopperPlayer doesn’t support Undo (RH-57772)
    • GrasshopperPlayer single input doesn’t move on after one selection (RH-57773)
  • InsertEdge: fails when multiple documents are open (RH-57708)
  • Rendering: Materials: Rendering Materials: Navigation is too slow on Mac… compared to Windows (RH-56937)
  • TextField: Combination of 2 Area() fails (RH-57532)
  • UserText: Attribute User Text Functions: UI Issue (RH-57755)
Crashes Fixed:
  • RDKCrash: RhinoWIP fails to launch with segmentation fault caused by System.EntryPointNotFoundException: Rdk_CRdkCmnEarlyPostEffectPlugIn_SetCallbacks (RH-57808)
UI Change:
  • SelectionFilter: Added to top bar as a popup list (RH-57261)
Windows-Only Changes
Bugs Fixed:
  • Drag and Drop: ETO Dragdrop to viewport does not work on the Windows (RH-57559)
  • Grasshopper:
    • GrasshopperPlayer single input doesn’t move on after one selection (RH-57713)
    • GrasshopperPlayer doesn’t support Undo (RH-57715)
UI Change:
  • Grasshopper: Rename contextual inputs (RH-57828)
Rhino WIP 7.0.20112 for Windows and Mac is now available
Bugs Fixed:
  • RDK: At least two non-legacy implementations are broken (RH-52291)
  • Warning in big libs project (RH-57686)
  • Annotation: Hatch: Annotation Hatch: Ensure gradient hatch display conduit gets deactivated properly (RH-57547)
  • Contour: switch to new mesh intersector (RH-57791)
  • Cycles: Calls an RDK function it shouldn't call (RH-57584)
  • Display:
    • TestDetailCache - Details turn “ghosted” when a detail is selected (RH-56183)
    • RhinoPolyhedra doesn’t show previews in latest WIP (RH-57966)
  • GrasshopperPlayer: Explicit error message when path fails (RH-57916)
  • PackageManager: Ampersand missing (RH-57860)
  • RDK: Texture baking queue threading code should be made cross platform (RH-44475)
  • RemoveCrease: Does not work on a SubD (RH-57777)
  • Rendering: Post Effects have no effect on cloned image (RH-57953)
  • Rendering: Materials: Rendering Materials: No way to convert a basic material (ON_Material) to a PBR approximation (RH-57483)
  • SDK: RhinoCommon: SDK RhinoCommon: No access to internal object array from TransformObjectList (RH-57901)
  • Slide: Jerky along SubD edges (RH-57867)
  • Split: Failure loops when splitting polysurfaces with curves (RH-2197)
  • Trim: Keeps wrong part of polysurface (RH-3942)
Crashes Fixed:
  • Cycles: Crash on Undo (RH-57680)
  • MeshIntersect: Contour Command: tl!TL_MeshXPlane::ProcessQuad – Access Denied (RH-57783)
  • OffsetSubD: opennurbs!ON_Mesh::Duplicate – Access Denied (RH-57890)
Enhancements:
  • PackageManager: Added download count to package manager UI (RH-54090)
  • Rendering: Material thumbnails rendered by the selected render device (RH-57313)
  • ScriptCompiler: Supports running in batch mode (RH-51366)
  • Slide: Is able to slide boundary edges outward (RH-51756)
  • TextField: Allow sorting keys and values (RH-57510)
  • UserText: Attribute User Text - Added new TextField functions and cleaned-up the function list (RH-57105)
Features Added:
  • GrasshopperPlayer: New command (RH-55265)
Regressions Fixed:
  • Trim: Seems to be projection dependent in v7 (RH-56960)
Tasks Completed:
  • AlignVertices: AlignMeshVertices icon macro and menu needs to be changed (RH-57528)
UI Change:
  • Keyboard Shortcuts: F4 function key - returned to pool of unused function keys. (RH-57875)
  • TextField:
    • New Attribute User Text Functions Dialog (RH-57733)
    • TextFiled: Toolbar buttons added to DocumentUserText, AttributeUserText, and LayoutUserText pages (RH-57736)
Mac-Only Changes
Bugs Fixed:
  • Rendering: Content Editor preview is empty (RH-57931)
Crashes Fixed:
  • RDK: More Types dialog crashes on the Mac (RH-57930)
UI Change:
  • PackageManager: Hide "Downloads" label in Installed tab (RH-58013)
Bugs Fixed:
  • RDK: Eto Gradient Texture crashes on Windows (RH-57591)
  • Rendering: Materials: Rendering Materials: Texture preview not updating (RH-57967)
Crashes Fixed:
  • Cycles: Raytraced crashes when adding invalid linear light (RH-57648)
  • Rendering: Texture Mapping: RhinoCore!CTextureMappingPropDlg::OnInitDialog – Access Denied (RH-57886)
Enhancements:
  • Display: Shadow quality in viewports is improved (RH-57802)
  • ScriptCompiler: Supports transparent commands (RH-57990)
Features Added:
  • Grasshopper: GrasshopperPlayer: Supports system environment variables (RH-57872)
UI Change:
  • PackageManager: Hide "Downloads" label in Installed tab (RH-57993)
Rhino WIP 7.0.20119 for Windows and Mac is now available
Bugs Fixed:
  • Color Picker: Doesn't show metal color list for metals (RH-57919)
  • Grasshopper:
    • Grasshopper must use V7 for “internalizing” SubD objects. (RH-55366)
    • GrasshopperPlayer: Run specific definition from Rhino Alias (RH-57729)
  • Insert: Scriptable command displays 'Block name conflict' dialog (RH-57346)
  • PackageManager: Fetching packages UI takes a long time (RH-57858)
  • Properties: Panel toolbar button order (RH-57338)
  • RDK: GetTextureFromUsage fails in v7 when built against v6 RhinoCommon (RH-57752)
  • Rendering: Intel denoiser's output doesn't stick in Raytraced viewport (RH-58000)
    • Rendering Materials: Different bump map/displacement map results (RH-57509)
    • Rendering Materials: Baking is triggered by procedural textures that are “off” (RH-57928)
    • Rendering Materials: PBR emission color defaults to black which is not useful (RH-58006)
  • SDK: ON_MeshParameters::SetFaceType doesn't seem to do anything (RH-58029)
  • SDK: RhinoCommon:
    • SDK RhinoCommon: Intersection.MeshMeshFast() throws ArgumentNullException on empty output (RH-57569)
    • SDK RhinoCommon: Wrap required for IRhRdkPostEffectPipeline::PostEffects(ON_SimpleArray<ON_UUID>& ids) const (RH-58017)
  • SelFaceLoop: Keyboard shortcut should only pay attention to the last selected face for direction indication (RH-57831)
  • Split: Missed Face Split (RH-53471)
  • Stitch:
    • Creates creased edges when input doesn’t have any (RH-56340)
    • Creates holes with edge loops as input (RH-56341)
    • Fails on these objects (RH-57492)
  • Toolbar: Subdivide tooltip needs changing (RH-55457)
Crashes Fixed:
  • BlendSrf: Crash with edge chaining (RH-58001)
  • Cycles:
    • ccycles!ccl::ObjectManager::device_update_mesh_offsets – Access Denied (RH-57068)
    • Crash on exit when rendering a preview (RH-57920)
  • Display: TestSetPerFaceColor crashes if faces are pre-selected (RH-57869)
  • RDKCrash: ntdll!RtlpWaitOnCriticalSection – Access Denied (RH-57888)
  • SubDLoft:
    • Dragging curve from SubDLoft with History that was undone crash (RH-58021)
    • Crashes when lofting with History off (RH-58022)
    • Crashes when adding divisions (RH-58036)
Enhancements:
  • File IO:
    • DWG/DXF Import - Supports reading gradient patterns as gradient hatches (RH-57099)
    • STEP Import/Export - Supports per-face colors (RH-57923)
    • DWG/DXF Export - Supports writing gradient hatches as gradient patterns (RH-57989)
  • OSnap: Added SnapToMeshes to Modeling Aids settings (RH-57904)
  • SelName: Uses "Natural sort order" to list object names (RH-44460)
  • SubDLoft: Added History support (RH-57428)
  • TextField:
    • AttributeUserText - Annotations can be self-referenced by “(null)” (RH-57956)
    • DetailScale - New “Use detail attribute name” checkbox (RH-57962)
Features Added:
  • Display:
    • New RemovePerFaceColors command (RH-57837)
    • Supports SubD Per Face Color (RH-57936)
  • File IO: PDF Export supports Layers (RH-37721)
  • Properties: Display color can be assigned to sub-faces of Polysurface and SubD (RH-37306)
  • Reflect: New command (RH-55973)
SDK Enhancement:
  • RDK: RenderSettings RunScript logic should be in the RDK core (RH-57610)
Mac-Only Changes
Bugs Fixed:
  • Grasshopper:
    • Right-click context menu has weird characters (RH-57864)
    • Rename contextual inputs (RH-57896)
  • Properties: Set color to Custom from the color swatch (RH-58008)
  • Rendering: Render window at 1 to 1 Zoom is twice what the viewport size is (RH-57807)
  • TextField: Layout User Text - fx dialog box (RH-57909)
Bugs Fixed:
    • Rendering Materials: ETO UI - Value/number not showing properly on Windows (RH-58015)
    • Rendering Materials: ETO UI - Bump map isn’t updating (RH-58016)
  • Textures: Texture: Mapping text gets cut off (RH-57800)
Enhancements:
  • ScriptCompiler: Supports specifying version information (RH-35623)
Features Added:
  • ScriptCompiler: Included in Rhino installer (RH-58052)
Rhino WIP 7.0.20126 for Windows and Mac is now available
Bugs Fixed:
  • Annotation: Hatch: Annotation Hatch: Gradient transparency changes when hatch is selected (RH-57402)
  • BooleanUnion: Selection order have inconsistent result on per-face color (RH-57958)
  • Color Picker: Make new Color Dialog smaller and stay put (RH-57940)
  • Delete: SubD delete faces workflow - leaving new boundary edges selected is sometimes inefficient and annoying. (RH-57976)
  • ExtractSrf: Loses Per Face Material (RH-58146)
  • Grasshopper:
    • Context Parameters default settings (RH-57829)
    • GetString Singular does not work (RH-57832)
    • GetNumber defaults don’t accept ENTER (RH-57863)
    • Need to Redraw if fail to complete or exit a command (RH-58119)
