Rhino 6: wrong signs of negative tolerances
Hi @lowell,
how to set two negative tolerances without the additional wrong signs?
Thanks
Michael
www.flexiCAD.com
Hi Michael - that looks buggy to me - you can fix it by deleting the “-” that is in front of the tolerance number in Properties and leave it with no sign at all.
https://mcneel.myjetbrains.com/youtrack/issue/RH-44355
Hi Michael -
You can’t do that now.
Is that a common thing in Germany?
I’ll see if I can fix it so you can.
https://mcneel.myjetbrains.com/youtrack/issue/RH-44354
Lowell
I think that might be applicable anywhere. It just means that the value has to be less than the indicated dimension in all cases and it specifies the range it should fall into…
Yes, I get the intent. I’ve just never seen it used.
Many thanks to Michael for passing on my report.
Here is an example that I copied from my table book.
It shows the standardised dimensioning of a minus tolerated stud.
best regards
Robert
tol
