I find myself using the TAB direction lock feature all the time, and thought it would be a cool feature if the lock direction could be toggled orthogonal to the picked direction. Toggled direction would be based on the current c-plane, for instance.
‘‘Mesh to surface’’ could be less nurbs surface for a high-poly model. Thanks
If I understand it right, you can use CTRL+click to lock the verticle point.