  • GrasshopperPlayer: Supports "File Search Paths" (RH-57898)
  • Make2D: Hidden layers use "Continuous" linetype in localized Rhino (RH-57087)
  • MeshSplit:
    • Not working with a specific file (RH-57844)
    • Example of mesh head split not working (RH-57855)
  • OpenNURBS: Only ON_Mesh that has m_V but not m_dV is getting tested for faces validity (RH-54563)
  • PackageManager:
    • UI confusion about available update (RH-57665)
    • Manifest does not auto-populate author (RH-57983)
  • RDK:
    • Rhino stalls while downloading files, but never shows progress (RH-57792)
    • Custom Material - Bump texture slot amount can’t be set negative (RH-58040)
  • Rendering:
    • PostEffectJobs get normal/albedo/depth pixels only once, afterwards null pointers (RH-57822)
    • Decals don’t work on SubD objects (RH-58076)
    • RenderCRC ASSERT fires when the related bug’s model is loaded (RH-58134)
    • ETO UI Win: Picture Material properties errors (RH-58044)
    • Rendering Materials: PBR glass is not working (RH-58156)
    • Rendering Materials: “Slippery stone” PBR textures are not recognized (RH-58200)
  • SDK: RhinoCommon: SubDEdge.ToNurbsCurve() method needed (RH-53342)
  • ScriptCompiler: MissingManifestResourceException (RH-58159)
  • SelFaceLoop: Mesh face loop selection should only pay attention to the last selected face (RH-58133)
  • Split: Does not respect per face materials (RH-58153)
Crashes Fixed:
  • DeleteEdge: Crash bug (RH-57045)
  • InsertPoint: InsertPoint Command: RhinoCore!Mu7::ConvexPlanarPolygon::ConvexPlanarPolygon – Access Denied (RH-56631)
  • PackageManager: System.IO.FileNotFoundException: Yak.YakClient.Install (String tempPath) (RH-58091)
Enhancements:
  • BlendSrf: New "Refine" checkbox avoids creating a simpler blend surface when it is possible to do (RH-56944)
  • BooleanUnion: Allow suppressing the "Tolerance had to be doubled…" warning (RH-58010)
Features Added:
  • Color Picker: Added color swatches (RH-57941)
Performance Improvements:
  • Grasshopper: Slow far-from-origin area calculation (RH-57394)
UI Change:
  • File IO: STEP Import - Remove "(Uncheck to retain per-face colors)" from the options dialog (RH-58075)
  • Menu: Add RemovePerFaceColors command (RH-58095)
  • MergeFaces: New Results=Selected/NotSelected options (RH-57952)
Mac-Only Changes
Bugs Fixed:
  • Annotation: Hatch: Annotation Hatch: Gradient hatches may display across documents on Mac (RH-58107)
  • Color Picker:
    • Transparency doesn’t work in new color picker on Mac (RH-57934)
    • Rdk_Globals_ShowColorPickerEx does not trigger the callbackProc event on Mac (RH-58172)
Features Added:
  • Grasshopper: GrasshopperPlayer: Supports system environment variables (RH-57995)
  • Preferences: Tool palettes: Add advanced setting to suppress tool palettes reappearing after command completes (RH-57945)
Bugs Fixed:
  • Eto: Not possible to dynamically switch Windows to use the ETO RDK UI (RH-57951)
  • NamedSelections: NamedSelection: List duplicated when objects are copied and pasted (RH-58086)
  • Rendering: Materials: ETO UI Win: Picture Material, bugs when changing/editing image (RH-58060)
  • ScriptCompiler: RhinoScriptCompiler: Error on Build (RH-58213)
  • Grasshopper: Cluster performance slow (RH-44500)
UI Change:
Rhino WIP 7.0.20133 for Windows and Mac is now available
Bugs Fixed:
  • RDK: Inconsistent / inaccurate use of terminology (RH-58343)
  • Color Picker:
    • Eto Color dialog has several bugs (RH-57963)
    • Performance is very sluggish (RH-58068)
  • Display: Per face material removes per face colors in the display (RH-57944)
  • Eto: Color button paste is buggy (RH-57739)
  • Grasshopper:
    • GradientHatch component doesn’t bake properly (RH-56752)
    • Use headless doc for Import 3dm component (RH-58090)
  • History: Problem with CRhinoHistory::SetCurveValue( int value_id, const ON_Curve& curve ); (RH-58039)
  • Lock: Locked objects retain control points (RH-58179)
  • OSnap: No Vertex snap when selection filter is "Vertices" (RH-58137)
  • OpenNURBS: Add ON_Viewport::ShallowCopy() (RH-58297)
  • Properties: No access to page top of some properties on Mac (RH-58243)
  • PropertiesPage: Dimension page - Column spacing too wide (RH-53004)
  • RDK:
    • Texture baker doesn’t rebake when different size is requested (RH-57908)
    • Assert creating a material (RH-58177)
    • Wrap GetDecalTextureMapping() for Decal (RH-58246)
  • Reflect: Doesn't update after moving a control point. (RH-58357)
    • Rendering Materials: OpenGL material bug (RH-58135)
    • Rendering Materials: Bamboo PBR does not import correctly (RH-58222)
    • Rendering Materials: Worn painted cement PBR doesn’t recognise the normal map (RH-58225)
  • Rhino Installer Engine: RHI (Rhino 7 c++ plug-in) not installing in V7 (RH-57500)
  • Selection: SubD Friendly curve displays an extra line with fuzzy selection (RH-58410)
  • Split: Per face color face is removed (RH-57924)
  • SubD:
    • Improve SubD control point/Gumball editing performance - phase 1. (RH-57501)
    • ON_SubD::CreateSubDFriendlyCurve() gives bad answer for kinked rectangle (RH-58057)
  • SubDAppearance: TestSubDSetTexDomains command did not register when starting Debug Rhino (RH-58393)
  • SubDLoft: Wrong answer (RH-58056)
  • Sweep1: As SubD refits polylines in one direction. (RH-58109)
  • UDT: CageEdit - Doesn't support SubD surfaces as captive objects (RH-50330)
Crashes Fixed:
  • RhinoCore!CRhinoSettings::GetChild – Access Denied (RH-58275)
  • ScriptCompiler: Crash on command edit (RH-58205)
Enhancements:
  • File IO: OBJ Export - New "Use display color for objects with no material set" checkbox (RH-58198)
  • NamedSelections: Works with post-selection (RH-56701)
  • ScriptCompiler: New TransparentAndHidden command type (RH-58234)
  • Stitch: Stacked SubD vertices can be combined (RH-56953)
Features Added:
  • BlockEdit: New BlockResetScale command (RH-57957)
  • SDK: Bring up export options dialogs via rhinoscriptsyntax (vb and python) (RH-30938)
SDK Enhancement:
  • SDK: RhinoCommon: SDK RhinoCommon: Added RhinoObject.TryGetGumballFrame method to RhinoCommon (RH-58174)
Tasks Completed:
    • Create Grasshopper Example (RH-58282)
    • CraftAngleAnalysis: Create Python Draft Angle Sample (RH-58309)
  • NamedSelections: NamedSelection: Rename column header (RH-58292)
  • RibbonOffset: Make Grasshopper Example (RH-58277)
  • SDK: Review C++ SDK (RH-57914)
  • SDK: RhinoCommon:
    • SDK RhinoCommon: Create C# Sample for RibbonOffset (RH-58255)
    • SDK RhinoCommon: Create C# Sample Draft Curve (RH-58256)
UI Change:
  • Menu:
    • Add SelSubDFriendlyCrv command (RH-58235)
    • Add BlockResetScale command (RH-58317)
  • Toolbar: Add GrasshopperPlayer command (RH-57847)
Mac-Only Changes
Bugs Fixed:
  • DocumentProperties: Render Page - RunScript not implemented (RH-48171)
  • Grasshopper:
    • GrasshopperPlayer: Preview doesn’t update in viewport (RH-58293)
    • Custom Preview component works even when Grasshopper preview mode is disabled (RH-58338)
  • NamedSelections: NamedSelection: List duplicated when objects are copied and pasted (RH-58241)
  • PackageManager: Rhino Polyhedron plugin doesn't load on Mac from Yak (RH-56023)
  • ScriptCompiler: Plugin created using RhinoScriptCompiler does not run on Mac (RH-58170)
Features Added:
  • PackageManager: Rhino for Mac should be able to load rhino plug-ins (.rhp) from yak packages (RH-56662)
  • ScriptCompiler: Included in Rhino installer (RH-58089)
Regressions Fixed:
  • ToolPalettes: Do not hide floating tool palettes when commands don't prompt for actions (RH-58345)
Bugs Fixed:
  • Color Picker: Jumps when picking around circle (RH-57998)
  • Grasshopper:
    • GrasshopperPlayer: Preview doesn’t update in viewport (RH-57714)
    • Add SubD as a type hint, GhPython Windows (RH-58037)
    • Custom Preview component works even when Grasshopper preview mode is disabled (RH-58259)
  • Installer: Rhino 6 plugins get confused by Rhino 7 WIP installation and won't run (RH-49042)
  • Panels: Properties > Text panel needs scaling / wrapping (RH-57621)
    • PanelingTools RHI (Rhino 6 c++ plug-in) doesn’t install for Rhino 7 (RH-54071)
    • Fails to register V6 plug-ins with Rhino 7 (RH-56645)
  • Tabs: Tab: Layouts tab context menu hosed (RH-57587)
Rhino WIP 7.0.20140 for Windows and Mac is now available
Bugs Fixed:
  • DevLoft: May fail on curves connecting end to end (RH-58333)
  • ExtractRenderMesh: Not working on block instances (RH-58295)
  • File IO:
    • PDF Import - Missing lines (RH-58084)
    • Incorrect warning about a missing font (RH-58472)
  • Gumball: Relocating not snapping to mesh vertices associated with selected subobjects (RH-58463)
  • Help: Help Typo in Quadremesher help (RH-58368)
  • PackageManager:
    • Confusing UI when update is available (RH-57747)
    • Yak Yank and Push System.NullReferenceException (RH-58367)
    • Not showing absolute latest version if pre-releases is checked (RH-58424)
  • Project: Circular shape does not project loose (RH-58195)
  • RDK: RenderCRC assert fired when rendering preview (RH-58386)
  • Rebuild: History replay issue with preserving end tangent directions (RH-58487)
  • RemoveCrease: Fails on corner vertex (RH-58528)
  • Rendering:
    • Raytraced view does not show decal on a SubD (RH-58321)
