Rhino 7 and Enscape 4 - Error: Rhino7Plugin.dll
We just started to get this error on a users machine (Win11/Full Admin Access). When opening Rhino7, a popup appears that Enscape can’t open and that a Rhino7.Plugin.dll is required.
I’ve uploaded the error here:
its failing to load enscape.Rhino7.plugin.dll
Do you have any of the conflicting plugins they mention?
You can disable 3rd party plugins for testing via File>Properties>Plugins , restarting Rhino is req’d after changes
The error doesn’t say anything about conflicting plugins - but when I get on the users machine I will try your suggestion.
On the Enscape page i linked they mention a couple, there could be others as well.
" Note: There are conflicts with two other Revit plugins: Colorizer and Techviz. To avoid incompatibilities, please uninstall them before using Enscape."
Those weren’t installed on the system…
