Rhino WIP for Windows and Mac 7.0.19253 is now available!
Bugs Fixed:
- Annotation: Hatch: Color confusion (RH-54347)
- Annotation: Linetype: Not updated (RH-53956)
- ApplyShutLining: Shutlining doesn’t work on Subd objects (RH-54536)
- Bridge:
- Bridge - fails on these SubDs (RH-53064)
- Bridge command - unexpected creases (RH-53065)
- Bridge needs a option of alignment (RH-52684)
- Bridge options inconsistent (RH-53259)
- Bridge seam point (RH-52135)
- Bridge should use Weld as the default (RH-53602)
- Hard time selecting alignment dots (RH-53906)
- Limit edge loop selection to open edges (RH-46838)
- ClippingPlane: Subd objects don’t show clipping plane edges (RH-54471)
- Copy: Copying a SubD edge/point makes a copy of the whole SubD (RH-54664)
- Help: Help article for PrintDisplay should say the command isn’t sticky (RH-54387)
- MeshIntersect:
- MeshSplit:
- Make MeshSplit work with Infinite Planes (RH-53735)
- MeshSplit creates output which, when joined, has a non-manifold face (RH-44607)
- MeshSplit does not work on the tiny and redundantly pre-divided strip (RH-54275)
- MeshSplit failure (RH-54543)
- MeshSplit gets it wrong when splitting curve passes through multiple vertex point (RH-34559)
- Splitting a disjoint mesh removes areas of the mesh that do not get an intersection result (RH-42678)
- RDK: Delete curve and shut lining still shows the curve. (RH-52998)
- Rendering:
- Rendering: Texture Mapping: Subd objects don’t have a texture mapping property icon (RH-50789)
- Rhino Inside: Exceptions thrown when working with headless doc (RH-54552)
- Settings: UI - Assert fires when changing background color (RH-51376)
- SmartTrack: Smart Ortho typed distances (RH-54559)
Enhancements:
- Annotation: Hatch: Match hatch at creation time. (RH-37578)
- RDK: Import plug-ins should create RDK materials (RH-51432)
- SelChildern: New DeselectOthersBeforeSelect option (RH-54164)
UI Change:
- Annotation: Hatch: Enable new ETO Hatch create dialog as the default for wip 7 win & mac (RH-54555)