    • Post Effects always run twice (RH-58473)
    • RDK: Tonemapping histogram shows outdated data (RH-58498)
    • Rendering Materials: Swap colors doesn’t work if a custom curve is used in a Gradient texture (RH-58186)
    • Rendering Materials: PBR Material doesn’t find correct slot when texture name is shortened (RH-58426)
    • Material Editor has slow performance with 8k textures (RH-58506)
    • Rendering Texture Mapping: Texture baking must not populate CRhinoSubDObject::m_mesh_ref (RH-58395)
    • Rendering Texture Mapping: Checker texture bug on SubD (RH-58428)
  • Repeat: Tab key toggle for SubD appearance should not repeat (RH-58238)
  • SDK: RhinoCommon: Allow plug-ins to change Rhino application title (RH-58355)
  • Selection: Unwanted command-line output when selecting some text from rs.WindowPick() (RH-58420)
  • SubD: Add room for per vertex false color storage to ON_SubDMeshFragment before SDK freeze. (RH-58442)
  • SubD Editing:
    • AFTER Gumball extruding, SubD has missing or faulty face texture domains (RH-58394)
    • Remove calls to ON_SubD::SetTextureDomains (RH-58396)
  • Subobject Selection: Picking issue v7 (RH-58382)
  • Textures: Edit multiple - Size edit fails when one is not the same (RH-58499)
  • ToSubD: NURBS extrusion ToSubD removes one crease (RH-58161)
  • Unwrap: Use coarser mesh density for SubDs (RH-58389)
Crashes Fixed:
  • Rendering: Materials: Rendering Materials: Crashes when changing material type (RH-58494)
Enhancements:
  • Autocomplete: Keep use count equal or bigger than 2 for some commands (RH-58011)
  • BlendSrf: New automatic straighten button and angle threshold (RH-57101)
  • RDK: There needs to be a way to indicate which PEP histograms should be computed (RH-58479)
  • SubD: Support Subdividing SubD on a sub object basis. (RH-41636)
Features Added:
  • SubDThickenCurves: New command (RH-58049)
Regressions Fixed:
  • CPlane: Object option forbids picking single surfaces (RH-58298)
Tasks Completed:
  • Localization: Turn on menu localization process in Mac Rhino 7 (RH-58364)
UI Change:
  • Menu:
    • Add GrasshopperPlayer command (RH-57846)
    • Add GrasshopperPluginList command (RH-58414)
  • Toolbar:
    • Add RemovePerFaceColors command (RH-58096)
    • Add SelSubDFriendlyCrv command (RH-58236)
    • : Add BlockResetScale command (RH-58318)
    • Add SubDThickenCurves command (RH-58341)
Mac-Only Changes
Bugs Fixed:
  • Annotation: Style deletion isn't working correctly on Mac (RH-58511)
  • Core bugs: CRhinoDib::BitBlt Mac implementation copies data erroneously (RH-58322)
  • Display: Rhino Mac crashes when trying to load a shader (RH-58580)
  • Invert: Ignores selection filters (RH-48296)
  • PackageManager: Fix gridview spacing on mac (RH-58582)
  • Preferences: Can't set real-time renderer assignment for display mode (RH-58316)
  • RDK: Assigning material to block instance is broken (RH-58353)
  • Rendering: Materials: Rendering Materials: Textures load at very low resolution (RH-58201)
  • ShowDir: The Flip command may repeat instead (RH-58461)
  • ToolPalettes: Grasshopper and Python buttons missing in the Command Editor buttons browser (RH-58533)
Enhancements:
  • Grasshopper: Add SubD as a type hint, GhPython Mac (RH-58228)
Features Added:
  • BlockManager: Supports selecting multiple block definitions in the list (RH-38048)
Tasks Completed:
  • PackageManager: Add Mac instruction to RhinoDocs (RH-58254)
Bugs Fixed:
  • RecordAnimation: Arctic mode leaves out ambient shadows (RH-58118)
  • ShowDir: The Flip command may repeat instead (RH-58232)
Cosmetics:
  • Rhino Installer Engine: Display version number on rhiexec dialog (RH-58415)
Crashes Fixed:
  • Textures: Crash on texture change (RH-58524)
Enhancements:
Rhino WIP 7.0.20147 for Windows and Mac is now available
Bugs Fixed:
  • Crease: Creasing a corner vertex adds unexpected creased edges (RH-58620)
  • DraftAngleAnalysis: Angle option (RH-2359)
  • DupEdge: Box mode creates smooth mode curve (RH-58608)
  • MeshSplit: Split meshes with each other with PermitSplittingWithEachOther option (RH-58468)
  • Rendering:
    • Post effect histogram drawing code is evaluated even when histograms are not shown on the screen (RH-58480)
    • Restore to defaults on Multiplier PEP doesn’t update image (RH-58481)
  • SubDLoft:
    • A case that doesn’t work (RH-54203)
    • SubDLoft - Not handling SubD-friendly case as expected (RH-58592)
  • Sweep2: Produces different results after Output SubD (RH-58540)
Crashes Fixed:
  • Bevel: RhinoCore!Mu7::MeshBeveller::MeshBevelVertex::CalculateEdgeVertexPoints – Access Denied (RH-58564)
  • QuadRemesh:
    • !DomainBoundILStubClass::NativeToManagedTransition – Access Denied (RH-58575)
    • !DomainBoundILStubClass::NativeToManagedTransition – Access Denied (RH-58591)
  • RDK:
    • rdk!LBPRhDisplayAlphaInDib – Access Denied (RH-58552)
    • rdk!CRhRdkDirectTextureBaker::PrepareFacePcToWc – Access Denied (RH-58577)
  • RDKCrash: DocumentProperties Command: rdk!CRhRdk::OnUnitsChangedWithScaling – Access Denied (RH-58301)
  • Stitch: Crash (RH-58519)
Enhancements:
  • CopyToClipboard: Now excludes document user text (RH-48141)
  • File IO: OBJ Export - New options for NGons (RH-58695)
  • SubDLoft: Create Interpolated SubD when all input curves are SubD-friendly (RH-57546)
Features Added:
  • Selection: New SelDimOverride Command (RH-58366)
Regressions Fixed:
  • Pipe: Extra click required in V6 and V7 (RH-58523)
SDK Enhancement:
  • SubD: Add Concave corner option to ON_SubDFromMeshParameters that is similar to the Concave corner. (RH-58467)
Tasks Completed:
  • QuadRemesh:
  • Selection: Change Name of SelDimOverride to SelDimTextOverride (RH-58365)
UI Change:
  • Snapshot: Snapshots: Add column header to panel (RH-58291)
  • Rendering: Materials: Rendering Materials: Made PBR Opacity default to 20% when Opacity section opens (RH-58449)
Mac-Only Changes
Bugs Fixed:
  • Rendering: Realtime SDK: Rendering Realtime SDK: Realtime engine integration causes Idle event to not fire while rendering (RH-58654)
  • ToSubD: Grouping issue of output objects (RH-58639)
Crashes Fixed:
  • Eto: System.NullReferenceException: Object reference not set to an instance of an object (RH-58611)
  • Stitch: com.mcneel.rhinoceros.RhCore:Mu7::StitchCommand::RunCommand(CRhinoCommandContext const&) (RH-58616)
Features Added:
Bugs Fixed:
  • ToSubD: Grouping issue of output objects (RH-58080)
Enhancements:
  • Grasshopper: Guid Parameter pick to accept preselection (RH-58583)
Rhino WIP 7.0.20168 for Windows and Mac is now available
Bugs Fixed:
  • 3DFace: SubD preview issue (RH-55749)
  • Append:
    • AppendFace: Joining fails randomly (RH-55899)
    • AppendFace: Heap corruptions (RH-58909)
    • AppendFace: Twisted preview in chain mode (RH-58936)
    • AppendFace: FromEdge allows snapping to dated boundary edges (RH-58939)
  • Color Picker: Custom colors aren't showing details but look like they want to (RH-58809)
  • Display:
    • Shaded display on grid plane doesn’t stay intact (RH-57626)
    • Rendered mode isn’t displaying locked objects with transparency (RH-58603)
    • Complaints about curve drawing speed in V6 and V7 (RH-58794)
    • Black triangles on WCS mapped object (RH-58834)
    • Result different from TestSilhouette (RH-58448)
    • Color gradient missing from dialog (RH-58953)
  • Eto: Some command dialogs have 0 padding (RH-59076)
  • ExtrudeSubD: Does not trigger Reflect update (RH-58379)
  • FilletSrf: Trim option does not work (RH-58998)
  • Grasshopper: The Grasshopper placeholder does not correctly keep Parameters connected. (RH-56215)
  • LayerStateManager: Gets width slider for no apparent reason (RH-58885)
  • Lock: Locking/hiding layers does not turn off automatically turned on control points (RH-58816)
  • MergeAllFaces: Goes on forever (RH-57219)
  • MergeFace: Locks up Rhino (RH-58196)
  • MeshIntersect: No result with these two triangles (RH-58694)
  • OSnap:
    • Make locked layer behave like locked object (RH-58871)
    • Make locked picture behave like locked surface (RH-58872)
  • OpenNURBS: Fix example_test and the subd logo test model so public opennurbs tests pass (RH-58890)
  • PlanarUnion: Planar boolean commands: Prompt tune up (RH-58989)
  • Polyline: Direction shifts from Helper for Arc (RH-59000)
  • RDK:
    • Exceptions in VS Designer (RH-58627)
    • PEPs are not executed right after they are added (RH-58734)
    • Quickly clicking material thumbnails in succession causes exception to be thrown (RH-58895)
    • New public IsSelected function for the Post Effect SDK (RH-59002)
  • Rendering:
    • Render doesn’t match Rendered viewport (RH-58632)
    • Glare filter defaults need to be a but different (RH-58888)
    • Rendering Materials: Custom Preview Material goes missing in Cycles (RH-58258)
    • Rendering Materials: Aliasing a drive with MS-DOS subst command causes problems with texture paths (RH-58500)
    • Rendering Materials: Clearcoat bump texture artifact in Rendered mode (RH-58604)
    • Rendering Texture Mapping: SubD advanced texture preview wrong after undo (RH-58454)
    • Rendering Texture Mapping: WCS mapped displacement on SubD doesn’t show WCS mapped color texture (RH-58595)
    • Rendering Texture Mapping: N-sided faces in SubD don’t show texture map (RH-58596)
