Rhino WIP 7.0.20071 for Windows and Mac is now available
Bugs Fixed:
- 3DFace: Appending with Interpolated=Yes moves existing SubD edit points (RH-57275)
- BlockManager: Changing Block def name should raise doc change events (RH-57114)
- Cycles:
- Display:
- Eto: Slider thinks everything is 0 to 100 (RH-57139)
- GetPoint: SnapToMeshObject forbids picking points off selected meshes (RH-57370)
- History: Editing grips turns off history locking (RH-57289)
- InsertPoint:
- Installer: Preparing Plug-ins for First Use (RH-56720)
- Layout: Size may not update in Layouts panel (RH-54357)
- OpenNURBS: ON_SumSurface copy constructor and operator= need work (RH-43931)
- Options: Reset to defaults error with construction plane options (RH-57267)
- Print: Can not preview the print (RH-57220)
- QuadRemesh:
- Rendering: Feather-setting for Fog in PEP needs more precision (RH-55641)
- Rendering: Materials:
- SDK: RhinoCommon: SDK: RhinoCommon: Needs some kind of view modified event (RH-56556)
- SelVisible: SubD objects are not selected (RH-57250)
- Selection: Ghosted picks of mesh edges not working (RH-57293)
- SlideEdge:
- Split: works with this curve in perspective view… should it? (RH-46534)
- Toolbar: Mouse-over hint rewording (RH-57257)
- Trim: Failure (RH-56923)
Cosmetics:
- Properties: Panel flickers when scrolling the Plug-ins list in Rhino Options (RH-56991)
Crashes Fixed:
- SubD: Crash after double-clicking edge on big SubD (RH-57319)
Enhancements:
- Annotation: Text: Annotation: Text: Single Stroke Fonts display better in Text/TextObject edit box (RH-50123)
- QuadRemesh: Allow group selection when picking guide curves (RH-57173)
- Selection: SelConnected works with SubD control points and edit points (RH-57316)
- UDT: CageEdit - SubD can be captive object (RH-57176)
Features Added:
- GetPoint: New SnapToMeshObject command (RH-52710)
- SubDAppearance: New SubDDisplayToggle command (RH-55232)
Regressions Fixed:
- Display: Front wires are transparent in Ghosted mode (RH-57295)
- Explode: Missing layer material names when referenced blocks are exploded (RH-57046)
SDK Enhancement:
- SubD: Add C++ SDK SubD tool to remove zero length edges (RH-57274)
Tasks Completed:
- OpenNURBS: Document RDK functions in ONX_Model (RH-57280)
UI Change:
- Toolbar:
Mac-Only Changes
Bugs Fixed:
- Enable RH_WRITE_DEBUG_REG in -DebugLog (RH-57302)
- Display: Color reduction in display modes doesn't stick (RH-56993)
- Layout: Current indication (bold) does not stick (RH-54973)
- Snapshot: Deleting Materials in Snapshot doesn't always update Snapshot (RH-56147)
UI Change:
- Menu: Add missing items in viewport title menu on Mac (RH-57199)
Windows-Only Changes
Bugs Fixed:
- Installer:
- Rendering: Missing render content (RH-50331)
Enhancements:
- UI Cleanup: Resize ImportLayout dialog box (RH-57252)
UI Change:
- Menu: Add SubDDisplayToggle command (RH-57354)
