Hello good people of the internet,
After downloading the most recent version of Rhino 7 (7.16, March 2022) my grasshopper files will no longer load. In particular, I use some modules in the Pancake add-on to load .obj files into rhino and perform mesh operations. I bring up the pancake module because my grasshopper file will load as long as the module is not trying to input a .obj file. If it is trying to input a file (which was done without issue for months prior to most recent update), grasshopper will not load the algorithm at all, though it will eventually output the proper files (which is even more head scratching). If there is no direct fix, is there any way to revert my rhino 7 back to the version before the latest update? Iâm grateful for any help you fine folks give! Iâve attached my system info if that helps.
System Info:
Rhino 7 SR16 2022-3-8 (Rhino 7, 7.16.22067.13002
License type: Commercial, build 2022-03-08
License details: Cloud Zoo
Apple macOS Version 12.2.1 (Build 21D62) (Physical RAM: 64Gb)
Rhino is running in Rosetta2 on Apple Silicon
Mac Model Identifier: MacBookPro18,2
Language: en-US (MacOS default)
Apple M1 Max (OpenGL ver:4.1 Metal - 76.3)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 48 GB
Graphics: Apple M1 Max
Displays: Unknown (255dpi 2x)
Graphics processors
Apple M1 Max
Color LCD (1728 x 1117 @ 120.00Hz)
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp âPanelingToolsâ 7.16.22067.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp âGrasshopperâ 7.16.22067.13002
/Applications/Rhino 7.app/Contents/PlugIns/import_IGES.rhp âIGES Import Plug-inâ 7.16.22067.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp âDisplacementâ 7.16.22067.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework âRenderer Development Kitâ 7.16.22067.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp âImport_OBJâ 7.16.22067.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp âIronPythonâ 7.16.22067.13002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp âSnapshotsâ 7.16.22067.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp âCommandsâ 7.16.22067.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp âRhino Renderâ 7.16.22067.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp âRDK_EtoUIâ 7.16.22067.13002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp âLegacy Rhino Renderâ 7.16.22067.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp âRhinoCyclesâ 7.16.22067.13002