  • SDK: Mesh vertex precision data loss in plug-ins and internal code (RH-58829)
  • SDK: Python: SDK Python: Rhino.WindowPick not the same as rhinoscriptsyntax.WindowPick (RH-58495)
  • SDK: RhinoCommon:
    • Fix comment for EarthAnchorPoint.EarthBasepointLongitude property (RH-54078)
    • BrepFace.CreateExtrusion documentation need updating (RH-58111)
    • SDK RhinoCommon: Bug in Mesh.GetNakedEdges() when using double precision vertices (RH-58919)
  • Selection: SubObject selecting fails (RH-58774)
  • SelectionFilter:
    • Activating SelFilters deselects current selection (RH-58372)
    • Single filter settings and Isolate do not get along (RH-58975)
  • SubD:
    • Add surface parameters in ON_SubD::GetSurfaceMesh (RH-58458)
    • Face with unset texture domain (RH-58526)
    • Change ON_SubD::ContentSerialNumber to GeometryContentSerialNumber (RH-58882)
    • High stretch on Ngon face with packed textures (RH-58898)
    • Planar mappings loose on a save/reopen (RH-58934)
  • SubD Editing: SubD mesh update needs to set texture mapping tag (RH-58507)
  • SubDLoft: Does not work with Chain option for rails (RH-58815)
  • ToNURBS: ToNurbs - SubD to brep - add option to make bigger brep faces (RH-53157)
  • Unwrap: Ruins SubD preview in Rendered mode (RH-58392)
  • ZoomExtents: Zoom Extents All in Model Space zooms out in Layout (RH-48834)
Crashes Fixed:
  • Rendering: "Safe Frame Settings" in Render menu causes crash (RH-59003)
  • Stitch:
    • ntdll!RtlpHeapFindListLookupEntry – Access Denied (RH-58563)
    • opennurbs!ON_SubD::Orient – Access Denied (RH-58621)
  • SubDLoft: Causes crash with two curves (RH-59018)
Enhancements:
  • BlendEdge: More progressive (RH-54486)
  • File IO:
    • OBJ Import - OBJ color converter supports alpha value (RH-58748)
    • SKP Import - New “Import curves” checkbox (RH-58876)
    • SKP Import/Export - Supports SketchUp 2020 file format (RH-58900)
  • FilletSrf: New BlendType=CircularFillet/G2Blend option (RH-58921)
  • Loft: Made SnapToKnots on by default for closed curve matching (RH-58650)
  • OSnap:Quad: OSnap Quad: Supports SubD edges (RH-58079)
  • Polyline: New ThroughPoint option when Mode=Arc (RH-58905)
Features Added:
  • BooleanDifference: Finalize TestPlanarDifference SDK in C++/RhinoCommon (RH-58516)
  • BooleanIntersection: Finalize TestPlanarIntersection SDK in C++/RhinoCommon (RH-58514)
  • BooleanUnion: Finalize TestPlanarUnion SDK in C++/RhinoCommon (RH-58512)
  • Grasshopper: New "Preview Boundary" display option (RH-58981)
SDK Enhancement:
  • RefitTrim: Expose in the SDK (RH-54621)
  • SDK: RhinoCommon: SDK RhinoCommon: Add functionality behind Plane > Deformable to RhinoCommon (RH-58858)
UI Change:
  • MatchSrf: Option "CurveNearSurface" is renamed "OnSurface" (RH-58854)
  • Menu: Add ClearAnalysisMeshes command (RH-58831)
  • Rendering: Materials: Rendering Materials: Preview geometries now use a fixed real-world size (RH-56806)
  • Color Picker: Color picker: Larger current color swatches (RH-58731)
  • FilletEdge: Option shortcuts are unstable (RH-58852)
  • Offset: Shift Trim option (RH-58853)
Mac-Only Changes
Bugs Fixed:
  • ApplyDisplacement: Displacement mesh modifier does not obey OCS frame (RH-57609)
  • Color Picker:
    • Does not open in RhinoWIP for Mac (RH-59081)
    • Resets all global options, and deletes all custom display modes (RH-59094)
  • Export: Information irrelevant to exported objects is also saved (RH-59014)
Crashes Fixed:
  • Displacement: com.mcneel.rhinoceros.RhCore:-[MROpenGLLayer drawInOpenGLContext:pixelFormat:forLayerTime:displayTime:] (RH-58615)
Enhancements:
  • Grasshopper:
Incomplete Port:
  • EditPythonScript: Search, replace, cut, copy, paste menus in EditPythonScript on macOS (RH-54432)
  • SDK: GHPython: SDK GHPython: Search, replace, cut, copy, paste menus in GhPython on macOS (RH-54431)
  • Display: Reflect confusion regarding which side is the parent (RH-58585)
Bugs Fixed:
  • Color Picker: Resets all global options, and deletes all custom display modes (RH-58733)
  • Export: Information irrelevant to exported objects is also saved (RH-58797)
  • Rendering: Cycles: Cycles: Not all CUBIN-files have been properly compiled (sm_3x) (RH-58184)
  • Worksession: Just one warning (RH-58728)
Rhino WIP 7.0.20182 for Windows and Mac is now available
Bugs Fixed:
  • Analytics: Ignore block members that are hidden or on off layer (RH-52413)
  • Annotation: Mirrored leader reverses text characters (RH-59258)
  • Annotation: Text: Text3d BoundingBox calculation is broken in Rhino7. (RH-59185)
  • Append: AppendFace picks wrong vertices (RH-59096)
  • BlendEdge: New blend CVs don't match across a G2 edge (RH-59156)
  • Block: When some block members are hidden, visible members may be selected but not highlighted (RH-59227)
  • BlockEdit: Block instance double click handler should not try to run nested (RH-59172)
  • Bridge:
    • Do not continue with selecting the second edge set when the first set is expected to fail (RH-57090)
    • Doesn’t allow face selection while command is running (RH-57203)
    • Fails on some faces (RH-59053)
  • ConnectSrf: Failure case (RH-59084)
  • ExtractRenderMesh: Conversion of ON_SubD packed texture to ON_Mesh m_S values is not accurate. (RH-59070)
  • ExtrudeCrv: Option shortcuts are unstable (RH-58896)
  • File IO:
    • PDF Export: Exporting Detail views creates blank PDF file (RH-58103)
    • DWG Export - Alternative units below dimension lines are missing (RH-59203)
    • DWG Import - Alternative units below dimension lines setting is ignored (RH-59204)
  • FilletSrf: Default to Round (RH-59142)
  • Grasshopper: SubDEdges stops working whenever input changes (RH-58018)
  • Layout: Typing activate name editing in Layouts panel (RH-58092)
  • MultiPipe:
    • Multipipe: Should work on curves as it does on lines (RH-58342)
    • Multipipe: Fails without explanation if some lines are not connected (RH-58465)
    • Multipipe: Duplicate lines can cause failure or unwanted result (RH-58466)
    • Doesn’t appear to use the Radius entered (RH-58602)
  • NamedSelections: Does not select all objects (RH-59064)
  • NamedView: NamedViews: Multiple named views won't be deleted at once (RH-58691)
  • Options: Appearance -> Colors are forgotten (RH-58738)
  • RDK: Intel C++ denoiser not buildable due to SDK changes (RH-59256)
  • RefitTrim: Input deleted on failure (RH-59041)
  • Rendering:
    • Glow and Glare Post effects are so slow it freezes Rhino (RH-58586)
    • Impossible to access IRhRdkRenderWindow for a given CRhinoView (when running a realtime renderer running) (RH-59017)
    • Rendered mode doesn’t show a close enough approximation of PBR bump mapping to be useful. (RH-59221)
    • Rendering Materials: Wacom LMB doesn’t open textures in PBR (RH-55993)
    • Rendering: Materials: PBR - Create from Texture Files (RH-56498)
    • Rendering Materials: Decals disappear when saving a file (RH-57959)
    • Rendering Materials: Assert when importing multiple materials from file (RH-58455)
    • Rendering Materials: Properties gives incorrect material info (RH-58948)
    • Rendering Materials: Texture maps in Zip are not extracted (RH-59071)
    • Rendering Texture Mapping: Unwrapped SubD ngons has errors at some repeat values (RH-59006)
    • Rendering Texture Mapping: Unwrapped SubD ngons have mapping artifacts on their interior (RH-59007)
  • SDK: RhinoCommon:
    • SDK RhinoCommon: Cannot create Tubes in RhinoCommon (RH-58214)
    • SDK RhinoCommon: Don’t use InteropWrappers for public SDK (RH-59035)
    • SDK RhinoCommon: CRhRdkPostEffect uses “Shown” twice, for different things (RH-59132)
    • SDK RhinoCommon: Remove RhinoView.IsPageView (RH-59198)
    • SDK RhinoCommon: ObjectPropertiesPageCollection.DocumentRuntimeSerailNumber misspelled (RH-59267)
  • SelBadObjects: Bad curve case (RH-58670)
  • Selection: Lag for leaders (RH-57326)
  • Stitch: Multiple separate SubD vertices can be stitched by preselect (RH-58821)
Crashes Fixed:
  • Rendering: SafeFrame - RhinoCore!__chkstk – (NTSTATUS) 0xc00000fd - A new guard page for the stack cannot be created. (RH-58447)
  • Eto: Constructor for BinaryFormatter causes stack overflow (RH-59219)
  • InsertEdge: RhinoCore!Mu7::NgonMeshEdge::Next – Access Denied (RH-56634)
  • Layout: Specific mouse clicks cause crash in Layouts panel (RH-59153)
  • Pull: RhinoCore!LoosePull – Access Denied (RH-59186)
  • Rendering: DocumentProperties Command: !RDK.Rendering.RdkRenderingRenderChannelsSection::RDK.Rendering.RdkRenderingRenderChannelsSection.SetCustomList – Access Denied (merge) (RH-59092)
  • Slide: Crashes with any SubD edge (RH-59216)
Enhancements:
  • Display: New "Skylight shadow quality" slider control in display mode options (RH-57803)
  • LayerStateManager: Detail view layer states can be restored to all selected detail views (RH-58813)
  • MultiPipe: Should not have the end-to-end limitation (RH-58544)
  • Reflect: Preselect allows adding reflect planes to multiple SubDs at once (RH-58819)
  • What: Reports meshing parameters information for Brep and SubD render meshes (RH-59182)
Features Added:
  • Color Picker: Added Hex color entry (RH-57937)
  • File IO: PDF Import - Supports reading layers from PDF (RH-58482)
  • Display: Cast shadows together with skylight shadows causes unreasonably bad performance (RH-59287)
SDK Enhancement:
  • SlideEdge: Expose core functionality in SDK (RH-54756)
Tasks Completed:
  • MultiPipe: New name of SubDThickenCurves command (RH-58923)
  • Rendering:
    • Clean up DumpToBytes Cycles evaluator optimization (RH-58980)
    • V-Ray for Rhino 6 is compatible with Rhino 7 (RH-59143)
  • SDK: RhinoCommon:
    • SDK RhinoCommon: PostEffectPlugIn class could use a SDK review (RH-59036)
    • SDK RhinoCommon: Remove SetHatchGeometry from RhinoCommon (RH-59266)
UI Change:
  • Bridge: Post-select allows selecting SubD/Mesh faces for input (RH-59155)
  • Menu: Add MakeSubDFriendly command (RH-59088)
  • Toolbar:
    • Add SelDimOverride Command (RH-58653)
    • Add ClearAnalysisMeshes command (RH-58832)
  • ConnectSrf: Changed to pick surfaces instead of edges (RH-58949)
Bugs Fixed:
  • ExtractRenderMesh: From SubD pays attention to custom meshing parameters (RH-59202)
  • Protocol Handler: Set class name for top-level Rhino window (RH-58697)
  • ReadCommandFile: Exit command does not work when used in command file (RH-59098)
Enhancements:
  • Grasshopper: Components: Grasshopper Components: SubD Edges - Tag output provides a richer description of edges (RH-59190)
  • Layer: Sublayers stay collapsed when another layer is dropped onto their parent (RH-58824)
Tasks Completed:
  • Installer: Add new Eto based crash reporting system to installer. (RH-59111)
UI Change:
  • File IO: PDF Export - Make Windows 7.x Export > PDF to use ETO Dialog (RH-59038)
  • Grasshopper: Components: Grasshopper Component: Request for unifying keystrokes (RH-59054)
Rhino WIP 7.0.20189 for Windows and Mac is now available
Bugs Fixed:
  • Block: Sub-objects of the block members on locked layers can be selected (RH-59295)
  • Display: "Skylight shadows quality" string correction (RH-59330)
  • GetPoint: Object snapping does not pay attention to per viewport layer visibility (RH-59245)
  • Grasshopper: Point Deform component doesn't always work on meshes (RH-58807)
  • Grasshopper: Components: Grasshopper Components: Justification of 3D Tag on Rhino 7 is off (RH-58478)
  • Help: RebuildUV - Degree 3 only in the rebuilt direction (RH-59349)
  • MultiPipe: Esc completes command instead of canceling (RH-58350)
  • Pan: During a command rapidly switching between panning/rotating with the RMB causes command to cancel (RH-59249)
  • RDK: Intel denoiser doesn't update when a post-effect before it updates. (RH-59375)
  • RefitTrim: Keep the flip flag (RH-59226)
  • Rendering: Render window doesn't remember last saved file type (RH-58087)
    • Rendering Materials: Create from texture files… tool in PBR material is very slow (RH-58248)
    • Rendering Materials: PBR is not 100% transparent in Rendered or Raytraced (RH-58384)
  • SubD:
    • SubD friendly fits mess up end CVs when fitting a closed curve with the seam before an arc segment (RH-53307)
    • Add ON_SubD::Offset with support for “solid” creation (RH-59327)
    • Clean up ON_SubDDisplayParameters before SDK freeze. (RH-59425)
  • Toolbar:
    • SrfControlPtGrid has been missed in icon of Surface from point grid (RH-58157)
    • SelAll missing on Select toolbar in v7 (RH-59282)
Enhancements:
  • Check: Zero-lenth polyline segments made by any actions are automatically removed (RH-45780)
  • Clash: Clearance Distance accepts negative values (RH-58933)
  • ExtractSubCrv: Does not provide info for incorrect curve input (RH-59279)
  • InfinitePLane: InfinitePlane: Curve option (RH-59392)
  • Installer: Installs a single-stroke font "SLF-RHN Architect" (RH-57126)
  • Rendering: All denoisers need better error output and handling (RH-58140)
  • Rendering: Materials: Rendering Materials: Made converting legacy material to PBR possible (RH-57438)
  • ToSubD: Works better with surfaces consisting of line and elliptical arc shapes (RH-51858)
Regressions Fixed:
  • Intersect: Breps Intersection Bug (RH-59237)
  • Rendering: EXR format not supported (RH-59384)
SDK Enhancement:
  • SDK: RhinoCommon: SDK RhinoCommon: Simple way to get active detail from a RhinoPageView (RH-59323)
Tasks Completed:
  • MultiPipe: Macro needs to change for SubDThickenCurves icon to Multipipe (RH-59259)
  • SDK: RhinoCommon: SDK RhinoCommon: Create modeless dialog host that will work on Mac and Windows (RH-58273)
  • Toolbar: EditPythonScript and EditScript added to Tools toolbar (RH-58530)
UI Change:
  • Toolbar: Add SelDimTextOverride command (RH-58378)
Bugs Fixed:
  • Context Menu: Does not repeat macro (RH-59314)
  • File IO: DWG Export - Leaders are incorrect (RH-59412)
  • Help: Correct index for Autosave in Help file (RH-59341)
  • RDK: Intel C++ denoiser doesn't execute when denoiser settings are changed (RH-59304)
  • Toolbar: OptionsImport missing on Tools toolbar (RH-59284)
Features Added:
  • Grasshopper: File overwrite warning in grasshopper (RH-59181)
Regressions Fixed:
  • Copy: Worksession InPlace Copies are in the attached file (RH-59359)
Rhino WIP 7.0.20196 for Windows and Mac is now available
Bugs Fixed:
  • Display: SubD wires appear on transparent rendering materials with this custom technical display mode (RH-59183)
  • Eto: GridView cell editing issue (RH-58152)
  • NamedSelections: Extrusions do not update when they become breps (RH-59456)
  • Pipe: History doesn't work with SubD output thick pipes (RH-59444)
  • Project: Project fails but MeshIntersect works (RH-31360)
  • Rendering: Cycles: Rendering Cycles: Unsupported channel (RH-59437)
  • SDK: RhinoGetRevolve not implemented (RH-55317)
Enhancements:
  • NamedSelections: Duplicating all objects of a named selection also duplicates the named selection (RH-58376)
  • SelVolumePipe: Remember the radius (RH-59411)
  • ToNURBS: New ExtraordinaryVertex=G0/G1/G2 options (RH-55492)
  • ToSubD: Do a better jobs of creating SubD friendly fits to elliptical arcs (RH-53319)
Regressions Fixed:
  • Rendering: Render window - Export of depth buffer image to EXR incorrect (RH-59383)
SDK Enhancement:
  • RDK: RhinoCommon - RenderWindow Channel class has inconsistent interface (RH-59379)
  • SDK: New SDK Functions for SubD Offset (RH-59390)
Mac-Only Changes
Bugs Fixed:
  • File IO: DWG Export - Leaders are incorrect (RH-59433)
  • Gumball: Rotate around gumball does not work from gumball menu (RH-59385)
UI Change:
  • Grasshopper: Components: Grasshopper Components: Request for unifying keystrokes (RH-59220)
Bugs Fixed:
  • Display: OpenGL 3.3: Display: Some Shaders Do Not Compile on VmWare Fusion 11.* (OpenGL 3.3) (RH-59244)
Enhancements:
  • Display: Lights: New global "Shadow Intensity %" setting in display mode options (RH-59072)
Bugs Fixed:
  • Annotation: DimAngular: Annotation: DimAngular: No resolution when using Degrees, Minutes, Seconds (RH-59338)
  • Documentation: Replace coerce* with scriptcontext method (RH-56763)
  • File IO:
    • STEP Export - Incorrect geometry read by TailorSteel (RH-50481)
    • 3DM Export - Bloated by unused textures (RH-57625)
    • PDF Import - Creates bad objects (RH-59253)
  • Localization: Typo in LayerBook printed string (RH-59512)
  • MacroLibrary:
    • Typo of Package Manager (RH-59286)
    • Two macro names start with a space character (RH-59410)
  • PackageManager: Yak's build command is stripping the icon_url field out of the manifest.yml file (RH-59246)
  • Polyline: Mode=Arc Throughpoint can fail (RH-59439)
  • Rendering: Cycles: Rendering Cycles: Pause controls no longer work in Raytraced mode (RH-59481)
  • SDK: Rhino 7 SDK does not include Visual Studio 2019 wizards (RH-56639)
  • SDK: GHPython: SDK GHPython: Namedtuple bug in ghpythonlib.components (RH-59408)
  • SDK: RhinoCommon: SDK RhinoCommon: Line.IsValid is invalid (RH-59493)
  • SelValue: Prompt tune up (RH-58692)
Crashes Fixed:
  • BlendEdge: RhinoCore!SetbackFil::calcFaceCrv – Access Denied (RH-59373)
Enhancements:
  • BoxEdit: Made "Use current CPlane" option sticky (RH-59351)
  • File IO:
    • DWG/DXF Export - Saves Rhino Model Base Point as AutoCAD Base location (RH-59222)
    • DWG/DXF Import - Reads AutoCAD Base location as Rhino Model Base Point (RH-59225)
  • Help:
    • Gumball DragStrength article addition (RH-59173)
    • Add dialog path to top of every option/preference topic (RH-59491)
  • Purge: New options for deleting unused environments and textures (RH-59548)
  • Rendering: Content Panels: Rendering Content Panels: Added "Select All" menu item to Materials, Textures, and Environment panels (RH-59549)
  • Rendering: Decals: Rendering Decals: Support WCS/WCSBox mappings (RH-57927)
  • Rendering: Textures: Rendering Textures: Is possible to select objects by textures (RH-59550)
  • SelectionFilter: Implement behavior of right-clicking "Disable" on Mac (RH-57748)
  • SynchronizeViews: Works with detail views of a layout (RH-32294)
SDK Enhancement:
  • SDK: RhinoCommon: SDK RhinoCommon: Added a version of Brep.CreateFromLoft to do end tangent matching (RH-45628)
Tasks Completed:
  • ApplyWatermark: Remove ApplyWatermark and FindWatermark commands (RH-59497)
  • SDK: RhinoCommon: SDK RhinoCommon: Review .NET SDK (RH-57915)
UI Change:
  • Display: Change "Color percentage %" to "Color reduction %" (RH-59501)
Mac-Only Changes
Bugs Fixed:
  • OSnap: OSnaps: Option+click unexpectedly unchecks the one being clicked (RH-59454)
Crashes Fixed:
  • Display: PrintDisplay: Width greater than 1mm causes a crash (RH-59272)
  • Print: Width of 2mm causes print crash (RH-58957)
Enhancements:
  • Display: Lights: New global "Shadow Intensity%" setting in display mode options (RH-59145)
Features Added:
  • Grasshopper: Script editor settings should be sticky (RH-36725)
UI Change:
  • SelectionFilter:
    • Right Click Issues on Mac (RH-57712)
    • Is made to run in script mode on Mac (RH-59522)
Bugs Fixed:
  • SDK: Rhino C++ SDK installer tune-ups needed (RH-58795)
Rhino WIP 7.0.20203 for Windows and Mac is now available
Bugs Fixed:
  • MultiPipe: Does not remember the last used radius during the same session (RH-58348)
  • NamedSelections: Copies should merge sub object types (RH-59480)
  • Rendering: Render command using Cycles or legacy Rhino render fails to check for up to date render meshes before rendering (RH-59174)
  • Rendering: Texture Mapping: Rendering: Texture Mapping: Raytraced mode, material thumbnails and Renders do not show texture maps (RH-59593)
Enhancements:
  • File IO: PLY Import/Export - Supports double-precision meshes (RH-58862)
  • MultiPipe: Use "curves" instead of "lines" in prompt (RH-58477)
  • NamedSelections:
    • NamedSelection: Subobject selection sets duplicate with their top object (RH-56406)
    • Added the scriptable command that can be nested in other commands (RH-56876)
  • RefitTrim: New CurrentLayer option (RH-59431)
Features Added:
  • RefitTrim: RefitTrim - New command (RH-54617)
Regressions Fixed:
  • RDK: 'Don't show me this again option' does not do what I expect (RH-59488)
Tasks Completed:
  • SDK: RhinoCommon: SDK RhinoCommon: Review per document modeless dialog extension methods (RH-59347)
UI Change:
  • NamedSelections: Copies should use naming convention like layers (RH-59469)
Mac-Only Changes
Bugs Fixed:
  • Grasshopper: Components: Grasshopper: Components: Value List component not working with strings (RH-58158)
Enhancements:
  • Grasshopper: Components: Grasshopper: Components: More outputs for various edge types added to SubD Edges component (RH-59262)
Features Added:
  • Grasshopper: Fixed overwrite warning dialog when loading the same document multiple times (RH-59419)
UI Change:
  • OSnap: Vertex, Percentage, OnMesh, POnCrv, POnSrf, POnPSrf, and POnMesh added to One shot list (RH-58532)
Bugs Fixed:
  • Layer: Visibility works incorrectly after moving layer (RH-47206)
  • SDK: GHPython: SDK: GhPython: Option to print output as plain text instead of GridView (RH-59534)
Rhino WIP 7.0.20217 for Windows and Mac is now available
Bugs Fixed:
  • 3DFace: Osnap check boxes disappear and don't work during 3DFace (RH-59440)
  • Display: Filewatcher causing texture update issues due to tight code looping and modifying existing files. (RH-59416)
  • ExtractRenderMesh: Does not use per object custom mesh parameters on Breps (RH-59679)
  • File IO:
    • Slow save on external HDD via USB 3.0 or HDD internal SATA 6 Gbs (RH-53023)
    • DWG/DXF Export: Dimension lines “Fixed length extension” is ignored (RH-58763)
    • 3DS Import - Says FXB in warning message (RH-59714)
  • Localization: String extraction removes comments (RH-59697)
  • RefitTrim: An unexpected failure (RH-59086)
  • Rendering: Materials: Rendering: Materials: Select objects by material ignores locked layers (RH-58441)
    • Rendering: Textures: Refreshing textures not working correctly (RH-59085)
    • Rendering: Textures: Alpha channel transparency broken in V7 (RH-59602)
  • SDK: RhinoCommon: SDK: RhinoCommon: Disable event watchers when reading headless doc (RH-59091)
  • Snapshot: Restoring Snapshots using lots of memory (RH-58903)
  • Toolbar: SoftTransform macro tune up (RH-59520)
  • Weld: Does not work properly on planar faces of a mesh (RH-59647)
Crashes Fixed:
  • Bridge: Rhino freezes when face counts different in two sets (RH-59296)
Enhancements:
  • ArrayCrv: Changed to use command-line options with preview (RH-6445)
  • File IO: 3DS/FBX Import - Prompts a warning if more than 1000 SubD faces will be created (RH-57244)
  • Move: New Normal option (RH-2741)
  • Rendering: Textures: Rendering: Texture: Allows to add multiple bitmaps to Textures panel at once (RH-59506)
SDK Enhancement:
  • SDK: RhinoCommon:
    • SDK: RhinoCommon: Added two new full-featured Sweep1 methods (RH-56247)
    • SDK: RhinoCommon: Expose ON_KnotVectorStyle (RH-59711)
Mac-Only Changes
Bugs Fixed:
  • Rendering: Textures: Rendering: Textures: Offset gets messed up on WCS texture on Mac (RH-59333)
Bugs Fixed:
  • Properties: The scriptable command affects un-selected objects (RH-59518)
  • RDK: High dynamic range UI problems (RH-59521)
Crashes Fixed:
  • 3DFace: Hangs with mp4 video clips in help topic (RH-59459)
Enhancements:
  • NamedSelections: Added Worksession support (RH-57812)
Rhino WIP 7.0.20224 for Windows and Mac is now available
Bugs Fixed:
  • File IO: Expired WIP reports successful save but does not save (RH-59283)
  • Move: Normal option does not work with curve (RH-59713)
  • MultiPipe: Ends fold back with larger radii (RH-58578)
  • Rendering: Higher than 72 DPI Rendering settings crop render (RH-57806)
  • Rendering: Cycles: Rendering: Cycles: Raytraced sample control in the viewport goes to 0 when trying to change it and can't be fixed (RH-59696)
  • Rendering: Post Effect: Rendering: Post effects: Run every time a viewport is refreshed (RH-58474)
  • SDK: RhinoCommon:
    • SDK: RhinoCommon: Obsolete warning when building RDK-related RhinoCommon samples (RH-59443)
    • SDK: RhinoCommon: TextEntity.CreateExtrusions returns null items intermittently (RH-59680)
  • SubD: Fix bugs in ToSubD .NET SDK (RH-59664)
  • SubDSweep2: Stopped working (RH-59716)
  • ToSubD: Crease conversion is incorrect (RH-59700)
  • Trim: Trimming hatch makes it invisible when selected (RH-59438)
Enhancements:
  • OffsetSubD: Respects creases from the input (RH-59073)
  • Print: Print colors support transparency (RH-59733)
  • Toolbar: Added RemoveExistingSymmetry to RMB of the Reflect button (RH-59291)
Features Added:
  • Annotation: Hatch: Annotation Hatch: Supports transparent colors (RH-45234)
  • OffsetSubD: New command (RH-53773)
Regressions Fixed:
  • Rendering: Textures: Rendering: Textures: Bitmap Texture Settings doesn't display the file name (RH-59496)
Tasks Completed:
  • Display: Check that all shaders are included in xcode project (RH-59529)
  • LayerBook: Docs (How) (RH-58956)
  • NamedSelections: Create Announcement Post (RH-59427)
UI Change:
  • Annotation: Hatch: Annotation: Hatch: Wording tune up for Gradient hatches (RH-57905)
  • ArrayCrv: Made scriptable command the one and only mode (RH-59648)
Mac-Only Changes
Bugs Fixed:
  • Color Picker: Custom color list selecting issue on Mac (RH-59768)
Enhancements:
  • Display: RH-56918 Display: Layers and objects support transparent colors (RH-57213)
Bugs Fixed:
  • Color Picker: Print color in Properties Panel missing the opacity slider (RH-59784)
  • NamedSelections: Items from previous file remain after new file (RH-59702)
  • RDK: UI - Materials refresh their thumbnails when re-ordering a material (RH-58894)
Enhancements:
  • Display: Layers and objects support transparent colors (RH-56918)
  • Update System: Now only prompts update when the last Rhino window is closed (RH-57839)
Features Added:
  • Licensing and Validation: Gracefully refuse to load Rhino.Inside when no licenses are available (RH-55790)
Rhino WIP 7.0.20231 for Windows and Mac is now available
Bugs Fixed:
  • Annotation: Hatch: Annotation: Hatch: Doesn't update properly if the added stop is edited immediately after creation (RH-59719)
  • Append:
    • AppendFace uses the incorrect material after completion (RH-59683)
    • AppendFace: Snaps fail after toggling SubD appearance (RH-59917)
  • BlockEdit: Does not work properly for hidden and locked objects (RH-46745)
  • Display: Test Case - reduced RH7 performance - 6000 block instances (RH-58833)
  • Grasshopper: Components: Grasshopper: Components: Sweep fails on rails with unusual domains (RH-59766)
  • Join: Solid is inside out (RH-59755)
  • MeshSplit: ESC won't cancel when progress is above 70% (RH-59632)
  • NamedSelections: Cleared from 3dm file when opened on Mac (RH-59731)
  • Properties: Changing top material should not remove per-face material (RH-58097)
  • RDK: RhinoCommon PostEffects don't get disposed of (RH-59254)
  • Rendering: Previews are being refreshed too often (RH-58767)
  • Rendering: Materials: Rendering: Materials: Thumbnail doesn't show entirely transparent (RH-59354)
  • Rendering: Post Effect: Rendering: Post Effects: GPU rendering only draws an alpha checkerboard while Toast is rendering (RH-59721)
  • SDK: Python: SDK: Python: rs function ProjectPointToMesh() returns two points (RH-59348)
  • SDK: RhinoCommon:
    • SDK: RhinoCommon: Remove Obsolete Channel.GetValues(int x, int y, int width, int height… (RH-59449)
    • SDK: RhinoCommon: Make the compact argument work again for MeshFaceList.DeleteFaces and MeshFaceList.RemoveAt (RH-59863)
  • SubD: Extruding with Gumball sometimes looses crease on edge (RH-58423)
  • SubDSweep1: Creates Incorrectly Ordered Control Net (RH-58112)
  • ToNURBS:
    • Leaves gap around dart vertex (RH-57825)
    • Remove unneeded and complicated code from SubD to NURBS (RH-59816)
  • UserText: Enter does not return focus to the command line (RH-59642)
Crashes Fixed:
  • rdk!CRhRdkDocumentDataSource_RenderChannels::OnCustomEvent – Access Denied (RH-59823)
  • InsertEdge: Crashes Rhino after execution (RH-59847)
  • Rendering: Post Effect: Rendering: Post Effect: Raytraced mode crashes with NVIDIA Denoiser (RH-59846)
Enhancements:
  • SelColor: Supports alpha value (RH-59788)
  • Selection: New color settings for window/crossing selection rectangles (RH-59791)
  • Stitch: Post-selection automatically accepts vertex without pressing Enter (RH-58131)
Regressions Fixed:
  • Annotation: Linetype: Annotation: Linetype: Don't work inside blocks (RH-59759)
SDK Enhancement:
  • SDK: RhinoCommon: SDK: RhinoCommon: RhinoUnWeldMeshVertexes is made a publicly exported function (RH-59883)
Tasks Completed:
  • QuadrangulateMesh: Make it a hidden command so it doesn't autocomplete (Reverted) (RH-54821)
  • RibbonOffset: Create Python Example (RH-58306)
UI Change:
  • CommandPrompt: Use "Press enter when done" for transform commands when Copy=Yes (RH-59240)
  • Join: SubDJoinedEdges setting now sticky between sessions (RH-59795)
  • Toolbar: Remove QuadrangulateMesh toolbar button from v7 (Reverted) (RH-54907)
  • ClippingPlane: Delay in selection (RH-56789)
  • InsertEdge: Should override selection filter (RH-59305)
Mac-Only Changes
Bugs Fixed:
  • Display: Import display mode does not replace default (RH-57390)
Incomplete Port:
  • Layer: Added "Select object layer" to Layer panel on Mac (RH-45828)
UI Change:
  • Sweep1:
    • SubD Output option is removed from Sweep1 and Sweep2 (RH-59840)
    • Remove SubD output option from Sweep1 and Sweep2 commands (RH-59852)
Bugs Fixed:
  • Color Picker: Color picker: Alpha does not work properly in Advanced settings (RH-59793)
  • Rendering: Denoiser post effects can't be toggled in Raytraced mode if the sample target has been achieved (RH-59781)
UI Change:
  • Sweep1:
    • SubD Output option is removed from Sweep1 and Sweep2 (RH-59715)
    • Remove SubD output option from Sweep1 and Sweep2 commands (RH-59798)
Rhino WIP 7.0.20238 for Windows and Mac is now available
Bugs Fixed:
  • Menu: SubD > Edit Tools > Extrude Faces and Boundary Edges calls wrong command (RH-59928)
  • 3DFace: Add to Mesh Tools toolbar (RH-59983)
  • Append:
    • AppendFace doesn’t allow box mode SubD toggle during command (RH-59797)
    • AppendFace: Does not show disjoint SubD parts (RH-59945)
  • Bevel: Adds unnecessary edge that can't be deleted (RH-59514)
  • File IO: AI Export - Font and encoding issues (RH-59270)
  • InterpCrv: Curve can be closed by picking, but Close and Sharp options are not available (RH-60000)
  • Layout: Copied layout is not added right under the original (RH-59914)
  • NamedSelections: Lose focus on the name (RH-59958)
  • RDK:
    • Ground plane height can’t be changed (RH-59464)
    • Thread Engine Shutdown happens too late, RhinoCommon callbacks are already unhooked (RH-59916)
    • Ground Plane resets to 0 when switching to manual (RH-59960)
  • Rendering: Textures: Rendering: Textures: Deleting texture files externally hangs Rhino (RH-59471)
  • SDK: Clean up C++ SDK samples warnings (RH-59770)
  • SDK: RhinoCommon: SDK RhinoCommon: BrepFace.IsPointOnFace needs a tolerance parameter (RH-59800)
  • SubDLoft:
    • Shape count in dialog defaults to 0 incorrectly (RH-59967)
    • Smooth checkbox should depend on Join checkbox (RH-60022)
    • Cancel does not clear preview (RH-60030)
    • Crease option does not work for SubD friendly curves (RH-60038)
  • UnTrim: Untrim: Message tune up (RH-59785)
Crashes Fixed:
  • SynchronizeRenderColors: Crash after updating material (RH-60061)
Enhancements:
  • ArrayPolar: New UseLastAxis option (RH-54068)
  • Layout:
    • Re-ordering in Layouts panel support Undo/Redo (RH-55392)
    • Added Print button to Layouts panel (RH-59884)
Regressions Fixed:
UI Change:
  • File IO: AI Export - Displays a warning message about saving PDF when double-byte characters are exported (RH-59269)
  • SubDLoft: Added a dialog for options (RH-59954)
  • Toolbar:
    • Add LinetypeDisplay macro (RH-50408)
    • ‘Unreflect’ added to RMB of SubD Reflect button (RH-59527)
    • Added Move Vertical and Normal macros (RH-59612)
Mac-Only Changes
Bugs Fixed:
  • PackageManager: Does not launch on Mac (RH-59703)
  • Bridge: Scroll wheel not respected in MacOs (RH-59922)
Bugs Fixed:
  • Localization: Rhino Render Advanced Settings display in English (RH-59677)
  • SDK: Final SDK Freeze Step - prevent C++ plug-ins compiled against WIP SDKs from loading. (RH-49048)
  • SelectionFilter: Isolate causes SelectionFilter to open (RH-59977)
SDK Enhancement:
  • SDK: RhinoCommon: SDK RhinoCommon: Show or hide the Osnap bar from RhinoCommon (RH-59951)
Rhino WIP 7.0.20245 for Windows and Mac is now available
Bugs Fixed:
  • Bevel:
    • Can’t run transparent selection commands on Mac Rhino WIP (RH-45021)
    • Offset picking broken (RH-60034)
  • Cap: Fails on a SubD (RH-59033)
  • Connect: Does not simplify polyline (RH-60072)
  • Display: Support SubD per vertex colors in OpenGL VBOs (RH-60083)
  • Display: OpenGL 3.3: If VMWARE_OPTIMIZATION is undefined, shading in VMWare using CoreProfile outputs white object (RH-37172)
  • DraftAngleAnalysis: Silhouette.ComputeDraftCurve(angle) produces crease curves (RH-59157)
  • File IO:
    • IGES Import - Connected edges duplicated all at once by DupEdge command (RH-3894)
    • 3DS file does not open in Rhino for Mac WIP (RH-58197)
    • Rhino WIP asks “Save changes to Untitled” wrongly (RH-59968)
  • Gumball:
    • Displaced when dragging radius dimensions (RH-59672)
    • Scroll-wheel zoom stops gumball dragging (RH-59948)
  • Intersect: A pre/post pick error when sub-object-selecting a SubD face (RH-59899)
  • Layout:
    • Layouts panel - Dragging & Dropping Multiple Layouts Places Incorrectly (RH-59907)
    • Copying a Layout Disables Drag & Drop (RH-59913)
  • MeshSplit:
  • MeshTrim: Failed to trim/split (RH-28498)
  • PackageManager: Showing update available when partial semver used (RH-59704)
  • Print: Interior ngon edges incorrectly print in vector output (RH-59477)
  • RDK: CRhRdkCompoundClientChannel::SetValueRect causes high CPU utilization (RH-60016)
  • Reflect: Does not work on a model (RH-59941)
  • Rendering: HUD - The post effect star icon does not always update (RH-60078)
  • Rendering: Cycles: Server Busy with two Raytraced viewports (RH-59079)
    • PBR material appears blown out in Raytraced while adjusting settings (RH-58065)
    • Wrong preview size when rotating the thumbnail (RH-58977)
    • Bump default amount should be 30% (RH-60035)
  • Rendering: Textures: Tooltips incorrect (RH-59980)
  • SDK: RhinoCommon:
    • Modify RhinoTransformObjectsEventArgs to return grips and grip owners (RH-60006)
    • Create File3dm.FromByteArray (RH-60014)
    • RenderMaterial.SimulateMaterial old version is no longer called in V7 (RH-60021)
    • Update projects to target .NET 4.8 (RH-60024)
  • Settings: AppearanceSettingsState missing EditCandidateColor (RH-60063)
  • SubD: Create and maintain SubD toolbar (RH-51987)
  • SubDLoft: If 'adjust shape segments' is unchecked, the adjusted shape segments field should be grayed out (RH-59991)
  • SubDSweep2: Rail segments can't be increased above a certain value with this file (RH-59990)
Crashes Fixed:
  • RDK:
    • Render: rdk_ui!CRhRdkUiRenderFrame::Instantiate – Access Denied (RH-58576)
    • Render: opennurbs!ON_SHA1_Hash::IsZeroDigest – Access Denied (RH-59806)
  • Rendering: Textures: Using a non-image file as a texture crashes Rhino (RH-59644)
  • TextObject: Crashes with single line font (RH-59796)
Enhancements:
  • 3DFace: Starts in Append mode when meshes or SubD are pre-selected (RH-58683)
  • CollapseMeshVertex: CollpaseMeshVertex: Now supports multiple undo's (RH-59900)
  • Eto: TreeGridView Expanding detection during Cell Click / Mouse Up (RH-60048)
  • Help: Added notes about procedural texture mapping issue when extracting render meshes from NURBS and SubD (RH-59008)
  • NamedSelections: Added Header Click Column Sorting (RH-60040)
  • PackageManager: Specify build target platform and version (RH-58098)
  • Rendering: Materials: PreviewStudio environment is improved for better lighting in thumbnails (RH-54759)
  • SynchronizeRenderColors: Works with per-face colors (RH-59902)
  • WeldVertices:
    • Now works on SubD vertices (RH-49973)
    • Now works on SubD control points and edit points (RH-60124)
Regressions Fixed:
  • Print: PDF printing of skylight shadows has artifacts at DPI higher than 175 (RH-59989)
  • Surface-surface intersection: Intersection bug (RH-59494)
SDK Enhancement:
  • SDK: Added SubDSweep1, SubDSweep2 and SubDLoft functions (RH-59912)
  • SDK: RhinoCommon:
    • Supports reading plugin data when importing a 3dm file (RH-60129)
    • Convert KnotStyle() from method to property (RH-60146)
Tasks Completed:
  • Mesh2: Removed from Rhino 7 (RH-59890)
UI Change:
  • Toolbar:
Web Page:
  • LayerBook: Docs (What, Why) (RH-58955)
Mac-Only Changes
Bugs Fixed:
  • EditPythonScript: Does not pass all printed output to the output pane (RH-59979)
  • Grasshopper: Cannot add menu items to Grasshopper on Mac from a plugin (RH-60045)
  • Layout: Copying layout crashes on Mac (RH-60066)
  • MoveFace: Highlights all selection candidates in Technical, Artistic, or Pencil modes (RH-57391)
  • Rendering: Post Effect: v0.3.0 of the Intel Denoiser isn't found or won't install on Mac (RH-59993)
  • RhinoStart: Rhino WIP won't start due to missing symbol (RH-60089)
  • SDK: RhinoCommon: Plug-ins can't find Newtonsoft.Json (RH-60094)
Crashes Fixed:
  • PackageManager: System.InvalidCastException: Specified cast is not valid. (RH-59517)
Windows-Only Changes
Bugs Fixed:
  • Installer: .NET 4.8 installation triggers reboot; Bootstrapper fails to handle it properly (RH-60062)
  • Layout: Copy behavior different on tabs (RH-60067)
  • Rendering: Materials: ASSERT when opening file (RH-60113)
  • SDK: Rhino 7 SDK installer requires VS2019 the error message says it requires VS2017 (RH-60114)
Crashes Fixed:
  • Analysis:EdgeContinuity: Analysis EdgeContinuity: Crash when toggling panel display (RH-59996)
  • Display: OpenCL!OpenCL – Access Denied (RH-59746)
Enhancements:
  • NamedSelections: Parent items can be reordered by drag and drop (RH-60058)
Usability Problems Fixed:
  • 3DFace: Appending from edges needs more feedback (RH-59460)
  • SubD: Sub-object selection is frustrating and inaccurate (RH-59666)
Rhino WIP 7.0.20252 for Windows and Mac is now available
Bugs Fixed:
  • BoxEdit: Panel and modifying the document (RH-60148)
  • DraftAngleAnalysis: Created mid curve is not on actual mid (RH-59095)
  • Extrude: ExtrudeSubD, Basis=UVN, Direction still shows X Y Z (RH-50124)
  • ExtrudeSubD: Fails on a specific face (RH-59020)
  • GetObject: Update picking to support layer and object transparency (RH-57212)
  • MeshIntersect:
  • Print: Printing Perspective view freezes Rhino (RH-47045)
  • RPC: RPC plug-in crashes on exit (RH-60135)
  • Rendering: Filewatcher: Material preview/Rendered display not updating when changing texture (RH-59964)
  • Rendering: Textures: Deliberate changes to mesh are reversed by texture coordinate updating code (RH-58335)
  • Split: By isocurves removes per face color (RH-59239)
  • SubD: Add ON_SubDVertex::SurfaceNormal() to C++ SDK. (RH-60167)
  • WeldVertices: Often not working with mesh from SubD (RH-58199)
Enhancements:
  • 3DFace: First ESC during appending now only aborts current polygon creation (RH-48637)
  • Display: Raytraced mode supports hidden clipping planes (RH-59031)
Features Added:
  • UVEditor: Added a mapping channel selection step (RH-48983)
  • Rendering: Materials: Further optimization for editor performance with 8k textures (RH-58508)
Regressions Fixed:
  • Rendering: Scene lighting should pass through clipping planes (RH-59726)
Tasks Completed:
  • Installer: Remove MeshUtilities plug-in from Rhino WIP for Mac (RH-60122)
  • Rendering: V7 does not have an option for "no environment" like v6 (RH-59995)
  • Selection: SelEdgeLoop, SelEdgeRing, and SelFaceLoop need to accept pre-selection (RH-59539)
Mac-Only Changes
Bugs Fixed:
  • Append: Mesh object that faces are appended to moves to current layer (RH-47562)
Enhancements:
  • Layer: "Select Object layer" in the Layers panel automatically scrolls to the selected layer (RH-45829)
  • SubD: Sub-object selection is frustrating and inaccurate - Mac (RH-60107)
Bugs Fixed:
  • Color Picker: Wrong Colors (RH-60110)
  • Installer: Update to a .Net Framework that supports .Net Standard 2.0 (RH-53250)
Rhino WIP 7.0.20259 for Windows and Mac is now available
Bugs Fixed:
  • Contour: Switch temporarily to old code (RH-60349)
  • Copy: Duplicated SubD edges should respect the display (RH-60050)
  • Curve-surface intersection:
    • CSX point way off in near tangent case (RH-5691)
    • Missing Curve Surface Intersection (RH-43607)
    • Misses point intersection (RH-47996)
  • DragMode: ControlPolygon mode does not work as expected (RH-60153)
  • Grasshopper: Components: Data Input update does not work (RH-60274)
  • Gumball:
  • Help: Re-render images in Render command topic using new Rhino Render (Cycles) (RH-56281)
  • LayerBook: NamedView cannot be reset to None (RH-60278)
  • Localization: A few strings still need to be wrapped in RhinoCycles UI (RH-59992)
  • PointDeviation: Copy to clipboard shows "Median distance" twice (RH-60216)
  • RDK:
    • Closing Rhino after using post-effect triggers assert due to C# callbacks already gone (RH-60227)
    • CRdkCmnPostEffect destructor asserts and crashes in debug Rhino from 7.x (RH-60324)
    • Ensure PBR lets light through properly (RH-58405)
    • Raytraced viewport is smudgy and slow (RH-59066)
    • Denoiser bumps CPU usage for the session (RH-59694)
    • Strange fog behavior in Raytraced mode (RH-59763)
    • Environment rotation not correct (RH-60090)
    • Created from textures get incorrect size values with WCS mapping (RH-59972)
    • PBR preview does not update when changing assigned texture (RH-60326)
    • UV Mappings and texture coordinates seem to be wrong in Raytraced (RH-43134)
    • Custom mapping fails (RH-46963)
    • Extruding SubD faces results in gaps (RH-56651)
    • Rendered mode texture preview update on SubD has issues during extruding (RH-58430)
    • SubD texture wrong after undo (RH-60229)
  • RhinoStart: Protocol handler shows "Rhino 6" when clicked (RH-55645)
  • SDK: RhinoCommon: Bug in RhinoCommon's TryGetFiniteCylinder method (RH-60245)
  • ShowNotifications: Rhino WIP notification reads "License obtained from Rhino Accounts for Rhino 6" (RH-55511)
  • Subobject Selection: Fails if viewport grid draws on top (RH-60343)
  • ToNURBS: Test case for bigger faces from SubD to Brep - Closed surfaces (RH-60157)
  • UVEditor: Can only edit channel 1 (RH-47667)
  • Unwrap:
    • New SymmetryTip option for symmetrical unwrapping (RH-46751)
    • Edit option should not ask for mapping channel (RH-60228)
Crashes Fixed:
  • File IO: DWG Open - Crash with drag and drop (RH-60125)
Enhancements:
  • EditPtOn: Make curve Edit Point editing keep polycurves as polycurves (RH-59413)
  • ExtractUVMeshes: ExtractUVMesh: Prompt for specifying a mapping channel (RH-53685)
  • File IO: TXT Import - Display a message about what delimiter is detected (RH-55582)
  • Help:
    • Text Fields topic needs additional links (RH-56815)
    • Added note about sub-object selection with Lasso and SelBrush (RH-59758)
    • Made Audit3dmFile and Rescue3dmFile topics mention each other (RH-60235)
  • PackageManager: Hide incompatible packages (RH-57790)
  • SelectionFilter: Sel* commands override filters when everything gets filtered out (RH-60331)
  • Stitch: Check input geometry and report defects (RH-55230)
  • Subobject Selection: SelEdgeLoop, SelEdgeRing, SelFaceLoop can be nested in commands (RH-51225)
  • UVEditor: UV mapping in different channels can be edited respectively (RH-47922)
  • Unwrap: New UnweldedOnly option for selecting unwelded mesh edges only (RH-58823)
Features Added:
  • Unwrap: New MappingChannel option (RH-48982)
  • Selection: Speed up visibility culling (RH-60391)
Regressions Fixed:
  • Trim: Fails if not pull the trimming curve first (RH-59326)
UI Change:
  • Menu: Add RefitTrim command (RH-59564)
  • UVEditor: Mapping mesh doesn't move after applied (RH-53857)
  • DupEdge: Edges in a block are not selected properly (RH-60012)
Web Page:
  • LayerBook: Video (What, Why) (RH-58958)
Mac-Only Changes
Bugs Fixed:
  • Eto: GridView drag and drop issue on macOS (RH-60010)
  • File IO: STL Export - Settings are not sticky on Mac (RH-60084)
  • Grasshopper: Control+Click should act as right-click on macOS (RH-59829)
  • LoadPlugin: When installed via the package manager, the IntelDenoiser plug-in doesn't always load correctly on Mac (RH-59774)
  • NamedSelections: Items from previous file remain in new file (RH-59730)
  • Preferences: Display modes from Windows won't import on Mac (RH-60044)
  • Print: Gradient hatch in layouts does not print on Mac (RH-60161)
  • Properties: Icon display issue on Mac (RH-60393)
  • Rendering: Denoiser post effects can't be toggled in Raytraced mode if the sample target has been achieved (RH-59946)
  • Rendering: Materials: Bitmap changes on the disk cause black or white junk in the viewport (RH-52806)
  • Rendering: Post Effect: Package manager/Post Effects - Denoisers won't show up (RH-60001)
  • Rendering: Textures: Bitmap texture gets black border (RH-58451)
  • UnWeldEdge: Added Undo option during edge selection (RH-60252)
  • Unwrap: Command option and workflow clean up (RH-51213)
Crashes Fixed:
  • Print: Crash when paper size is null (RH-60192)
  • 3DFace: Appending from edges needs more feedback (RH-60053)
Bugs Fixed:
  • StatusBar: x,y,z cursor position cause lags in display (RH-60248)
  • UVEditor: Command-line loses focus after clicking UVeditor icon (RH-60253)
Cosmetics:
  • Menu: Add separator to viewport menu after default display modes (RH-59833)
Crashes Fixed:
  • Annotation: Text: Crash when selecting text object (RH-60282)
Enhancements:
  • Grasshopper: Include local clusters in Create dialog (RH-60037)
  • RPC: Integrated new RPC tools from Archvision (RH-59891)
Regressions Fixed:
  • Grasshopper: Popup dialog layout incorrect for special inputs. (RH-60339)
